Правильно ли я понимаю, что режима точка доступа в wl520gC нет?
И решит ли вопрос замена на wl500gP(v1)?
PS Задача
- взять wi-fi "с окна" и расшарить на квартиру.
Доступна пара сетей - как между ними будет производиться переключение?
Code:Jan 1 03:00:02 syslogd started: BusyBox v1.17.2 Jan 1 03:00:03 kernel: klogd started: BusyBox v1.17.2 (2010-09-30 19:29:29 MSD) Jan 1 03:00:03 kernel: CPU revision is: 00029029 Jan 1 03:00:03 kernel: Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes. Jan 1 03:00:03 kernel: Primary data cache 16kB, 2-way, linesize 16 bytes. Jan 1 03:00:03 kernel: Linux version 2.4.37.10 (root@localhost) (gcc version 3.4.6) #2 2010-09-30 19:32:21 MSD Jan 1 03:00:03 kernel: Setting the PFC to its default value Jan 1 03:00:03 kernel: Determined physical RAM map: Jan 1 03:00:03 kernel: memory: 01000000 @ 00000000 (usable) Jan 1 03:00:03 kernel: On node 0 totalpages: 4096 Jan 1 03:00:03 kernel: zone(0): 4096 pages. Jan 1 03:00:03 kernel: Page-cache hash table entries: 4096 (order: 2, 16384 bytes) Jan 1 03:00:03 kernel: Checking for 'wait' instruction... unavailable. Jan 1 03:00:03 kernel: POSIX conformance testing by UNIFIX Jan 1 03:00:03 kernel: PCI: no core Jan 1 03:00:03 kernel: PCI: Fixing up bus 0 Jan 1 03:00:03 kernel: Linux NET4.0 for Linux 2.4 Jan 1 03:00:03 kernel: Based upon Swansea University Computer Society NET3.039 Jan 1 03:00:03 kernel: Initializing RT netlink socket Jan 1 03:00:03 kernel: Starting kswapd Jan 1 03:00:03 kernel: Journalled Block Device driver loaded Jan 1 03:00:03 dnsmasq[73]: started, version 2.55 cachesize 512 Jan 1 03:00:03 dnsmasq[73]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N DHCP no-scripts no-TFTP Jan 1 03:00:03 dnsmasq-dhcp[73]: DHCP, IP range 192.168.1.101 -- 192.168.1.254, lease time 1d Jan 1 03:00:03 dnsmasq[73]: read /etc/hosts - 2 addresses Jan 1 03:00:04 kernel: usb.c: registered new driver usbdevfs Jan 1 03:00:04 kernel: usb.c: registered new driver hub Jan 1 03:00:04 kernel: usb-ohci.c: USB OHCI at membase 0xb8003000, IRQ 6 Jan 1 03:00:04 kernel: usb-ohci.c: usb-00:03.0, PCI device 14e4:471a Jan 1 03:00:04 kernel: usb.c: new USB bus registered, assigned bus number 1 Jan 1 03:00:04 kernel: hub.c: USB hub found Jan 1 03:00:04 kernel: hub.c: 2 ports detected Jan 1 03:00:04 kernel: ehci_hcd 00:03.1: PCI device 14e4:471a Jan 1 03:00:04 kernel: ehci_hcd 00:03.1: irq 6, pci mem b8003800 Jan 1 03:00:04 kernel: usb.c: new USB bus registered, assigned bus number 2 Jan 1 03:00:04 kernel: ehci_hcd 00:03.1: USB 0.0 enabled, EHCI 1.00, driver 10 Dec 2004/2.4 Jan 1 03:00:04 kernel: hub.c: USB hub found Jan 1 03:00:04 kernel: hub.c: 2 ports detected Jan 1 03:00:04 kernel: usb.c: registered new driver usblp Jan 1 03:00:04 kernel: printer.c: v0.13: USB Printer Device Class driver Jan 1 03:00:05 kernel: Linux video capture interface: v1.00 Jan 1 03:00:05 kernel: SCSI subsystem driver Revision: 1.00 Jan 1 03:00:05 kernel: Initializing USB Mass Storage driver... Jan 1 03:00:05 kernel: usb.c: registered new driver usb-storage Jan 1 03:00:05 kernel: USB Mass Storage support registered. Jan 1 03:00:06 l2tpd[94]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru' Jan 1 03:00:36 l2tpd[94]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru' Jan 1 03:01:06 l2tpd[94]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru' Jan 1 03:01:21 dnsmasq-dhcp[73]: DHCPREQUEST(br0) 192.168.1.137 00:19:66:f9:fb:70 Jan 1 03:01:21 dnsmasq-dhcp[73]: DHCPACK(br0) 192.168.1.137 00:19:66:f9:fb:70 microsof-095a7b Jan 1 03:01:21 dnsmasq-dhcp[73]: DHCPREQUEST(br0) 192.168.1.137 00:19:66:f9:fb:70 Jan 1 03:01:21 dnsmasq-dhcp[73]: DHCPACK(br0) 192.168.1.137 00:19:66:f9:fb:70 microsof-095a7b Jan 1 03:01:36 l2tpd[94]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru' Jan 1 03:01:51 dnsmasq-dhcp[73]: DHCPINFORM(br0) 192.168.1.137 00:19:66:f9:fb:70 Jan 1 03:01:51 dnsmasq-dhcp[73]: DHCPACK(br0) 192.168.1.137 00:19:66:f9:fb:70 microsof-095a7b Jan 1 03:02:06 l2tpd[94]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru' Jan 1 03:02:36 l2tpd[94]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru' Jan 1 03:03:06 l2tpd[94]: tunnel_establish: gethostbyname failed for 'tp.internet.beeline.ru' Jan 1 03:03:14 dnsmasq-dhcp[73]: DHCPREQUEST(br0) 192.168.1.137 00:19:66:f9:fb:70 Jan 1 03:03:14 dnsmasq-dhcp[73]: DHCPACK(br0) 192.168.1.137 00:19:66:f9:fb:70 microsof-095a7b Jan 1 03:03:16 dnsmasq-dhcp[73]: DHCPREQUEST(br0) 192.168.1.137 00:19:66:f9:fb:70 Jan 1 03:03:16 dnsmasq-dhcp[73]: DHCPACK(br0) 192.168.1.137 00:19:66:f9:fb:70 microsof-095a7b
PS Задача
Нашел две старые точки: Asus WL520G и OvisLink WL-5460AP. Настроил WDS. Как более точно настроить антенну? Видно что сигнал слабый. Можно где то в асусе посмотреть уровень сигнала? Спасибо.
Здравствуйте. Собираюсь купить asus wl-520gu, появился вопрос. Если подключить в него usb hdd и качать торренты, он это потянет? Канал небольшой, 2,5 мегабита с внешки и мегабайт с локалькой сети. В среднем 5-7 активных закачек.
Волнуюсь из-за оперативной памяти, 16 мб ведь всего. Спасибо.
Введите в telnet/ssh или в System Setup - System Command на роутере :Originally Posted by arabaj
З.Ы. А FAQ не пробовали почитать ?Code:wl scan && sleep 1s && wl scanresults
Приветствую уважаемые форумчане !
Вопрос из разряда « Бен это Данила ай нид хелп!» А то даже не знаю с чего начинать.
Суть вопроса : хочу сделать домашнюю сеть . подскажите где чего искать и чего устанавливать
ТЕХ.ЗАДАНИЕ))))))))))))))))))))))
В наличие имеется:
-корбина
-роутер asus 520 gu (исправно работает на родной прошивке с покупки ничего не менял)
-Стационарный компьютер ХР(сейчас подключён к роутеру витой парой)
-ноутбук ВИСТА(подключён по вайфаю)
-хард диск на 900 гигов с отдельным питанием от электрической сети (подключен к ноутбуку USB-кабелем)
-принтер Эпсон подключён к стационарному компьютеру, (подключал к роутеру делал сетевым, но некорректно печатал страницы, сейчас печатаю просто только с одного компа)
+ естесно подключение всяких телефонов и других ноутбуков
Воть…
Хочу…
Организовать домашнюю сеть (хранение на харде, обмен фаилами, контроль работы компьютеров, игра по сети)
Подскажите пожалуйста возможна ли следующая схема и её функциональные возможности-
РОУТЕР 520 gu к нему подключены:
+ноутбуки и все что можно по вайфаю
+ ХАРД по USB-кабелю для скачки торрентов и как общее хранилище файлов домашней сети (вопрос ставится именно так и торренты и общее хранилище домашней сети хард качает торренты при всех выключенных компьютерах).
+витой парой стационарный компьютер с принтером (принтер желательно чтоб мог распечатывать с любого компьютера)
Все енто объединено в какую-то локальную сеть .
ВОПРОС
Возможно ли это или я много хочу от роутера?
Если возможно, то:
1. Какую прошивку ставить
2. Какое понадобится дополнительное программное обеспечение
3. Как сделать эту домашнюю сеть (можно ли её сделать из той которую создает роутер)
Если не возможно, то какая конфигурация возможна и её функциональные возможности.
ТОВАРЩИ! ПОДСКАЖИТЕ, ПОЖАЛУЙСТА, ЧТО ОТКУА БРАТЬ, ГДЕ ЧТО НАЖИМАТЬ, И ЧТО ЧИТАТЬ.
ЗАРАНЕЕ БЛАГОДАРЕН!!!
Год назад настроил роутер WL-520GC, сейчас все работает без проблем, как добавить новый ноутбук через wifi
Добрый день.
Стоит задача приобрести роутер для одной цели!
Цель - Подключение удаленной сети из пары человек с помощь OpenVPN
Выбор пал на WL-520gC - WL-520gU - WL-500gPremV2, или посоветуйте пожалуйста другое оборудование!
(поставил в порядке возрастания цены,а она в приоритете - выполнять только 1ну задачу)
Есть рядо вопросов:
1)-Какой выбрать роутер,и стоит ли платить больше за WL-520gU - WL-500gPremV2(а может есть резон?)
2)-Какая на сегодняшний момент самая стабильная,новая прошивка под данное устройство
3)-Где найти манулал по настройке
---OpenVPN Client
---Маршрутизацию для:
-----Доступ в локальную сеть по маршутру VPN
-----Доступ в интернет через АДСЛ модем т.е. другой шлюз(доступ в интернет для ВПН тоже через этот АДСЛ)
4)Настройка:
-OpenVPN осуществляется исключительно через консоль? веб морды нет?
-Откуда устанавливаются дополнительные нужные пакеты с интернета или это вопрос урегулирован исключительно тем что есть в прошивке?
-На сем построен OpenWRT насколько понимаю эта же "Прошивка от Олега"?
5)Есть умельчы которые прикручивали asterisk + FreePBX на флешку в USB?
Прошу сильно ногами не писать,поиском искал но однозначных ответов нет.
Или может кто знает возможно можно какой АДСЛ можем прошивать и на нем поднимать ВПН с возможностью настройки нужной мне маршрутизации?
ADSL можно этот, http://www.ddixlab.ru/forum/viewtopi...231&start=3135 для всего остального есть ответы в поиске ) Да, OpenWRT к прошивке энтузиастов обсуждаемой здесь никакого отношения не имеет
Роутер выбирают исходя из мощности/объема памяти... Так что вы слишком оптимистичны если надеетесь что на WL-520gC/WL-520gU у вас хватит еще на что-нибудь кроме прошивки )
Астерик, никому не хочется разбираться почему он падает, так что задача ждет своего исследователя...
Прошивку отсюда -
ftp://core.dumped.ru/rt-n/2555/wl/WL...n-r2555.trx.gz
Не забыть распаковать )
PPTP Options: No Encryption - не нужно
Additional pppd options: "nomppe nomppc sync mtu 1400" - не нужно
Heart-Beat or PPTP/L2TP (VPN) Server:
убрать --sync" и кавычки.....
До и после перепрошивки хорошо бы сбрасывать роутер, помогает от странных глюков, после чего настроить заново ручками )
http://wl500g.info/showpost.php?p=33445&postcount=16
Попробуйте это - http://asus.vectormm.net/wl/2567/WL5....7-d-r2567.trx
