Add this to rc.local:
Sollie.Code:# Opening port 8082 iptables -I INPUT 7 -p tcp --dport 8082 -j ACCEPT
Dear All,
I'm relatively new to Linux/Firewalls so I need your help to be able to access my web pages from outside.
I've lighttpd running and listening in port 8082. What do I have to do to access the pages from the WAN?
Related to the above, I have ssh running with access from the LAN working fine. What do I need to do to allow ssh from the WAN?
Regards,
PVarela
Sollie, thank you. I'll try that tonight.
Do I need also to redirect port 8082 to router_local_ip:8082 in the web interface?
Regards,
PVarela
noDo I need also to redirect port 8082 to router_local_ip:8082 in the web interface?
This statement is questional (does he has 7 rules? By default I have only 6)iptables -I INPUT 7 -p tcp --dport 8082 -j ACCEPT
I suggest either (as a result you rule will be the first one):
or better (as a result you rule will be the last one):PHP Code:
iptables -I INPUT -p tcp --dport 8082 -j ACCEPT
Anyway check the result with iptables -LPHP Code:
# set default policy
iptables -P INPUT DROP
# remove the last default rule
iptables -D INPUT -j DROP
# Allow access to lighthttpd server from WAN
iptables -A INPUT -p tcp --dport 8082 -j ACCEPT
Sollie, al37919,
Thank you both. Everything is working perfectly now.
Regards,
PVarela
