working! Thank you very much
put this after the first line:
export PATH=/opt/bin:/opt/sbin:$(PATH)
i just added -a *.*.*.* (this means allow all ip)
here:
like this:Code:nano /opt/etc/init.d/S90transmission-daemon (you can use vi instead)
thenCode:/opt/bin/transmission-daemon -a *.*.*.* -g /tmp/harddisk/[yourtorrentfolder]
Code:/opt/etc/init.d/S90transmission-daemon stop /opt/etc/init.d/S90transmission-daemon start
without any reason transmission 2.32-1 after my last update just segfaults..
Is it only me or it's common problem ? How to make transmission talks to me (debug mode)?
[ed]
opted 1.9.2.7-d-r2624 fully updated
ok --debug gives nothing, segfaults also without message.
