The idea is to create in the near future a database with reported working and non working devices
please report here if you have a device that WORKS or does NOT WORK
please also report if you have upgraded and the device stays working or not
your post should look like this: (this is an actually working product I own)
Tested: Working
Model: WL-500g
Firmware: 1.6.5.3
Device:
Brandname: Constar (OEM'd i think!!)
Brandtype: ST-2512C
USB Interface: USB 2.0 High Speed (480Mbit) compliant
URL To manufacturer: http://www.snt.com.tw/
URL To product: http://www.snt.com.tw/product.php?mo...&cid=22&pid=65
Device Used during test:
Brandname: Maxtor
Brandtype: Maxtor Diamondmax Plus 9 160GB
Brandmodel: 6Y160P0
partition: 160GB using FAT32 (with some issues when mounting)
Brandname: Maxtor
Brandmodel: 6Y200P0
partition: 200GB using NTFS (unable writing)
