Results 16 to 30 of 59
Thread: [USB] External Storage Cases / External Harddrives
    Sep 2004
    Netherlands
    2.5" USB HD
    Tested: Working
    Model: WL-500g
    Firmware: 1.7.5.9-5 (Oleg)
    Device: HD260
    Brandname: MyCom
    Brandtype: 2,5" Hard Disk Casing
    USB Interface: USB 2.0 High Speed (480Mbit) compliant
    URL To product: http://silverapp1.mycom.nl/MyCom/Sto...&productType=1
    Device Used during test:
    Brandname: IBM
    Brandtype: Travelstar 20GB (4200RPM, 5V-1A)
    Brandmodel: IC25N020ATDA04-0
    partition: 1 x 20 gb fat32
    2'5 external disk TRANSCEND
    Tested: Working
    Model: WL-500g
    Firmware:
    Device:
    Brandname: TRANSCEND
    URL To product: http://www.transcendusa.com/DLCenter...reJet25HDD.pdf
    URL To manufacturer: http://www.transcendusa.com
    Brandname:
    Brandtype:
    Brandmodel:
    Jan 2005
    Rantigny (France)
    Archos Gmini 220
    Tested: Working
    Model: WL-500g
    Firmware: 1.9.2.7-3b
    Device: Gmini 220
    Brandname: ARCHOS
    Brandtype: Hard Drive Multimedia JukeBox
    URL To product: http://www.archos.com/products/prw_500452.html
    URL To manufacturer: http://www.archos.com
    Brandname: Hitachi
    Brandtype: 1.8" Hard Drive
    Brandmodel: Travelstar C4K20
    Welland ME740U2 3,5"
    Tested: Working
    Model: WL-500gx
    Firmware: 1.9.2.7-3c
    Device:
    Brandname: Welland
    Brandtype: ME740U2 3,5" no fan
    HD Size: 3.5"
    URL To manufacturer: http://www.welland.com.tw/
    URL To product: http://www.welland.com.tw/html/case/x40.html
    Brandname: Western Digital
    Brandtype:
    Brandmodel: 30BB 7200 RPM ATA/100 IDE Hard Drive
    partition: vfat 30GB
    Remark: The enclosure has also IEEE1394, so it's probably ME-740U2F, however it was sold to me as ME740U2 (www.czechcompuer.cz).
    Tested: Working
    Model: WL-500g
    Firmware: 1.9.2.7
    Device: CrossFire 160
    Brandname: SMARTDISK
    Brandtype: External Hard Drive
    Interface: USB 2.0 & FireWire (IEEE-1394)
    Brandname: Samsung (OEM 7200rpm 3.5 inch ATA disk)
    Brandtype: ?????
    Brandmodel: ?????
    partition: 1 fat32
    Tested: Working
    Model: WL-500g
    Firmware: All
    Device:
    Brandname: LaCie
    Brandtype: LaCie Mobile Hard Drive, Design by F.A. Porsche 200GB, USB 2.0
    HD Size: 3.5"
    URL To manufacturer: http://www.lacie.com
    URL To product: http://www.lacie.com/products/product.htm?pid=10554 (100Gb version, I tested the 200Gb version)
    Tested: Working
    Model: WL-500g
    Firmware: All
    Device: Hard Drive, Design by F.A. Porsche 200GB
    Brandname: LaCie
    Brandtype: External USB Hard Drive
    Interface: USB 2.0
    Advance BX338 Work
    Tested: Working
    Model: WL-500g
    Firmware: 1.9.2.7
    Device: Advance BX338
    Brandname: Advance
    Interface: USB 2.0
    Tested: NON-WORKING
    Model: WL-500gx
    Hardware: ?
    Firmware: Stock Asus 1.8.2.1
    Device:
    Brandname: Creative
    Brandtype: Muvo2 4GB
    URL To manufacturer: http://www.creative.com/
    URL To product: Creative's Muvo2 product page
    NB This webpage states that Kernels 2.4.26 and up have a fix (Asus firmware seems to be 2.4.20 plus USB upgrade to 2.4.25).
    Apr 2005
    Amersfoort, The Netherlands
    Tested: Working
    Model: WL-500gx
    Firmware: 1.9.2.7-5a
    Device:
    Brandname: unknown (maybe Techsolo?)
    Brandtype: USB 2.0 HDD Case 3.5" C-31
    HD Size: 3.5"
    URL To product: http://www.systron.com
    (Note: Based on chip Cypress CY7C68300A-56PVC)
    Brandname: Quantum
    Brandtype:
    Brandmodel: Fireball TM 2550A
    partition: Fat32 2.5GB
    (Note: quite old 3.5" IDE Hard Drive, but why a high speed one if router doesn't eat it anyway
    Tested: WORKING
    Model: WL-500gx
    Firmware: 1.9.5.7a
    Device:
    Brandname: Transcend
    Brandtype: StoreJet 1.8"
    URL To product: http://www.transcendusa.com/Products...ngNo=0&ModNo=9
    Brandmodel: TS40GSJ18
    partition: 1x40Gb NTFS 5.0
    Thumbs down DIGITUS USB 2.0 3,5" HardDisk-case with IDE HD
    Tested: Not Working (dies after a while)
    Model: WL-500g Deluxe (WL-500gx)
    Device: DIGITUS USB 2.0 3,5" HardDisk-case with Seagte HD installed
    based on the Genesys-Chip 'GL811E" (See http://www.genesyslogic.com/econtent...stcidx=3&SN=34 for details)
    Brandname: DIGITUS (but seen also with other labels like http://www.materiel.net/buffer/11668.jpg see entry of user 'smarechal') or entry as of "27-06-2005, 11:16" by user "oleo"
    HD Size: 3.5"
    URL To manufacturer: http://www.digitus.de/
    URL To product: no longer existing, product no longer available
    Brandname: Seagate
    Brandtype: ST3200822A
    Brandmodel: Barracuda 7200.7
    partition: see below log entries
    usb.c: registered new driver usb-storage
    Jan 1 00:00:07 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
    Jan 1 00:00:07 kernel: Vendor: ST320082 Model: 2A Rev: 0811
    Jan 1 00:00:07 kernel: Type: Direct-Access ANSI SCSI revision: 02
    Jan 1 00:00:07 kernel: Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
    Jan 1 00:00:07 kernel: SCSI device sda: 390721968 512-byte hdwr sectors (200050 MB)
    Jan 1 00:00:07 kernel: Partition check:
    Jan 1 00:00:08 kernel: p1 p2
    Jan 1 00:00:08 kernel: USB Mass Storage support registered.
    Jan 1 00:00:08 kernel: kjournald starting. Commit interval 5 seconds
    Jan 1 00:00:08 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,1), internal journal
    Jan 1 00:00:08 kernel: EXT3-fs: recovery complete.
    Jan 1 00:00:08 kernel: EXT3-fs: mounted filesystem with ordered data mode.
    Jan 1 00:00:08 kernel: Adding Swap: 524276k swap-space (priority -1)
    after a while during constand HDD-traffic! (looks like some sort of buffer overflow) the red HDD-LED remains constantly on but access to the drive is no longer possible. Others seems to have had the same problem with that pice (of sh..). removing power and applying power again solves the problem, but Windooz does not like such procedures.
    The box has the very same problem if connected directly to the PC rather to the WL500gx. Thus seems not to be a problem caused by the ASUS box.
    Freecom FHD2-Pro
    Device:
    Brandname: Freecom
    Brandtype: FHD2-Pro
    URL To manufacturer: http://www.freecom.com/
    It is USB powered (no need for a power adapter) on the WL500-gx.
    It is VERY quiet.
    Jun 2005
    Slovenia
    QTEC 3.5" Harddisk Case USB 2.0 Tested: NOT Working QTEC 3.5" Harddisk Case USB 2.0
    Tested: NOT Working
    Firmware: 1.9.2.7-6a
    HD Size: 3.5"
    URL To manufacturer: http://www.qtec.info
    URL To product: http://www.qtec.info/products/produc...=14214&specs=1
    After several hours of giFT processing USB connection dies with the following klog:
    usb_control/bulk_msg: timeout
    usb-storage: host_reset() requested but not implemented
    scsi: device set offline - command error recover failed: host 0 channel 0 id 0 l
    un 0
    SCSI disk error : host 0 channel 0 id 0 lun 0 return code = 6050000
     I/O error: dev 08:03, sector 7828824
     I/O error: dev 08:03, sector 7828832
     I/O error: dev 08:03, sector 7828888
     I/O error: dev 08:03, sector 7828952
     I/O error: dev 08:03, sector 7829016
     I/O error: dev 08:03, sector 7829080
     I/O error: dev 08:03, sector 7829144
     I/O error: dev 08:03, sector 7829208
     I/O error: dev 08:03, sector 7829272
     I/O error: dev 08:03, sector 7829336
     I/O error: dev 08:03, sector 7829400
     I/O error: dev 08:03, sector 7829464
     I/O error: dev 08:03, sector 7829512
     I/O error: dev 08:03, sector 6143600
     I/O error: dev 08:03, sector 6819944
     I/O error: dev 08:03, sector 30776
     I/O error: dev 08:03, sector 30840
     I/O error: dev 08:03, sector 30880
     I/O error: dev 08:03, sector 30888
     I/O error: dev 08:03, sector 30952
     I/O error: dev 08:03, sector 30960
     I/O error: dev ...
    Tried this on two hard disks with same results.
    Two ext3 partitions with 128MB swap. After hard reset it works again until it dies.
    Mar 2005
    The Netherlands
    Thumbs up
    Tested: WORKING
    Model: WL-500g
    Hardware: 1.0
    Firmware: 1.9.1.7 and 1.9.4.0 using now 1.9.2.7-6b by Oleg (all FW's worked)
    Box scan by me no other img's
    Device:
    Brandname: Sum E Vision
    Brandtype: 3.5" Aluminium Mobile Enclosure
    USB Interface: USB 2.0 High Speed (480Mbit) and USB 1.1 (12Mbit)
    USB chip: Genesys GL811
    URL To manufacturer: No URL
    URL To product: No URL Google Search
    HDD used:
    Brandname: Maxtor
    Brandtype: 160GB 8MB U133 7200rpm
    Brandmodel: DiamondMax Plus 9
    Partition: 160GB FAT32 (149GB real size)
    URL To manufacturer: http://www.maxtor.com
    URL To product: DiamondMax Plus 9
    This combo is tested with the Sitecom Micro USB Hub and Canon PIXMA IP4000.
    Test was Uploading from WAN side and printing, downloading from WAN side and printing and uploading/downloading with 2 FTP users and printing.
    There was no problem at all, this print test is only tested on 1.9.2.7-6b FW by Oleg
  1. External antenna?
    By Guest in forum WL-107g [RAlink Chipset]
    Last Post: 11-04-2008, 10:32
  2. FTP on External USB HDD no WAN uploads
    By SpAwN in forum WL-500g Q&A
    Last Post: 13-07-2005, 02:56
  3. Use of external antenna
    By Theo in forum WL-500g Q&A
    Last Post: 27-06-2005, 17:35
  4. Spin down external HD
    By Styno in forum WL-500g Custom Development
    Last Post: 05-06-2005, 22:04
  5. Replies: 1
    Last Post: 09-03-2004, 17:16
