Results 1 to 8 of 8
Thread: Router looses configuration + Power On problems
    See my configuration at the bottom.
    I switch off my router frequently for security reasons and
    low power consumption.
    After powering on again, the router often shows up
    with factory settings.
    I recently upgraded to Oleg's firmware 1.9.2.7-7g from
    -7d or -7e (don't remember exactly).
    I use the WEB interface for maintainance.
    I wonder if this firmware- or HW-specific.
    There is some other strange behaviour, which occured already
    with previous firmware versions:
    1. On first power-on (after some hours of disconnection from
    power supply) the router often is not initialized correctly:
    It does not respond to requests and the power LED is off (although
    the LAN LEDs are on)
    2. Doing a very quick Power On-Off-On switching (to solve the preceeding
    problem) the result is undetermined:
    - Sometimes the router starts rebooting continuously
    - sometimes it is reset to factory defaults
    In summary, the router is quite unusable for sporadic internet connection.
    I hope i'll find a solution here.
    Thanks in advance,
    Amelie
    --------- My configuration ---------------------------
    (might be unusual, since most features are disabled.
    The router is mostly switched of):
    - Asus WL500gx (aka Asus WL500G Deluxe)
    - Oleg firmware 1.9.2.7-7g
    - ADSL connection as PPPoE.
    - Some strict FW rules
    - Most features disabled, e.g. Radio off, PnP off, FTP off, access from WAN off
    - I use the WEB interface for maintainance
    Apr 2006
    Heesch, Netherlands
    Any hardware connected on USB?
    Solar inverter monitoring with Asus wl500gx http://solar.reinieren.net (dutch)
    No, i have no HW connected on USB.
    But your guess may point to the right direction.
    The reason might be insufficient power supply caused
    be powerconsumptive devices (e.g. connected on USB).
    I use the Asus router since Oct 2005, and since that time
    i had problems after power on. I held my ADSL-Modem
    responsible, connected at WAN port.
    There was also a post about generally poor Asus power supplies.
    My workaround until now was to power on again.
    But since i use Oleg's firmware 1.9.2.7-7g that does
    not work anymore: After switching on, my router configuration
    is gone.
    The 'non deterministic' behaviour of my router suggests
    something like electrical characteristics beeing the cause.
    I will investigate a little into disconnected ADSL-Modem
    and a stabilized power supply
    Thanks so far,
    Amelie
    Apr 2006
    Heesch, Netherlands
    Quote Originally Posted by Amelie View Post
    is gone.
    Thanks so far,
    Amelie
    Well, I have webcam, usb harddisk connected to usb, on standard power supply. But of course there could be differences in powersupplies. I have two wl500gx running, different supply.
    Is the problem still there if you flash asus firmware?
    And, are you sure your config is correctly stored? Maybe play around with backup/restore settings
    I have done a 'System Setup - Firmware Upgrade - Upload' to version 1.9.2.7-7g via the web interface several times. But i am not familiar with things like NVRAM and filesystem. Nor am i with system commands like 'flashfs enable/commit/save'. I just hope, the web interface works as expected.
    I am sure, they are not :-)
    I thought i did.
    I adjusted the settings via web interface. After second loss of router settings i did a 'System Setup - Setting Management - Save as...' to file via the web interface.
    Now for weeks weeks, every morning, if the settings are gone again, i am glad to 'System Setup - Setting Management - Upload' only, instead of manually adjust the whole router settings again.
    After i have checked the power supply, i will check
    1. openWrt
    2. other router HW
    Apr 2006
    Heesch, Netherlands
    I thought i did.
    1. openWrt
    2. other router HW
    Well, if you can fix the problem by uploading the settings again, then your settings ARE stored in memory, but not applied during boot.
    flashfs is not needed if you use only webinterface. Can you post your system log?
    That is something i expected too. Anyhow, as an experiment i did 'flashfs commit' to days ago, because the symptoms were like a missing commit statement in a database. Since then I did some 10 startups and the router kept his settings!
    It is some kind of progress. But i still have to start the router twice, because after first power-on the router does not respond to requests.
    a) reset-to-factory-defaults-state: Unfortunately, i didn't make a copy of the log. And now i can't reproduce that state anymore.
    b) not-responding-to-requests-after-first-power-on-state: I can't access the routers log via web interface nor telnet. And the external syslog-server does not receive any UDP log messages during that state.
    I attached a log from a second power on. The log is a snippet from my external syslog-server receiving log messages from my router. It was recorded some days before i executed the 'flashfs commit'
    The only suspicious entries i see, are about 'bogus logical sector size'. These kind of entries were there for one year at least. I already posted them into the forum, but got no answer.
    Don't spend to much time with the log, because 'reset-to-factory-defaults-state' as the main problem is 'solved'. The second problem (not-responding-to-requests-after-first-power-on-state) still remains, but i think i can live with it, as i already did for years.
    Many thanks for your help,
    Amelie
    BTW.
    Is there any english doc about your solar inverter monitoring mentioned at your footer?
    May 2004
    France...
    If this is a power supply issue, did you try an other one ? I guess any 5Volts DC power supply borrowed from an SUB hub would do the trick...
    The Struggle Continues...
  1. How-to: Use your router as a BitTorrent Client
    By GerardNL in forum WL-700g Tutorials
    Last Post: 24-10-2007, 19:38
  2. Wl500 connected via a dsl router - speed problems
    By impossible in forum WL-500g Q&A
    Last Post: 07-03-2007, 23:55
  3. Replies: 0
    Last Post: 24-01-2007, 02:54
  4. problems installing samba on my router
    By a-beck in forum WL-500g Q&A
    Last Post: 28-11-2006, 16:29
  5. Completely new WL700gE router crashed after firmware update - plz help!
    By ClaudeX in forum WL-700g Firmware Discussion
    Last Post: 20-07-2006, 00:03
