Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: Project WL-HDD and Weather Station (WS2300)
    Question Project WL-HDD and Weather Station (WS2300)
    Hi.
    Can anyone tell me if user-mode usb programs will work, using libusb?
    I have a Linux project http://oww.sf.net, that can run a USB-connected weather station. I'm wondering how likely it would be that I could get this running on the Asus.
    Thanks,
    Simon
    USB Thermometer
    I am tech lama/HW/ -It it possible, or exist USB thermometer compatibile with asus WL500g.
    My idea is to integrate thermometer with webserver - to log temperature, maybe other parametres of weather .. humidity, ......
    MAybe USB-COM convertor and COM thermometer + linux drivers .....
    I dont know just idea.....
    ICQ - 233853463
    www.voslogin.net
    Last edited by Antiloop; 11-10-2004 at 14:41. Reason: asus 500 = nothing only asus WL500g
    Apr 2004
    Netherlands
    I don't know about USB, but you can wire up an 8 channel A/D converter to the paralel port on the router. That gives you 8 analog measurements and several digital in- and outputs. You have to write your own I/O driver though...
    Aug 2004
    Hi
    There are varios temperature usb sensors around, what i have in mind is the frogbox, http://www.froggyhome.com which is a plastik frog imiatation with some weather sensors and usb inside .
    There are some others i had seen, but i have none in mind any more.
    Greets
    Dec 2004
    Grimstad, Norway
    Remserial serial server
    Will it be possible to compile the 'remserial' software ( http://lpccomp.bc.ca/remserial/ ) to work on a WL-500g unit? Or does it exist other, similar programs taht already works?
    I have an USB->RS-232 adapter, and want to connect a weather station to the router, and access the weather station fom my computer as if the weather station were connected directly to it, and thought this piece of software would do the trick.
    I have never tried to compile anything on the WL-500g, and I see that it's a relatively simple program, si I want to give it a try, but somebody have to push me very hard in the right direction.
    Thanks.
    Apr 2004
    Netherlands
    I guess you just have to give it a try.
    For setting up a cross-compile environment see other topics on this forum and http://wl500g.dyndns.org
    I connected my weatherstation (a wx200) to the wl500gx.
    I used the latest firmware with the usbserial and pl2303 modules.
    I compiled the weather software (http://wx200d.sf.net/).
    See http://david.zope.nl/hardware/wl500g/wx200wl500g
    remserial worked in my wl500b days ago
    here is my package.i added all the files in /tmp/local and a directory named sbin in the folder contains a file post-boot which startup the remserial when wl500b is booting up.
    but unfortunatly i chaged my usb-serial adapter,then i can only send datas from serial to tcp,and cannot receive from serial.
    i donnot know why.maybe the problem is the driver is not suit for my adapter..
    wish the package will do some good for you.
    Apr 2006
    Heesch, Netherlands
    I run serial over tcp successfully with ser2net.
    Look at this topic.
    http://wl500g.info/showthread.php?t=4535
    On my pc I have a virtual comport software.
    look here:
    http://www.hw-group.com/products/hw_vsp/index_en.html
    This works for my Solar inverter readings.
    But now I want to put this readings in a RRD graph, but I don't know how I can create a script to write commands and read the serial output. Some examples run on perl, but use a module which is not included in the microperl package installed on my asus. Any idea?
    Nov 2005
    Hello,
    Quote Originally Posted by mistraller View Post
    Look at this topic.
    look here:
    Does it work your system of Linux-Programm "ser2net" an the Windows-Programm for the "virtual-RS232"? Or is a hope?
    Thanks.
    Jul 2005
    Oslo, Norway
    Serial port emulation on parallel port
    Is it possible to somehow connect a serial port to the parallel port on a wl500g r.1.0 ?
    I have a weather station (ws3600) and I'm checking if I can use my wl500g as the reciever/transmitter of the data.
    Sep 2005
    Get a USB to serial adapter, they come cheap on ebay.
    Jul 2005
    Oslo, Norway
    USB to serial won't work
    The weatherstation I want to connect is reported to not work with a usb2serial converter. They use the serial-port in a strange way (http://open3600.fast-mail.nl/tiki-vi...ind=&forumId=5)
    But I guess your answer imply that it won't work (serial port emulation on parallel port). Anyway, thanks for the answer.
    Feb 2005
    Germany - Frankfurt a.M.
    Quote Originally Posted by eklem
    I think the wl500g have one parallel port, so you can buy an parallel -> serial Adapter, they are very cheap and the smartest solution I think.
    Jul 2005
    Oslo, Norway
    Ok, that's the hardware-part (something like this I guess: http://www.databutikken.com/no/defau...artId=AD101004). How do I go about solving the software-part? Is it just pointing the software to the parallel port with a converter, or do I have to do some extra stuff?
  1. Asus WL-500gP V2 & Sony Play Station Portable (PSP)
    By Vertige in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 31-10-2011, 06:41
