When DNS go down in the log was be:
Mar 10 19:10:31 syslog: failed to bind listening socket: Address already in use
Mar 10 19:10:31 syslog: FAILED to start up
Mar 10 19:10:36 syslog: failed to bind listening socket: Address already in use
Mar 10 19:10:36 syslog: FAILED to start up
Mar 10 19:10:41 dnsmasq[69]: nameserver 83.240.%.%%% refused to do a recursive query
Pls anybody where i do mistake? i don't do anything ... and DNS deamon go down :/.
btw doeas anybody know, why when i clicked on some target in the asus menu, firefox wrote me:
Connection Interrupted
The connection to the server was reset while the page was loading.
The network link was interrupted while negotiating a connection. Please try again.
in the IE is very similar ...
to raas:
Ok, from the image you've posted I 'read' that your asus has a correct gateway.. it can lookup google in putty. (so it get's outside of your network).
Now, on your pc you cannot get outside your network because it tries to resolve an ip-adres from the name on the asus.. As the asus doesn't have a dns service it cannot resolve the ip for the address you requested.
right!
ve is right, I think you have a problem with the ip-settings on your computer, not your asus (which is able to get outside).
at the top - is the problem with router ...
How do you have setup your asus? (Access point only, or router?)
just basic config - Home Gateway
