I guess PC pro is not WL-HDD pro
Don't worry, it works whatever way you choose. Maybe they just firewalled themselves out by mistake.
I need a network HDD which I can access from both wired and wireless clients. A review in PC Pro suggests that if you turn on wireless access to the HD in WL-HDD then you can no longer access by wired network. This sounds surprising and it isn't clear from the downloaded manual that WL-HDD has this limitation. Can anyone confirm this?
