Must please user defined in the ADOS for downloading the same as user in the asus system? I have in the asus system only one user admin. And in the ADOS program have i different user martin.
I have write permition 777 to the directory cron.1min and to the download directory.
Hi Everybody,
could anybody help me why I receive this error message above. For more details see attached file.
I can eliminate error message, but downloading still not work.
Should I open a special port on firewall?
I do not understand: log files of ADOS (in _log directory) are empty, I cannot find any error message.
I'm getting this during setup: Fatal error: Class 'PDO' not found in /opt/share/www/ados/install/index.php on line 457
edit: nevermind, solved
I had the same problem. Look to this post http://wl500g.info/showpost.php?p=112888&postcount=1232 (mainly to the php.ini extension setup part). Probably during php upgrade the php.ini file was rewritten.
When I want install ADOS I get this error:
Fatal error: This system requires PHP 5.1.3 or over. Your PHP version is.
I have installed PHP 5.2.10.
When I remove lines 139-145 from install/index.php I have only a white page.
I wanted force installation using link with parameters
but it's the same storyCode:http://192.168.1.1:81/ados/install/?db_engine=sqlite3&execute=yes&lang=en&step=2
Any ideas?
I "solved" this problem
In install/index.php in line 141 I changed "<" to ">"
before
afterPHP Code:
if( strcmp( $phpver[1], "5.1.3" ) < 0 )
PHP Code:
if( strcmp( $phpver[1], "5.1.3" ) > 0 )
My internet provider allow me downloading only between 00:00 and 6:00 hours. Any solution for this problem???? :/
Thanx....
(sorry for my bad english)
WL-500gP - oleg 1.9.2.7-d-r740. IPKG,SAMBA,FTP,PHP,ADOS...
+ WD HDD 250GB SATA
Hi folks,
Ive just installed ADOS (headstart package actually). I want to use it for downloading from rapidshare in happy hours.
If I start download manually it seems to be working fine but I need help with setting up schedule. I dont really get those options or they doesnt work in my setup
Ive used "Schedule properities for users" -> Alternate restrictions -> admin (my username) -> allow -> day -> time from : to. But it doesnt start download, actually if I leave this active and try to start download manually it creates an error (doesnt start). Should this work the way I thought or am I missing something? Can you please point me to some solution.
Thx for help and thx for this peace of software
Hello people.
I Installed last day ADOS Downloader in another router with TOMATO 1.27 USB.
But in this new install, my ADOS show me wrong size of file in downloading. See the picture with problem. The file has 200MB of size but ADOS show me 51KB. Help me please.
Hi, Im using ADOS 139 installed with Headstart package. Im using it for downloading files from rapidshare at night. But from monday (im not sure) it looks like it stopped working.
It doesnt show filesize (0 KB). And if I start download it logs an error (ECD_012,File's download is impossible,Can't connect to FTP server.,Can't establish connection to the remote server.).
But if I try to download anything else it seems to be working. Any tips where to start searching a problem?
