Results 1 to 12 of 12
Thread: data transfer speed
    data transfer speed
    Hi, I have my asus 160 GB wl-700ge connected to my windows vista computer via ethernet. I am able to map my asus drive onto the My Computer. However, whenever I transfer files from my computer hard drive to the asus drive (copy and paste or cut and paste), the transfer speed is merely a little less than
    4MBps.. that seems pretty low.. can anyone tell me what measures I can take to fix this problem??
    Thanks.
    guys.. please let me know if this is expected speed or if the data transfer speed of 3-4 MBPS is less than what it should... how much speed should I be getting when transferring media files etc. from windows to the router drive??
    Quote Originally Posted by emailpr View Post
    In my post (Russian):
    http://wl500g.info/showthread.php?t=11687
    I showed the table measuring read/write speed in my USB-HDD measured in different ways with different parameters.
    Hi, thanks.. but I don't understand russian.. also, I am talking about the hard drive built into the router.. I am getting a max of 4.8 MBps for data transferred from computer to the router. Is this normal? or am I supposed to get more? heck, I get about 20 MBps when I transfer files to my IPOD!!
    Yes, it is normal. Speed of my WL700ge is max. 5.1 MBps.
    If you're running the firmware as it comes directly from Asus, your transfer speeds will be degraded because the CPU is 100% loaded due to a setup bug when the router boots.
    If you're courageous, you can improve the speed by installing the custom firmware and insuring you have the following line in your rc.local:
    # Fix the gpio load problem
    echo "interrupt=no" > /proc/miscio/power_enable_config
    Alternatively, you could try opening up the telnet hole on the stock firmware (via the web server) and try it from the command line. It'll work until the router reboots.
    - K.C.
    is this fixed in the last 1.0.7.8 custom firm?
    I still get the same slow transfer speed as i used to since 1.0.4.6
    5 to 6MB per sec. from network to hdd, really bad when you change to a bigger hdd and have to fill it up :S
    thats normal
    grat182
    BTW :
    SiSoftware Sandra
    Benchmark Results
    Drive Index : 6354 kB/s
    Results Interpretation : Higher index values are better.
    Random Access Time : 17 ms
    Results Interpretation : Lower index values are better.
    Performance Test Status
    Run ID : XP2500 on terça-feira, 12 de Fevereiro de 2008 at 14:40:38
    System Timer : 3.6MHz
    Operating System Disk Cache Used : No
    Use Overlapped I/O : No
    Test File Size : 512MB
    Block Size : 1MB
    Benchmark Breakdown
    Buffered Read : 8 MB/s
    Sequential Read : 6699 kB/s
    Random Read : 6022 kB/s
    Buffered Write : 8004 kB/s
    Sequential Write : 6130 kB/s
    Random Write : 5952 kB/s
    Random Access Time : 17 ms (estimated)
    Drive
    Drive Type : Network
    Total Size : 233GB
    Free Space : 109GB, 47%
    Cluster Size : 1kB
    That is normal but it should't be, is it impossible to make the brick run faster?
    Would there be scope to fine tuning the samba setup defined by the asus firmware? I suppose you need to be an expert on Samba to do this.
    http://samba.org/samba/docs/man/Samb...ion/speed.html
    This link seems to go through some fine tuning changes, but it's uncharted territory for me. Has anyone looked at this?
    LK
    Quote Originally Posted by CrAzY_DrIveR View Post
    BTW :
    SiSoftware Sandra
    Benchmark Results
    Block Size : 1MB
    Benchmark Breakdown
    Drive
    Total Size : 233GB
    Cluster Size : 1kB
    This is a very good results, i think. My speed is 3-4 mB/s on Kamikaze 7.09 firmware. Can you post your smb.conf file?
    i have no idea where to get the smb.conf file.
    i just changed the 160 stock drive to a 250gb very hot maxtor and put the kf 1.0.7.8, a fresh xp sp1 install, nothing more.
    Still very slow compaired to the 9-10 MBps that we get from 100 Mbps networks...
  1. read /dev/ppp: Value too large for defined data
    By ENDer2000 in forum WL-500gP Firmware Discussion
    Last Post: 25-10-2007, 21:54
  2. Replies: 1
    Last Post: 19-10-2007, 17:05
  3. Replies: 38
    Last Post: 08-12-2004, 10:44
  4. WL-HDD disk transfer speed
    By gerardwr in forum WL-HDD Q&A
    Last Post: 31-10-2004, 16:32
  5. USB HDD connects as Webcam
    By Oldchatterman in forum WL-500g Q&A
    Last Post: 19-10-2004, 17:54
