Also, the link which you've posted for manual is for other model as seems.
Also, I'm suggesting you to print images which you've just posted, to be able to get back.
It doesn't work.
It says it's disconnected or something:
http://home.wanadoo.nl/vsteenis_adsl/log.txt
Jan 1 01:00:06 pppd[80]: PPPoE: Use eth1 for PPPoE discovery
Jan 1 01:00:06 pppd[85]: pppd 2.4.1 started by admin, uid 0
Jan 1 01:00:06 pppd[85]: Sending PADI
Jan 1 01:00:06 kernel: neg fail
Jan 1 01:00:11 kernel: lp driver: get device ID
Jan 1 01:00:11 kernel: neg fail
Jan 1 01:00:56 pppd[85]: Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x10020000
Jan 1 01:00:56 pppd[85]: Couldn't get channel number: Transport endpoint is not connected
Jan 1 01:00:56 pppd[85]: Doing disconnect
Jan 1 01:01:26 pppd[85]: Sending PADI
Jan 1 01:02:16 pppd[85]: Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x10020000
Jan 1 01:02:16 pppd[85]: Couldn't get channel number: Transport endpoint is not connected
Jan 1 01:02:16 pppd[85]: Doing disconnect
Jan 1 01:02:46 pppd[85]: Sending PADI
Jan 1 01:03:36 pppd[85]: Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x10020000
Jan 1 01:03:36 pppd[85]: Couldn't get channel number: Transport endpoint is not connected
Jan 1 01:03:36 pppd[85]: Doing disconnect
Jan 1 01:04:06 pppd[85]: Sending PADI
Jan 1 01:04:56 pppd[85]: Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x10020000
Jan 1 01:04:56 pppd[85]: Couldn't get channel number: Transport endpoint is not connected
Jan 1 01:04:56 pppd[85]: Doing disconnect
Jan 1 01:05:26 pppd[85]: Sending PADI
Don't worry about getting back to it, I know every setting straight out of my head.
Looks like pppoe discovery does not work, this could be a MAC filter on the ISP side. Can you check on that?
Does your speedtouch allows mac cloning? If so, try to put IP address of your PC or wl500g and check, that it works in ppp mode. If it does not, that probably MAC address is locked.
My ISP doesn't block mac adresses...
I've had other routers connected to it without problems.
Other modems etc.
Mac adress is no problem @ kpn/wanadoo
Ok, if you've windows xp, then you could try to establish pppoe connection from it first...
Have you rebooted speedtouch after switching to bridge mode?
I'm going to try now one more time with rebooting everything...
wish me luck.
Nope I still get the same error in system log.
DHCP spoof or SIP spoof a solution if PPPoE doesn't work?
how do I establish a dial in PPPoE in windows xp?Originally Posted by Oleg
I've no idea what is SIP spoof.
Yes, try dhcp spoof. You need to setup wl500g WAN port for automatic IP, leaving other settings as is.
As for speedtouch - which options are offered for DHCP spoof?
Start New Connection Wizard, Select Connect to the Internet, then Set up my connection manually, then Connect using a broadband connection that requires user name and password (PPPoE), then type the ISP name (the name for the connection, not very important), then user name and password, then finish.Originally Posted by Lightah
You may also need to assign static IP address to your PC.
SIP_spoof is to get your external ip on your network card (or router).
But dhcp_spoof is almost the same.
phonebook
VPI: 8
VCI: 48
Type: ppp
PPP settings
user/pass
NAT disabled
DHCP settings
DHCP server enabled
advanced
adresses: 10.0.0.1 to 10.255.255.254
subnetmask: 255.0.0.0
def. gateway: auto
lease time: 7200
DNS server: auto
DHCP spoofing
DNS settings
DNS server active
Domain name: xxxxx
ASUS WL-500g
WAN automatic ip
Read this links:
BRIDGE mode -
http://www.petri.co.il/configure_alc...ent_bridge.htm
SPOOF mode -
http://www.petri.co.il/configure_alc...p_spoofing.htm
try configuring like described
Lightah: Check this out: http://wl500g.info/showpost.php?p=8432&postcount=22 Perhaps it helps..
According to this post it uses pptp. So, you need to configure speedtouch to bridge mode, while wl500g should use pptp.Originally Posted by Styno
Ok tried DHCP_spoof:
I get external ip on router but I don't have internet on my computers.
log with 192 range: http://home.wanadoo.nl/vsteenis_adsl/log192.txt
log with 10 range: http://home.wanadoo.nl/vsteenis_adsl/log10.txt
No internet?
