I have the same problem but my firmware is 1.9.6.9.
I'm trying to use Download master with a 512MB Corsair flashdrive (with a FAT32 partition on it), but I can't make it work. I always get the 'Device not found' error message, when I try to connect. Firewall is off on my PC, and otherwise everything is working on the router.(firmware:1.9.6.9) Could somebody help me?
I forgot to mention, that device discovery finds my wl500gp without problems!
Does your router recognize the inserted flash disk (Status/USB)?
Hello,the only reason where i buy the wl 500 gp is for download to hdd with pc off.i read all topic from here but i cant make it.i make 2 partitions fat32 but every time i take this error
And you checked that:
- You attached the HDD to the right USB port (upper/lower)
- you enabled DL Master in router setup
If you configured right you just might have an incompatible HDD attached. Maybe the Oleg firmware can solve this?
can you explain me please how i download via ftp?
i put host,username,password,port but nothing happend
If Linux isn't your thing, then leave these firmwares alone. Linux is great but will always remain a geek thing without GUI. Normal people don't have the time to manually configure their boxes. They spend their time on family activities
You might look around on the forum for compatible HDD's.
AFAIK Oleg's firmware is't support Download Master. This thing in ASUS firmware only. Check your firewall (or disable it for a time). Download Master need 1213 port might be opened.
xm i make error ,the first partition isnt fat32,now all its ok
Yes it does. Actually I already broke with my Asus WL-500gP. I crated another thread about that:
WL-500gP and Asus support experience http://wl500g.info/showthread.php?t=6345
hello
as I can make so that the router recognizes my external hd?
thank you
hi
can u help me.
i can't download http....the storage is connected it's ok,but when i press download it's nothing happening
...thanks
