Results 1 to 4 of 4
Thread: Help with HP 1018
    Help with HP 1018
    I connect Canon iP4300 with asus wl-500gP and it worked, but HP 1018 laser printer don't. Tryed to search information in this forum, but what i found i don't known what to do exactly and what i tryed to do-don't helped.
    Can someone write detailed tutorial, please?
    p.s. sorry for my terrible english
    Please HELP!
    Jul 2007
    Austria
    Well, maybe you'll get your stuff working.
    Read carefully (particularly posting => 11)
    http://wl500g.info/showthread.php?t=4092
    It can be, that the fw to download is pretty the same.
    Jan 2008
    Novi Sad, Vojvodina, Serbia
    I managed to get HP LJ 1000 and 1020 working, with help from this forum
    firmware for 1018 is here: http://oleg.wl500g.info/hplj/
    Try to use sihp1018.dl instead of sihp1020.dl, and replace it in scripts too.
    Depending on windows driver version, you need to disable bidirectional support or it blocks windows and router printing completelly, only restart helps.
    Good luck!
    A.
  1. Help with WL-500gP and HP 1018
    By VrXStylE in forum WL-500gP Q&A
    Last Post: 27-03-2008, 20:19
  2. HP laserjet 1018 (1020) on WL500GP - Proper HOWTO needed
    By darkdiablo in forum WL-500gP Q&A
    Last Post: 03-01-2008, 21:27
  3. Scanner
    By bbetoo in forum WL-500gP Q&A
    Last Post: 27-10-2007, 12:32
