i have the same problem
Have a EXT3 partition, but cant mount.
Disk /dev/discs/disc0/disc: 250.0 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders
/dev/discs/disc0/part1 * 1 9 72261 82 Linux swap
/dev/discs/disc0/part2 10 30401 244123708+ 83 Linux
Swap is OK, but cant mount part2
[admin@(none) root]$ mount /dev/discs/disc0/part2 /opt/
mount: Mounting /dev/discs/disc0/part2 on /opt/ failed: Invalid argument
The strangest thing is that ive flashed with OpenWRT, x-wrt, it it mount it correctly.
And before instaled x-Wrt, ive had oleg firmware and I had the same problem ...
Is it possible that the mount command is outdated ?
How can i upgrade the mount command ?
Please help
