Probably something is wrong with file permissions.
Try to run the following command:
Code:chmod 755 /opt/etc/init.d/S10cron
what version of the firmware are you using?
Please post the result of "/opt/sbin/cron" and "ls -la /opt/sbin/c*".
Also post "cat /opt/etc/init.d/S10cron".
wengi
hi wengi
I use 1.9.2.7-d-r2624
result are:
-sh: /opt/sbin/cron: Permission denied
total 8
drwxrwxrwx 2 admin root 4096 Jun 23 22:57 .
drwxr-xr-x 3 admin root 4096 Oct 21 2010 ..
# Startup script for cron
PIDFILE=/opt/var/run/cron.pid
case $1 in
start)
/opt/sbin/cron
stop)
[ -f ${PIDFILE} ] && kill `cat ${PIDFILE}` ;;
echo "usage: $0 (start|stop)"
exit 1
esac
there is no cron in /opt/sbin !!!
Did you install cron? (ipkg install cron)
wengi
ipkg install cron
Package cron (4.1-8) installed in /opt/ is up to date.
Configuring cron
Remember that the system crontab file is "/opt/etc/crontab".
usage: /opt/etc/init.d/S10cron (start|stop)
postinst script returned status 1
ERROR: cron.postinst returned 1
Nothing to be done
Successfully terminated.
Later edit: removed cron, install again, now working
thank you for support
Hello all,
I am not able to run any programs installed by ipkg. I can see the program files in /opt/bin and /opt/sbin, and can 'cat' their contents, or copy them to other places, but whenever I try to execute one of them, sh returns a 'not found' message.
This is on a WL-500gPv2, running firmware version 1.9.2.7-rtn-r3073 which I built from source. I made one small modification to the source to change a few parameters that get passed to pppd, but that is the only change I made. opt is mounted from a USB disc, and appears to be working fine in all other respects.Code:[admin@WL500 sbin]$ pwd /opt/sbin [admin@WL500 sbin]$ ls -al drwxr-xr-x 2 admin root 4096 Jul 13 10:39 . drwxr-xr-x 11 admin root 4096 Nov 13 2010 .. -rwxr-xr-x 1 admin root 72168 Oct 20 2010 cron -rwxr-xr-x 1 admin root 373004 Dec 1 2010 privoxy [admin@WL500 sbin]$ cron -sh: cron: not found [admin@WL500 sbin]$ ./cron -sh: ./cron: not found
Any thoughts ?
sounds like an uclibc problem.
Have you installed uclibc from optware?
Hi at all.
I've the WL500GP and followed the tutorial to install and configure Oleg firmware. Installed Transmission and uShare. It has worked perfectly for a couple of years, until my last firmware update with 1.9.2.7-rtn-r3300. After that (i suppose) a cannot access any more to transmission web gui at http://192.168.1.1:9091/transmission/web/ and the same for uShare. The HD is still accessible from the PC and the folder of transmission are still there.
Any suggestion? I installed a wrong version of firmware?
Thank you
just a guess.
Try "netstat -tulpen" in the shell and have a look if there is anything listening on these ports.
wengi
i really meant "-tulpen".
Unfortunately i do not have an asus router any more, so i have no idea which switches are supported.
The most important one is -ln (for listening, numeric) which lists all active ports.
Try -l and look if e.g. 9091 for transmission is listed.
wengi
Hy wengy, this is the report of netstat -l
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 WL-001E8C2D280C:netbios-ssn 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:www 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:ftp 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:domain 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5431 0.0.0.0:* LISTEN
tcp 0 0 :::laserjet :::* LISTEN
tcp 0 0 :::domain :::* LISTEN
tcp 0 0 :::telnet :::* LISTEN
udp 0 0 WL-001E8C2D280C:netbios-ns 0.0.0.0:*
udp 0 0 0.0.0.0:netbios-ns 0.0.0.0:*
udp 0 0 WL-001E8C2D280C:netbios-dgm 0.0.0.0:*
udp 0 0 0.0.0.0:netbios-dgm 0.0.0.0:*
udp 0 0 localhost.localdomain:34954 0.0.0.0:*
udp 0 0 0.0.0.0:domain 0.0.0.0:*
udp 0 0 0.0.0.0:bootps 0.0.0.0:*
udp 0 0 0.0.0.0:upnp 0.0.0.0:*
udp 0 0 :::domain :::*
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node Path
nothing with 9091....
and this is the help for netstat
Usage: netstat [-ral] [-tuwx] [-en]
Display networking information
Options:
-r Routing table
-a All sockets
-l Listening sockets
Else: connected sockets
-t TCP sockets
-u UDP sockets
-w Raw sockets
-x Unix sockets
Else: all socket types
-e Other/more information
-n Don't resolve names
transmission is not running.
try "/opt/etc/init.d/rc.unslung start" and have a look with "netstat -ln".
If there is still no port 9091 try "/opt/etc/init.d/S90transmission-daemon start" and again have a look with netstat.
If transmission is still not running:
Verify the content of /opt/etc/init.d/S90transmission-daemon with my howto and make shure it is executable (chmod 750).
Have a look at /opt/var/log/syslog.log. Are there any errors on transmission?
wengi
Thank's for your help but probably some scripts are corrupted and transmission in not running, i can't find also IPKG so i think that the best to do is to format the first 2 partitions and follow your tutorial again. I wouldn't want to loose all the files stored in the 3 partition so i will try to do everityng again without touching this partition...
Thank you
