so well why don't you put the WLAN in the same subnet?Originally Posted by appo
Is there a way in gateway mode to exchange data between WLAN & LAN?
Currently my 500g is setup in gateway mode. I can access the internet from wired-lan (LAN) and wireless-LAN (WLAN)
However I want to exchange files between the LAN and WLAN. Gateway mode assigns a different subnet to LAN and WLAN. So there is no possibility that these two subnets can exchange data.
I could set the router to access point, then LAN and WLAN are in the same subnet. Then XP will see both computers, I can setup shares and exchange data. But then I will loose all the WAN options of the router!
Ehm, ... how do I do that?
I browsed through the manual and saw on page 44 - IP Config > WAN & LAN > LAN IP Setting > IP address - however this will only effect the wired ones ... right? I can't find anything about this setting for WLAN.
Or should I specify a fixed ip address in XP in the same subnet as the LAN iso using DHCP?
Thanks!
Bugger - I think I found it
Page 46 - IP Config - DHCP Server
Page 58 - Wireless Firewall - DHCP Server
Right? Will test it tonight....
wireless firewall does not exist anymore in 1.8.x.x firmwaresOriginally Posted by appo
by mentioning firmware version I could have given the answer before
and at last it's in the manual
