Hi all..
Right now I'm experiencing strange and frightening behaviour !
I have my data partition mounted at /mnt
This morning all was fine.. could access all my files.
Right now,
I can access some directories.. some don't even show up in windows (samba) and some dir's show up as file.
In SSH, I can see the contents of /mnt.
when I issue dir command I can see a folder cms
when I try to go to the folder with cd cms it gives me an error: -sh: cd: can't cd to cms like it is non-existing.
I also have this with a music and movies directory.
When I issue df command I can see my 500gb disk is filled for 70% so the data must be there.
Is my partition corrupt or something ? and if so.. how can I fix these things?
aprox. 300gb of data on the disk which I don't want to loose.. (sure I have backups, but it would take me a lot of time to do it.. )
Is there anything I can do?
please help...
