Results 1 to 12 of 12
Thread: Hello all, Kfurge C'firmware problem
    Hi all,
    nice site.
    i followed the guide on kfurge's site up to...
    ---Step #3, Installing optware packages
    -----For completeness, re-run "ipkg install" for uclibc, busybox, ipkg, and wget to fully install them. You may have to use the -force-overwrite flag.
    there seems to be no problem while installing the pakages using ipkg
    i stopped here i decided to quit telnet by typing 'exit'
    but when i enter back into telnet i get the the busy box console (as expected)
    but none of the previous pakages i installed do not work,
    eg VI (new busybox),ipkg .
    is this suppose to happen? if not what im i doing wrong?
    i eventually hoped to install ushare (to stream mp4 file to my ps3)
    and Php,apache,mySQl (for my brother)
    Thanks -BLUE
    i even if i browse opt/bin the new executables are there, what have i done wrong?
    you have to run
    export PATH=/opt/bin:/opt/sbin:${PATH}
    export LD_LIBRARY_PATH=/opt/lib:${LD_LIBRARY_PATH}
    and/or put it in your rc.local.
    grat182
    thanks that fixed it!
    i have the same problem, after i enter this to line everything is back. i checked my rc.local file and this
    strings are in it, why its not working after reboot? do i have all the time enter this strings after reboot??
    Both PATH and LD_LIBRARY_PATH become invalid with a true login shell. You'll have to add the lines to the users .profile in order to make them active with each login.
    - K.C.
    Im sorry for a dummy question but how can i do that?
    Jan 2007
    Netherlands
    Quote Originally Posted by ValoYossa View Post
    http://wl700g.homelinux.net/drupal/?q=node/84
    Openwrt or Custom Firmware on asus? - http://wl700ge.hezik.nl/ - Http://wl700g.homelinux.net
    My ASUS collection: WL500gp(80GB usb-hdd - Running OpenWrt Kamikaze 7.09) | WL700gE(250GB - Running OpenWrt Kamikaze 8.09rc1)
    Quote Originally Posted by back2basic View Post
    thank you for link
    i followed this guide but i think i made a mistake somewhere
    after all i have this:
    telnet 192.168.1.1
    Trying 192.168.1.1...
    Connected to 192.168.1.1.
    Escape character is '^]'.
    (none) login: MyUser
    Password:
    warning: cannot change to home directory
    Connection closed by foreign host.
    whats could be wrong? what i did wrong?
    im not sure if i did this right:
    vi /opt/etc/sudoers
    # Runas alias specification
    # User privilege specification
    root ALL=(ALL) SETENV: ALL
    MyUser ALL=(ALL)SETEVN: ALL
    # Uncomment to allow people in group wheel to run all commands
    # and set environment variables.
    %wheel ALL=(ALL) SETENV: ALL
    # Same thing without a password
    # %wheel ALL=(ALL) NOPASSWD: SETENV: ALL
    # Samples
    # %users ALL=/sbin/mount /cdrom,/sbin/umount /cdrom
    # %users localhost=/sbin/shutdown -h now
    and my .profile was totally empty file so i just added two strings and saved it:
    export LD_LIBRARY_PATH=/opt/lib:$/{LD_LIBRARY_PATH}
    im sorry im trying learn linux but its difficul and to much information in same time. Im sorry for bothering you with my dummy question
    Jan 2007
    Netherlands
    thank you for link
    this also has to be in youre .profile
    # Bash initialization script
    PS1="[\u@\h \W]$ "
    PATH=/opt/sbin:/opt/bin:/sbin:/bin:/usr/sbin:/usr/bin
    LD_LIBRARY_PATH=/opt/lib:/shares/lib
    export PS1 PATH LD_LIBRARY_PATH
    and youre /etc/passwd should look like someting like this
    root::0:42000:root:/:/bin/sh
    ron:****encrypted passwd DON'T change***:35001:42000:ron:/opt/home/ron:/opt/bin/bash
    use putty to log in to youre box
    Download here
    PS1="[\u@\h \W]$ "
    Download here
    THANK YOU THANK YOU THANK YOU its finally working!!!!
    i use mac os terminal but i have this putty too. Mac os also unix based system so i think its ok to use it, cause i did mostly everything in my box trough mac os terminal and its working.
  12. Quote Originally Posted by back2basic View Post
    PS1="[\u@\h \W]$ "
    Download here
    I just don't understand one thing: I followed kfurge's instructons regarding rc.local, shells, passwd and profile files. Despite if I reboot the router and connect via telnet, I could just receive an empty line or string, if I release this command echo $LD_LIBRARY_PATH or if I release this, result of echo $PATH is /usr/sbin:/bin:/usr/bin:/sbin
    Situation is almost the same, if I try it in bash, unless value of $PATH is correct (/bin:/sbin:/usr/bin:/usr/sbin::/opt/bin:/opt/sbin), but $LD_LIBRARY_PATH is even empty.
    Why? What did I do wrong?
  1. Problem with Berkeley db utilities at execution
    By Rodion in forum WL-500g Q&A
    Last Post: 22-12-2006, 17:23
  2. WL-500gP and Asus support experience
    Last Post: 03-12-2006, 13:59
  3. Problem with dieing AIR-connection
    By BòóN in forum WL-500g Q&A
    Last Post: 26-10-2004, 13:04
