Originally Posted by
wengi
Würdest Du uns die korrigierten Versionen mal zu Verfügung stellen?
wengi
Klar, hier der Code:
sluginfo.cgi
# $Id$
if [ "${BASH_CHECK}" != 1 -a -f /opt/bin/bash ]
then
BASH_CHECK=1; export BASH_CHECK
/opt/bin/bash $0
exit $$
showcommand() {
NAME=$1
shift
PROG=$1
shift
if [ -f ${PROG} ]
then
echo "<h3>${NAME}</h3>"
echo "<pre>"
${PROG} "$@"
echo "</pre>"
showfile() {
FILE=$1;
BASE=${FILE##*/}
shift
if [ -f "${FILE}" ]
then
showcommand "${BASE}" "/bin/cat" "${FILE}"
runprog() {
PROG=$1;
BASE=${PROG##*/}
shift
showcommand "${BASE}" "${PROG}" "$@"
cd /tmp
cat << EOF
Content-type: text/html
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta name="generator" content="sh" />
<meta name="version" content="\$Id$" />
<title>sluginfo</title>
</head>
<body>
<h1>Slug info</h1>
<ol>
<li><a href="#sys">System</a></li>
<li><a href="#soft">Installed software</a></li>
<li><a href="#disk">Disks</a></li>
<li><a href="#network">Network</a></li>
<li><a href="#samba">samba</a></li>
</ol>
EOF
echo '<a id="sys" /><h2>System</h2>'
showfile /etc/motd
runprog /opt/bin/uname -a
showfile /proc/cpuinfo
showfile /proc/meminfo
showfile /proc/bus/usb/devices
runprog /sbin/lsmod
runprog /bin/ps
runprog /bin/dmesg
echo '<a id="soft" /><h2>Installed software</h2>'
runprog /opt/bin/ipkg list_installed
echo '<a id="disk" /><h2>Disks</h2>'
showfile /proc/mounts
runprog /bin/df
showcommand "sda" /sbin/fdisk -l /dev/sda
showcommand "sdb" /sbin/fdisk -l /dev/sdb
showcommand "sdc" /sbin/fdisk -l /dev/sdc
showcommand "sdd" /sbin/fdisk -l /dev/sdd
echo '<a id="network" /><h2>Network</h2>'
runprog /sbin/ifconfig
runprog /sbin/route
showfile /etc/resolv.conf
runprog /opt/bin/host ipkg.nslu2-linux.org
runprog /bin/ping -c 2 ipkg.nslu2-linux.org
runprog /usr/bin/wget http://ipkg.nslu2-linux.org
echo '<a id="samba" /><h2>Samba</h2>'
showfile /opt/etc/samba/smb.conf
showfile /etc/samba/user_smb.conf
showfile /opt/var/log/samba/log.smbd
showfile /opt/var/log/samba/log.nmbd
echo '</body>'
echo '</html>'
package.cgi
# $Id$
then
/opt/bin/bash $0
exit $$
PROG=${0##*/}
TMPFILE=/tmp/${PROG}.$$
# HTML Header
cat << EOF
<head>
<meta name="generator" content="CGI:shell" />
<title>ipkg web</title>
<style type="text/css">
h1, h2 {
font-family: Arial, Helvetica, sans-serif;
color: #004;
table {
border-top: 1px solid #eee;
border-right: 1px solid #eee;
width: 100%;
th, td {
padding: 2px 4px;
border-left: 1px solid #eee;
border-bottom: 1px solid #eee;
table a {
background: #ddd;
color: #004;
text-decoration: none;
margin: 1px;
padding: 2px 4px;
font-size: 75%;
table a.ins {
background: #dfd;
border-left: 1px solid #cec;
border-bottom: 1px solid #cec;
table a.upd {
background: #ddf;
border-left: 1px solid #cce;
border-bottom: 1px solid #cce;
table a.del {
background: #fdd;
border-left: 1px solid #ecc;
border-bottom: 1px solid #ecc;
</style>
</head>
<body>
<h1>The ipkg web frontend</h1>
<form methode="GET">
<table>
<tr>
<td>Sync packages</td>
<td>
<input type="radio" name="updatedb" value="n" checked>no</input>
<input type="radio" name="updatedb" value="y">yes</input>
</td>
</tr>
<tr>
<td>Type:</td>
<td>
<select name="typefilter">
<option selected value="none">NONE</option>
<option value="update">Updates</option>
<option value="installed">Installed</option>
<option value="not">Not installed</option>
</select>
</td>
</tr>
<tr>
<td>Filter</td>
<td><input type="text" name="namefilter"></td>
</tr>
</table>
<input type="submit" name="submit"> <input type="reset">
</form>
EOF
NAMEFILTER=.
# QUERY_STRING=task=install&package=atk
IFS='&'
set -- ${QUERY_STRING}
for i in $@
do
case ${i%%=*} in
task)
TASK="${i#*=}"
package)
PACKAGE="${i#*=}"
updatedb)
UPDATEDB="${i#*=}"
typefilter)
TYPEFILTER="${i#*=}"
namefilter)
if [ "${i#*=}" ]
then
NAMEFILTER="${i#*=}"
submit)
SUBMIT="${i#*=}"
echo "<b>ERROR</b>: Unkown option '${i}'"
echo '</body>'
echo '</html>'
exit 1
esac
done
if [ ! -f /opt/bin/bash ]
then
echo "<h2>Please install bash</h2>"
echo "<p>I recomend to install bash because this cgi script will"
echo "run more than two times faster with bash</p>"
if [ "${UPDATEDB}" = y ]
then
echo "<h2>Upgrading package list</h2>"
echo '<pre>'
/opt/bin/ipkg update </dev/null
echo '</pre>'
if [ "${TASK}" = install ]
then
echo "<h2>Install ${PACKAGE}</h2>"
echo '<pre>'
/opt/bin/ipkg -force-defaults install "${PACKAGE}" </dev/null
echo '</pre>'
if [ "${TASK}" = update ]
then
echo "<h2>Update ${PACKAGE}</h2>"
echo '<pre>'
/opt/bin/ipkg -force-defaults upgrade "${PACKAGE}" </dev/null
echo '</pre>'
if [ "${TASK}" = delete ]
then
echo "<h2>Delete ${PACKAGE}</h2>"
echo '<pre>'
/opt/bin/ipkg -force-defaults remove "${PACKAGE}" </dev/null
echo '</pre>'
if [ "${SUBMIT}" != "" ]
then
echo '<h2>Package list</h2>'
/opt/bin/ipkg list_installed >${TMPFILE}
trap "[ -f ${TMPFILE} ] && rm ${TMPFILE}" 0
echo '<table border="1" cellpadding="0" cellspacing="0">'
echo '<tr><th>task</th><th>Package</th><th>I-Ver</th><th>P-Ver</th><th>Comment</th><th>Delete</th></tr>'
/opt/bin/ipkg list | grep -- "${NAMEFILTER}" | while read line
do
INSTALLED=""
NAME=${line%% - *}
line=${line#* - }
VERSION=${line%% - *}
VERSION=${VERSION% -}
COMMENT=${line#* - }
if [ "$COMMENT" = "$line" ]
then
COMMENT=' '
instline=$(grep "^${NAME} - " ${TMPFILE})
if [ "${instline}" != "" ]
then
INSTALLED=Y
DEL="<a href='$PROG?task=delete&package=${NAME}' class='del'>delete</a>"
instline=${instline#* - }
IVER=${instline%% - *}
if [ "${IVER}" = "${VERSION}" ]
then
TASK=' '
TASK="<a href='$PROG?task=update&package=${NAME}' class='upd'>update</a>"
DEL=' '
IVER=' '
TASK="<a href='$PROG?task=install&package=${NAME}' class='ins'>install</a>"
SHOW=0
case "${TYPEFILTER}" in
none)
SHOW=1
update)
[ "${INSTALLED}" ] && [ "${IVER}" != "${VERSION}" ] && SHOW=1
installed)
[ "${INSTALLED}" ] && SHOW=1
not)
[ -z "${INSTALLED}" ] && SHOW=1
echo "<b>ERROR</b>: Unkown typefilter '${TYPEFILTER}'"
echo '</body>'
echo '</html>'
exit 1
esac
[ "${SHOW}" = 1 ] && echo "<tr><td>${TASK}</td><td>${NAME}</td><td>${IVER}</td><td>${VERSION}</td><td>${COMMENT}</td><td>${DEL}</td></tr>"
done
echo '</table>'
echo '</body>'
echo '</html>'
Gruß FastJack
