Page 5 of 5 FirstFirst ... 345
Results 61 to 65 of 65
Thread: Firmware v1.9.2.7 CR2 [Oleg]
  1. #61
    Lightbulb Some questions about 1.9.2.7-3
    Addiotinal load was probably caused by debug messages produced by pptp kernel modules - try 1.9.2.7-3.
    Hi Oleg,
    couldy you answer me to this questions please:
    in 1.9.2.7-3
    - is it possible to make wireless bridge in client mode (the same network at eth2 & eth0)
    - where is watchdog configuration? how can i change it? what is in it's config by default?
    - is it possible to enable afterburner with this fw?, does afterburner works in WDS mode too?
    - what about WPA? does it works in WDS?
    i cannot test this thing at this time, by i need them.
    Could you, or somebody test this and give me answers?
    thanks a lot for all.
    btw. THX for very nice and helpful firmwares Oleg. I'll send you some donations when i earn some money. For this time i'm 'moneyless'
    Pipos (2xWL-500g, WDS-only mode, used as backbone for MAN network; 1xWL-500g in Client Mode with NAT)
  2. #62
    Quote Originally Posted by pipos
    in 1.9.2.7-3
    It's better to post this in the 1.9.2.7-3 thread.
    Yes, switch to AP mode, which should do the trick.
    what do you need exactly?
    Sure.
    have no idea. I do not have afterburner capable devices.
    it does not work with 1.9.2.7.
    There is no need to donate answers, the only donation Antiloop asked about was forum support, i.e. forum license and hosting. We're helping for free.
  3. #63
    Dec 2004
    Skopje, Macedonia
    Question Wireless lost
    I've been using 1.9.2.7-1 and everything was fine. Obviously, I disobeyed the rule.."don't touch it if it works" and I upgraded to 1.9.2.7-3. And it happened that I couldn't ping wireless clients and WDS clients anymore. Same happened when I downgraded to 1.9.2.7-2. When I downgraded to 1.9.2.7-1 again, it started working. All this was without hard reseting the router. BTW, in the Status&Log->Wireless section of the web interface, I could see the wireless client MAC address and it said .. associated.
    "What's the color of a chameleon put onto a mirror?" - Stewart Brand.
  4. #64
    Quote Originally Posted by yato
    Also I have discovered that limits labeled as kbps (kilobits) in GUI are kBps (kilobytes) in fact (tc reports numbers eight times higher than entered!)
    So, it looks like QoS doesn't work, but if you divide limits by eight, it works fine - maybe Oleg can fix that in custom FW.
    Good finding, hopefully I've fixed it now.
  5. #65
    Quote Originally Posted by bungee
    today i had the second time an crash of the pppoed. After a restart everything works fine. will this problem fixed i the next cr release?
    Bye Enno
    My FW is 1.9.2.7 CR3
    bungee, this is not CR3 topic. also, there is already 1.9.2.7-3a available for download, which fixes most of the problems. If you still has problems, post your syslog to the correct thread.
    Last Post: 14-04-2005, 00:26
  2. Firmware v1.7.5.9 CR2 [Oleg]
    Last Post: 06-10-2004, 09:12
  3. Firmware v1.7.5.6 CR2 [Oleg]
    Last Post: 05-05-2004, 04:10
    Last Post: 03-05-2004, 12:13
    Last Post: 07-04-2004, 18:22
