Hi there,
I have a USB sound card that is not working properly with my wl500g. When I send music to the router all I get is a continuous single pitched tone coming from my speakers connected to the sound card.
I have installed latest firmware and EsounD Daemon etc as per instructions in other threads. Also the usb sound card works when not played through the router.
How do I check the chipset in my USB sound card using Putty (Telnet)?
Is there any way I find out if this chipset is compatible? The card (3D sound) is on the a compatibility on another thread but I wouldn't be surprised if they changed the chipset.
Does anyone know a workaround for this? I imagine that it is possible, I just don't know what I have to install / change.
Any suggestions, diagnostics etc would be really appreciated.
Thanks
