Well, guy. This is the reason, why it's going to 1.1.1.1 - you CAN'T specify the same net for LAN and WAN side. Switch your LAN to 192.168.0.0/255.255.255.0 and your problems will be solved.
This is not a bug, this is a MISCONFIGURATION.
my "must have" ip settings:
wan ip adress:
192.168.1.16 (because of DMZ IP from my SDSL /ROUTER)
wan subnet mask:
255.255.255.0
gateway:
192.168.1.1
local router ip:
192.168.1.3 (my.router)
DHCP Server:
starts at:
192.168.1.5
ends at:
192.168.1.10
thats all. i don't know why the router is searching for 192x ips in my local network, and i don't know if he is realy doing this. the fact is, that i can't connect to hp.com and adobe.com (other i didn't try) with the subnetmask 255.0.0.0. ideas?
Athlon XP 2200+ runnig on ECS K7S5A
512 MB DDR
160 GB Samsung
Ati Radeon 9500
System running under Yoper.v2
Router: WL500g
ohh its such a shame
i feel ashamed, you're totaly right. i knew that, but i didn't notice that by typing in the last post.
if you came to frankfurt (airport) next time you will get this beer crate in real
thx a lot, now everything is working fine.
512 MB DDR
160 GB Samsung
Ati Radeon 9500
Router: WL500g
I have problem with the transfer speed from my wireless network to my hdd. that is attach at the usb port.
When i install the firmware (1.8.1.7) than the ftp transfer speed is around 50 Kbyte. this is much lower than when i install the firmware (9.8.2.1) (ftp transfer speed : +/- 350 Kbyte).
is it normal that it's so huge difference? It take month's to fill my 160 gig hd with this speed
Thanks in advance.
Have you checked wired connection?Originally Posted by reddevil
Is it read or write speed. Also, which firmware version you're using exactly? Is it 1.8.1.7 or 1.8.1.7-2a?When i install the firmware (1.8.1.7) than the ftp transfer speed is around 50 Kbyte. this is much lower than when i install the firmware (9.8.2.1) (ftp transfer speed : +/- 350 Kbyte).
Ok, will do.Originally Posted by xlephant
If i use the wired connection i get the same result. I'm using firmware 1.8.1.7-2a. the speed make no difference,iIt's when i upload or download files.Originally Posted by Oleg
Please try using ASUS 1.8.1.7 firmware and let me know if it works better. The only reason for me is that your hdd case has broken chipset or whatever. With usb stick I''ve 600k transfer rate.Originally Posted by reddevil
Oleg i made a mistake. here are my new results: (all in wired state, ftp, same file 12MB)Originally Posted by Oleg
firmware :
- 9.8.2.1 : upload : 250 K/s Download : 400 K/s
- 1.8.1.7 : upload : 250 K/s Downlaod : 470 K/s
- 1.8.1.7-2a : upload : 50 K/s Download : 600 K/s
So the slow speed was only at upload. sorry about that. But it's not much if you compare it with the other firmwares. And why is the upload slower than download?
Probably your case are built using the Genesys Logic chips... 1.8.1.7-2a has workarounds for it.
Take a look at this thread and
try launching and post results for this command
Code:cat /proc/scsi/usb-storage-0/0
Originally Posted by OlegCode:cat /proc/scsi/usb-storage-0/0 Host scsi0: usb-storage Vendor: Myson Century, Inc. Product: USB Mass Storage Device Serial Number: 100 Protocol: 8070i Transport: Bulk GUID: 04cf88180000000000000100 Attached: Yes
Hello
i have 2 problems with this FW
1 the bigest i canot conect o my ISP (ARCOR) with PPOE.
2 the DHCP gives my no fix IP assign to MAC
with 1.7 FW from OLeg works all fine
THX
Maik
If Arcor = "Arcor of Germany", well, no problems whatsoever here, from the very beginning (1.6.3) until now (1.8.1.7-2a).
Since the last reset to defaults (my upgrade to 1.8.1.7-1), I haven't bothered assigning a static IP address to one specific MAC; this at least used to work in the 1.7 series (of Oleg's firmware).
Ok, I will check on this.Originally Posted by reddevil
PPPoE works fine for me. Do you've anything in the logs?Originally Posted by naruto
Have you reseted unit to defaults after upgrade?
As for DHCP - manual assignment also work, be sure to clear caches on the clients.
