Nice looking, but I'm getting 404 error after I have replaced original transmission cgi file.
transmission v1.10 I think
This transmission.cgi comes with some progressbars and some general layout changes.
In my oppinion its more readable.
Its for transmission 1.05+ latest i think
A screenie is in attachments.
Get the 404 error, too. Checked the permissions, they should be fine. Could you please upload your running transmission.cgi again? I'm using the latest transmission (1.05). Thanks, a.
Here is the 404 also showing, I checked the permissions, must be an error in de cgi script itself. Also tried another webserver, got a Internal Server Error 500 (lighttpd).
Did anyone solve the 404 error problem described previously? If yes, please reply.
Can anyone tell me where to place the transmission.cgi file. Which folder?
Thank you!
Found lot of control M after each line like ^M.
try remove all ^M or use my attach file
You can create a version with the added feature FORCE-REMOVE? Thx advance.
Maybe i will, but force remove is not something usefull i think.
The next one version will use the network speed graphs of openwrt when u hover over a torrent.
And another speed graph with 5 secs refresh for total speed on top section.
I will also seperate the log view and the graph...
Just gimme some time im lazy lately
Spring is here we got 22 C, sun is shining.
P.S read my other post. For increasing the sensitivity of the wl-500gp to almost 4 times.
On the NSLU I had to replace "==" with "=" in comparisons. Otherwise this transmission.cgi works great.
Klaus
can you poat a new transmission.cgi please?
your zip file is corrupt.
how about nem transmissions version?
mh one simple question. what is the directory i have to put the file in ?!
many thanks
Nice. I was pretty much able to use the transmission.cgi right away as is. I just had to make sure that I chmodded it to 0755 since it didn't have execute permission right away.
Hi Rampage,
I am always looking for a clearer presentation of these details - my background is in design / CSS and I have designed a different version of the transmission.cgi previously -
http://wl500g.info/showthread.php?t=9441
I am now working on a ExtJS version - Its great for displaying / sorting Table based data.
Anyhooo, I am always interested in giving something back so if you need any design / graphics / JS help let me know
Velcrow
