hi alias88 (lee )
hmm... seems that the webserver isn't running.
could you describe the error (404, not found, or something else?)
(is samba running?, can you access the harddrive from your pc?)
check with 'df' if your disk/partitions are mounted.
check with 'top' or 'ps' or 'ps axf' which programs are running, there should be a process like lighttpd (the webserver). if there's none, check if your services are starting up when rebooted
Execute:
nano /usr/local/sbin/post-mount
Example: (last line has been decommented -> # removed, so the script does execute)
#! /bin/sh
/opt/etc/init.d/rc.unslung start
save to flash
Good luck!
