Changed in the 1.8 series by ASUS. Trick to make mnt/usbfs work:Originally Posted by xlephant
Code:mount -o bind /tmp /mnt ln -s /tmp/harddisk /mnt/usbfs
hi guys,
im a bit confused at the moment. was there a special reason to change the usb mountpoint from /mnt/usbfs to /tmp/harddisk, (don't know since which firmware) ? because a lot of the additions uses fixed paths in their scripts... and it is awful to change all this links.
also a lot of addtions don't run with newer firmware (graphical accounting, bluetooth and gift), maybe because of the mountpoint. ideas?
if anyone ask the question before, i'm sorry for asking again, but i didn't find the previous question(used search, realy ) . a link is maybe helpfull for me.
thx 2 all
Athlon XP 2200+ runnig on ECS K7S5A
512 MB DDR
160 GB Samsung
Ati Radeon 9500
System running under Yoper.v2
Router: WL500g
I guess the HDD has to be present before it can be mounted. In previous firmwares the HDD was mounted between pre-boot and post-boot script, but in the new 1.8.x.x firmwares the HDD is mounted by the watchdog which may take about 10 seconds AFTER post-boot has finished.
So if you want to run scripts (or make other mount points) on the HDD in the post-boot script you will have to make sure post-boot execution waits until the HDD is mounted. This can be done as described in :
http://wl500g.info/showpost.php?p=6290&postcount=26
So I have done this, but some of my executables (?) won't run, I get the following error message:Originally Posted by Oleg
./btctl
-sh: ./btctl: not found
huh?
it works ok with 1.7.whatever
Have you checked access rights? I mean chmod +x btctl?
same error here already checked the rights.So I have done this, but some of my executables (?) won't run, I get the following error message:
./btctl
huh?
any ideas will be helpful.
thx
512 MB DDR
160 GB Samsung
Ati Radeon 9500
Router: WL500g
