Results 1 to 5 of 5
Thread: I need help assigning static ip addresses
    hello, I have 8 static ip address with my dsl connection. My router has a static ip address and i would like to assign my other computers using my WAN static ip addresses not my lan. But all my computers are connected to the router Lan ports. My network settings as follows
    router = 208.106.81.x = static ip
    I have 8 total static ip address. so what i want to do is have my router with it's own static ip address and then have the 2 other computers connected with also my static ip addresses so it would be something like 208.106.81.x . How can i assign this? sorry if my question does not make sense.
    My English is very poor.
    Jan 2007
    Netherlands
    I think what you want is set the router in accesspoint mode.
    then the dhcp server in the router is turned off and just works as a switch so it passes through your wan ip to youre lan's
    Openwrt or Custom Firmware on asus? - http://wl700ge.hezik.nl/ - Http://wl700g.homelinux.net
    My ASUS collection: WL500gp(80GB usb-hdd - Running OpenWrt Kamikaze 7.09) | WL700gE(250GB - Running OpenWrt Kamikaze 8.09rc1)
    Hey
    Hey thanks for the message, so I will try that when I get home today from school.
    I want to set up my 8 static ip addresses as follows
    Static ip 1 will go to the router and the router has 4 ports which will have computers connected. i want all four ports to have there own wan ip addresses senses I have 8 and also have there own LAN ip address. So for example port 1 on the router will be connected to a computer with a wan static ip address other than the router, and the router will also assign that computer a LAN ip address. so it should look like this
    Router's static ip = 208.208.208.3
    Computer 1 connected via cable = 208.208.208.4 (LAN = 192.168.1.110)
    Computer 2 connected via cable = 208.208.208.5 (LAN = 192.168.1.111)
    Computer 3 connected via cable = 208.208.208.6 (LAN = 192.168.1.112)
    I hope this helps. Thank you aging for all the help. Sorry about my English aging.
    Jan 2007
    Netherlands
    when you set in accesspoint mode you get it like this
    Hey
    Hey thanks for the help everything is working according to my setup. Thank you aging!
  1. Ïðîáëåìà ñ Routing table
    By dimoz in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 25-02-2012, 18:39
  2. DYNDNS (Static) Not working
    By Chris Thompson in forum WL-700g Firmware Discussion
    Last Post: 18-03-2009, 00:49
  3. Where static routes configuration is stored?
    By Toxa79 in forum WL-500gP Q&A
    Last Post: 01-11-2007, 16:23
