Originally Posted by
oleo
I've anticipated that. That's why I didn't want to upgrade until I find a time to test the things. Meanwhile bzhou upgraded package as he is constantly doing this for over 1000 packages that he maintains. Some packages eventually broke during this process. It looks like, I must find a tima now to fix a problem. One is how to disable cache files removal. Until then, One might try Clutch and report if it works with latest release?
I've downgraded to r5332 that works well. Upgrade to latest release is postponed until path handling introduced with r5337 is sollved for transmissiond.
Users should use -force-downgrade and -force-reinstall to get this release.
you mean like this?
PHP Code:
[root@wpte root]$ ipkg install transmission -force-downgrade -force-reinstall
Reinstalling transmission (1.06+r5370-1) on /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/transmission_1.06+r5370-1_mipsel.ipk
package transmission suggests installing thttpd
package transmission suggests installing mini-sendmail
conffile_has_been_modified: conffile /opt/etc/transmission.conf has no md5sum
conffile_has_been_modified: conffile /opt/etc/init.d/S80busybox_httpd has no md5sum
Configuration file '/opt/etc/transmission.conf'
==> File on system created by you or by a script.
==> File also in package provided by package maintainer.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer's version
N or O : keep your currently-installed version
D : show the differences between the versions (if diff is installed)
The default action is to keep your current version.
*** transmission.conf (Y/I/N/O/D) [default=N] ?n
Configuring transmission
Please note that /opt/etc/init.d/S80busybox_httpd is installed for
running CGI interface at http://localhost:8008/cgi-bin/transmission.cgi
See instructions for daemon and WWW interface in /opt/share/doc/transmission
Configure daemon with /opt/etc/transmission.conf
Successfully terminated.
