hey!
I'm not sure if it's the famous "wan dies" issue but I have the following problem:
- Wl-500g running in Homegateway mode connected to Cable Modem with fixed IP and fixed DNS
- Running the busybox_httpd via firewall rule 8080 -> 80 from outside (in post-boot and post-firewall scripts)
- Running samba (in post-boot script)
- Running on Auto speed (don't know what speed my cable modem is running on)
- upgraded from 1.8.1.7-2a to 1.8.1.7-3 (must admit that the first upgrade failed so I did it a 2nd time and it succeeded then)
After that upgrade my WAN connection doesn't come up at boot time anymore, only pressing the "disconnect/connect" buttons (although it says "conneced" in the link status field) in the webconsole subsequently, connection is being established. After a short time of web browsing (no huge data transfers) WAN connection is lost again, bringing it back up only with the buttons in the web console.
Also tried
(thought it's similar to the buttons...)
as well as
et -i eth1 speed 10half/10full/100half/100full
but with no effect, only buttons work.
Tried also the following with no effect:
- installing 1.8.1.7-3 in recovery mode
- resetting to factory defaults via web console
- downgrading to 1.8.1.7-2a
- installing 1.8.2.4
- setting number of max connections to 4096
Also typing
only brings up a "?" or an empty line, I don't know what that means...
The only thing I noticed is that all trouble begins when flashfs comes into work, i.e. after upgrading I set up the scripts and use flashfs (save, commit, enable, reboot) and after that WAN connection is lost.
Then the post-firewall script is not executed anymore and samba does not work (many smbd processes open up, but isn't this a different issue?...I also have two unknown "ping" processes, but I think I'm getting paranoid )
Sadly
and rebooting doesn't do the trick either....
Could it be that I messed up flashfs upon the failed upgrade? Can I recover it in any ways or do a total cleanup? Is there a way to monitor when the WAN dies?
Meanwhile I don't know where to look at anymore and what to try next, all I tried didn't bring my any further....
cheers, thomas.
