Hi:
Is there any English tutorial to install transmission on the wl-500gP?
I used the search button, but did not find any ..
Any help?
Regards,
J. Rosado
Hi:
Any help?
Regards,
J. Rosado
I got error on installing transmission, how can I delete torrent, thanks
[admin@ASUS root]$ ipkg install transmission
Installing transmission (0.7+r1865-1) to root...
Nothing to be done
An error ocurred, return value: 1.
Collected errors:
ERROR: The following packages conflict with transmission:
torrent
Hi:
You have to remove the torrent package
Then you can install transmissionCode:ipkg remove torrent
let me know if you can put it working..I'm not able to make it work
wengi, thanks for the link, but for some reason this guide does not work with my oleg firmware and after i followed this tutorial: http://wl500g.info/showthread.php?t=5909
My torrents file change from the source directory to the work directory, but the download never starts. Also, the gnuplot does not work. I got some strange error on the graphic plot
Did you install the better uclibc?
check this link:
http://www.nslu2-linux.org/wiki/FAQ/Optware-uClibcBuild
I have been trying to install Transmission on my WL500gP as mentioned on
http://www.nslu2-linux.org/wiki/Optware/Transmission.
But the only response I got is:
When running 'ipkg list', the list also do not mention Transmission...Code:[admin@MyAsus root]$ ipkg install transmission Nothing to be done An error ocurred, return value: 4. Collected errors: Cannot find package transmission. Check the spelling or perhaps run 'ipkg update'
Anyone who can help?
ps. I also have installed the better uclibc...
WL500gP and WD MyBook Essential Edition 500GB
How can i update transmission?
ipkg update
ipkg install transmission.
No. But have a look at this:
http://wl500g.info/showthread.php?t=9658
ipkg update filename.ipg
Thanks. It worked. The update option was not working
I used transmission with oleg's firmware, but I can't download from some tracker, they said, if torrent client send incomplete header (such as size header etc.), they will reject that requeast. Can this can fix?
Thanks,
Just tell them to support transmission!
You can try using rtorrent instead of transmission. Even the most fussy private trackers seem to allow it. It is a bit harder to use (No web interface) but it works fine.
Do a forum search for more infos
Thanks, I'll try all of advice.
I just updated Transmission to version 0.81. I believe that this version should support selective downloading, as it does on OSX. Does anyone know how to do this via the web interface or command line?
