Results 31 to 45 of 54
Thread: Firmware v1.9.2.7 CR1 [Oleg]
    Quote Originally Posted by cZip
    Thank you for your answer. I have got firmware 1.7.5.6.-5 - it works well as a client.
    But I don´t have any Bandwidth Management and that’s why I would like to firmware 1.9.2.7
    Will be the client mod implement into the firmware 1.9.2.7?
    If yes, when..? approximately...?
    I've no idea. It's like a puzzle.
    Aug 2004
    Hamburg / Germany
    I tried to compile your firmware but it cannot find the 'addver' command. This is neither available in the custom firmware tree nor on my system (Debian GNU/Linux testing).
    Could you please tell me what 'addver' is?
    Thank you,
    Werner
    This program should be in the ASUS GPL sources. Is it missing?
    I'm attaching it just in case.
    Nov 2003
    Norway
    Firmware v.1.9.2.7 CR1 [Oleg]
    I have got a problem with my wireless connection.
    It gets disconnected every short while.
    The wireless computer got a static ip.
    This is som of the output from the syslog.
    Dec 22 17:00:21 udhcpc[127]: Sending renew...
    Dec 22 17:00:21 udhcpc[127]: Lease of 10.0.0.2 obtained, lease time 7200
    Dec 22 17:00:22 dnsmasq[71]: read /etc/hosts - 5 addresses
    Dec 22 17:00:22 dnsmasq[71]: read /etc/ethers - 4 addresses
    Dec 22 17:00:22 dnsmasq[71]: reading /tmp/resolv.conf
    Dec 22 17:00:22 dnsmasq[71]: using nameserver 10.0.0.138#53
    Dec 22 17:00:22 dhcp client: renew IP : 10.0.0.2 from 10.0.0.138
    Dec 22 16:05:28 dnsmasq[71]: DHCPREQUEST(br0) 192.168.1.5 xx:xx:xx:xx:xx:xx
    Dec 22 16:05:28 dnsmasq[71]: DHCPACK(br0) 192.168.1.5 xx:xx:xx:xx:xx:xx blade
    Dec 22 16:05:38 dnsmasq[71]: DHCPREQUEST(br0) 192.168.1.5 xx:xx:xx:xx:xx:xx
    Dec 22 16:05:38 dnsmasq[71]: DHCPACK(br0) 192.168.1.5 xx:xx:xx:xx:xx:xx blade
    Dec 22 16:05:41 dnsmasq[71]: DHCPREQUEST(br0) 192.168.1.5 xx:xx:xx:xx:xx:xx
    Dec 22 16:06:13 dnsmasq[71]: DHCPDISCOVER(br0) 192.168.1.5 xx:xx:xx:xx:xx:xx
    Dec 22 16:06:13 dnsmasq[71]: DHCPOFFER(br0) 192.168.1.5 xx:xx:xx:xx:xx:xx
    This keeps repeating it selfs.
    Any clues what's wrong ?
    Quote Originally Posted by Phantome
    Nothing wrong with wl500g. It just issues IP address in request for it.
    Probably windows wireless problems, wpa or something...
    Nov 2003
    Norway
    Sorry about that, something is disturbing the signal, changed the channel and everything is ok for now. Even the speed changed from 150kbyte/s to 2500kbyte/s
    Aug 2004
    Hamburg / Germany
    Thank you very much! It is in the 1817 GPL sources, but it is missing in 1927.
    Werner
    username/password
    Hello
    I now that this is a silly question, but I've just updated from ASUS 1.9.2.7 to
    and which username and password should I use to telnet the router ?
    thanx
    same as used by webinterface.
    again
    the webinterface as no user... only password
    Apr 2004
    Netherlands
    Quote Originally Posted by cardoso
    That means that you didn't upgrade to 1.9.2.7 properly.
    Push the reset button on the back of the router for at least 10 seconds while power is applied. That resets your router to its default factory settings. After that you'll have logon with default username/password and reconfigure your router. Then your router is correctly upgraded.
    You can login to telnet with the same username/password as the webinterface.
    I'm also suggesting to reset to defaults. Empty user name indicates, that you've upgraded from older (pre 1.8.x.x firmware) and has not reseted to defaults. This could cause problems, due to the fact, that firmware is seriously changed and some of the options supported earlier could cause problems with new firmware. BTW, it's still possible to telnet to your router - firmware defaults to root if username is empty.
    Oct 2004
    Portugal
    Lightbulb
    Hello people!!
    Add Portugal to the Time Zone!
    Portugal are like (GMT) England !
    thks for this forum
    Merry Christmas and good programing!
    Home Page
    Marco Sousa from PORTUGAL
    Sep 2004
    Russia, Saint-Petersburg
    on 1.9.2.7-1 (2004-12-17) not work WPA in WDS
    on 1.8.1.7-3 (2004-11-15) work fine
    Quote Originally Posted by Viper_Rus
    You need to specify WPA mode, which you are trying to use. There was already reported, that TKIP+AES does not work. Unfortunatly, this code could not be fixed, due to the fact that it's binary only, so I'm suggesting you to use 1.8.1.7-3 or 1.8.1.9.
  1. Firmware v1.9.2.7 CR2 [Oleg]
    Last Post: 11-01-2005, 18:22
  2. Firmware v1.7.5.9 CR2 [Oleg]
    Last Post: 06-10-2004, 08:12
  3. Firmware v1.7.5.6 CR2 [Oleg]
    Last Post: 05-05-2004, 03:10
    Last Post: 03-05-2004, 11:13
    Last Post: 07-04-2004, 17:22
