Jan 1 00:00:05 kernel: usb 1-1.1: configuration #1 chosen from 1 choice
Jan 1 00:00:05 kernel: usbcore: registered new interface driver usblp
Jan 1 00:00:06 kernel: SCSI subsystem initialized
Jan 1 00:00:06 kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:06 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 00:00:06 kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:06 kernel: USB Mass Storage support registered.
Jan 1 00:00:07 kernel: NTFS driver 2.1.28 [Flags: R/O MODULE].
Jan 1 00:00:07 dnsmasq[208]: read /etc/hosts - 2 addresses
Jan 1 00:00:07 dhcp client: deconfig: lease is lost
Jan 1 00:00:07 dnsmasq[208]: using nameserver #53
Jan 1 00:00:08 dhcp client: bound IP :
Jan 1 00:00:08 kernel: scsi 0:0:0:0: Direct-Access WD Ext HDD 1021 2002 PQ: 0 ANSI: 4
Jan 1 00:00:08 kernel: sd 0:0:0:0: [sda] 2930272256 512-byte hardware sectors (1500299 MB)
Jan 1 00:00:08 kernel: sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled
Jan 1 00:00:08 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jun 19 21:55:45 ntp client: Synchronizing time with pool.ntp.org...
Jun 19 21:55:52 kernel: sda: sda1 sda2 sda3
Jun 19 21:55:53 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
