Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: new firmware 1.9.2.7-8 by oleg
    PPPoE disconnect under heavy load
    i noticed a strange behaviour on my router. Whenever i download large amount of data from several sources (2-3 torrents running, while downloading from 2 sharewebs ie. rapidshare), the PPPoE connection gets lost. When i'm trying to go into the routers WebUI, it loads very slowly, often with errors (like missing Asus logo). Pressing the Reconnect button on the Status page doesn't help, usually i need to restart the router several times to be able to connect to my ISP.
    I'm using an 1.5/0.5 ADSL connection and i have to PCs connected to the Asus (1 through LAN, 1 through wifi)
    Quote Originally Posted by Serpent View Post
    Sergeos, I was even wondering if you have find a solution to your problem...
    Yes, finally I have figured the problem out.
    When I noticed the ADSL router disconnecting from the ISP even though it was not plugged into the ASUS router at all - something clicked in my mind and indicated that I had been digging in the wrong direction...
    As it often happens, the problem has turned out to be much simplier than it appeared to be.
    It was bloody generic USB hard drive connected to the device. Apparently every now and then when the HD was being accessed, it was creating some noise (interference) and the ADSL router was picking it up.
    So I changed the hard drive enclosure to a more expensive one (seagate) and finally my problem is sorted out (knock on woods...)
    I can now copy files accross from the ASUS router and at the same time surf the Internet comfortably. Though the router is now is configured only as a WiFi access-point and torrent downloader.
    Possibly will configure the router back as a full-blown router to enable wshaper when I have time, but not now. I'm quite happy with the way things are at the moment.
    Thanks everyone for the help.
  1. Neue Oleg Firmware verfügbar: v1.9.2.7 CR8
    By wengi in forum German Discussion - Deutsch (DE)
    Last Post: 06-12-2007, 15:17
  2. About WL-500W Oleg firmware
    By hweiee in forum WL-500w Firmware Discussion
    Last Post: 31-10-2007, 10:03
  3. C Compiler voor de oleg firmware
    By wouzs in forum Dutch Discussion - Nederlands
    Last Post: 28-10-2007, 15:57
  4. New Asus firmware, old Oleg firmware
    By JuggernauT in forum WL-500gP Firmware Discussion
    Last Post: 26-09-2006, 13:26
  5. twonky media server, network drive with oleg firmware
    Last Post: 22-03-2006, 07:15
