Results 106 to 114 of 114
Thread: [HowTo] Upgrading RAM to 128 MB (WL-500gP, WL-500W and WL-700gE)
Threaded View
    Thumbs up [HowTo] Upgrading RAM to 128 MB (WL-500gP, WL-500W and WL-700gE)
    As most of you asked to publish this I've finally finished this guide...
    The goal of this mod is to increase built in memory up to 128MB to be able run more services on the router without the expense of accessing slow swap, etc. Beware, that this mod requiresvery strong soldering skills! And usual disclaimer: do it on your own risk to brick the router completely.
    What do you need to perform a mod?
    • Good soldering skills at first (the board is Pb Free!) and equipment
    • One 22Ohm (33 Ohm is also ok) resistor to enable A12 address line (not needed for WL-700gE, as it has it already)
    • Two TSOP packaged DDR333 or DDR400 SDRAM chips organized as 32Mx16
    The easiest way to get chips (and perhaps cheap) is to remove them from the PC2700/PC3200 DIMM or SO-DIMM: at the moment we've checked the following parts:
    • Hynix HYMD532646CP6J-D43 PC3200 DIMM: it has Hynix HY5DU121622CTP-D43 chips
    • Samsung M470L6524BT0-CB3 PC2700 SO-DIMM: it has Samsung K4H511638B-TCB3 chips
    • Samsung M470L6524DU0-CB3 PC2700 SO-DIMM: it has Samsung K4H511638D-UCB3 chips
    • Transcend TS32MSD64V3M PC2700 SO-DIMM: it has Elpida D5116AFTA-5B-E chips
    Please note, that Hynix is least preferred. Also, avoid using Infineon chips.
    The problem is that PCB is not ideally traced and has some noise UDQS line coming to U4, resulting in memory errors (see below).
    Doing it
    • Start with flashing latest firmware which is known to support 128MB of RAM. My firmware starting with 1.9.2.7-7g are known to work ok, as they've required patches. But I recomend flashing latest anyway.
    • Telnet/ssh to your router and type
      nvram set sdram_init=0x000b
      nvram set sdram_config=0x0032
      nvram commit
      halt
      This would turn U4 chip off and prevent my firmware from auto enabling it. The router would be halted too, so you could safely remove power from it.
    • Disassemble your router now
    • Remove shieldings from the back of PCB (it's self-adhesive) and from the top
    • Solder 22 Ohm resistor on the free pads labeled R43. Skip this step if you have WL-700gE. Check image below:
    • Replace original U3 chip with your new memory chip. Be sure to remove PB free solder completely from the PCB pads before soldering your new chip!
    • Power your device on. It should now start normally and report 32MB of RAM (use free to check this).
      If it does not: check your soldering work again. Don't even think of pin-9 trick or whatever! FYI: all routers starts
      after replacing U3 chip.
    • Test RAM using memtest (see below). If it fails, then double check your soldering and try again.
    • Given, that your router works with U3 replaced, continue with replacing U4, now it should look like this:
    • Replaced? Ok, turn it once again and check, that it still work. If it does not check U4 soldering: perhaps you short-cuted something... Now type the following in the telnet/ssh to enable U4 and 128MB of RAM:
      nvram set sdram_init=0x0011
      nvram set sdram_config=0x0062
      nvram commit
      reboot
    • It should now reboot. If it does, than you're lucky man (Elpida and Samsung chips are reported to be very lucky)
      if it does not (Hynix never boots this way) then proceed this way: check your U4 soldering work once again. Try
      to power on your device. If everything looks good then you've to try adding 3-7 pF capacitor between U4 pin 51
      (UDQS) and ground:
    • If it does not boot - check your soldering work once again. If it still does not work - I've no idea then. Don't blame me, this is ASUS PCB fault.
    • Test RAM using memtest (see below). Leave it running for a long time to be absolutely sure it works fine. If it does not, then perhaps you should solder a capacitor as described above. Once it's error free, you could tell
      memory controller to re-tune some internal timings:
      nvram set sdram_ncdl=0
      nvram commit
      reboot
    Activating 128MB with known good memory
    You need this everytime you perform a reset to defaults...
    nvram commit
    reboot
    Testing device memory
    Type these lines to start testing:
    cd /tmp
    wget http://oleg.wl500g.info/bin/memtest
    chmod +x memtest
    ./memtest 16m
    Note, that memtest at most could only pin half of device memory. Replace 16m with 64m for 128MB of RAM.
    Pictures
    WL-700gE with Samsung chips and 8MB flash
    WL-500gP with Samsung and Hynix chips at the same time
    Samsung chip does not need caps on this PCB...
  1. Hardware Encryption on WL-500gP / WL-500gD / WL-700gE
    By staticroute in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 07-02-2013, 12:53
  2. [HowTo] Setup MediaTomb (mediaserver) on WL-500gP and WL-500W
    By rathalian in forum WL-500gP Tutorials
    Last Post: 20-12-2012, 21:14
  3. [HowTo] Get a HeadStart on a WL-500gP
    By raas in forum WL-500gP Tutorials
    Last Post: 11-01-2012, 08:19
  4. WL-500g Premium died After Upgrading Firmware
    By acidbrain in forum WL-500gP Firmware Discussion
    Last Post: 17-06-2011, 07:59
  5. HowTo: Use Palm as 500gP LCD
    By Tamadite in forum WL-500gP Tutorials
    Last Post: 08-02-2009, 21:18
