Page 61 of 64 FirstFirst ... 11515960616263 ... LastLast
Results 901 to 915 of 958
Thread: [HowTo] Install and configure Oleg's firmware
  1. #901
    Thanks and a question or two
    Hello wengi , great tutorial i say again. I have followed your tutorial about 2 or 3 years ago when added on my wl500-gp oleg's latest firmware and now, about a week or two latest enthusiast firmware. So i thank you for your great tutorial.
    Now my questions:
    I have an HSPDA modem, ZTE MF100 from my provider DIGI. I found in the web interface a part where i can set-up a 3g modem. I managed to find correct settings for my provider, and finally after some hours of testing finally works. But when i look at my sistem log i found many errors ... this is my log :
    Jan  1 02:00:27 kernel: sda: Write Protect is off
    Jan  1 02:00:27 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:27 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:27 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:30 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:30 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:30 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:30 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:30 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:30 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:30 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:30 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:30 kernel: sda: Write Protect is off
    Jan  1 02:00:30 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:30 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:30 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:33 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:33 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:33 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:33 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:33 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:33 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:33 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:33 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:34 kernel: sda: Write Protect is off
    Jan  1 02:00:34 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:34 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:34 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:36 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:36 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:36 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:36 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:37 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:37 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:37 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:37 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:37 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:37 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:37 kernel: sda: Write Protect is off
    Jan  1 02:00:37 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:37 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:37 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:39 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:39 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:39 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:39 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:40 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:40 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:40 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:40 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:40 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:40 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:40 kernel: sda: Write Protect is off
    Jan  1 02:00:40 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:40 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:40 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:42 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:42 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:42 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:42 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:43 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:43 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:43 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:43 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:43 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:43 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:43 kernel: sda: Write Protect is off
    Jan  1 02:00:43 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:43 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:43 kernel:  unable to read partition table
    Mar 11 21:39:02 pppd[159]: System time change detected.
    Mar 11 21:39:21 ntp client: Synchronizing time with pool.ntp.org...
    My HSPDA MODEM is an ZTE MF 100 @ 3,2 Mbs. The modem has an micro sd reader and an virtual drive with drivers for windows. Should i worry about those errors?. It would trouble my hdd when i will plug it in ?? ( I followed your tutorial, installed HDD, installed all till Transmission, but i conect the hdd only when i want to download torrents, and works fine , no errors - without my hdd ).
    And second one: I normally use an PPOE Lan conection but i want to use my ZTE Modem only as a backup when the network fails. I understanded that the koppel version of oleg's firmware does that, my 1.9.2.7-d-r2624 release can do that ?
    Or at least to make a script or something when my PPOE conexion is dead, and i insert my usb 3G modem to switch the connection automatically from PPOE to USB Modem. I saw that on the web interface at 3G/CDMA Modem tab, at additional parameters i have an device initial script tab. And if an script exists can it be flashed on my router so i do not have to plug my hdd for that ?
    It would be an ideea to have my 3g modem ready, and when my ppoe conexion is dead i just plug in my modem and the router does the rest.....
    10x and waiting your answer ....
    BTW: My settings for my 3G modem to work are:
    - zero cd configuration: Auto ("Not set" is not showing errors, starts the drivers but at USB location ID i don't see any modem installed)
    - username: user
    - password : user
    - APN : internet
    - Dial number: *99#
    - Call on demand: Yes
    - USB Device location ID 1.3 (as seen in View window, tts/2 )
    - Autodetect device: Yes
    - Usb device & product id as detected
    - Usb device packet size : 0
    - Usb device serial speed: 11200
    (this values i founded on an local forum with settings for koppel 1.71 , here http://craciun.in/?p=111 )
  2. #902
    2
    And my first part of my full log is:
    Jan  1 02:00:02 syslogd started: BusyBox v1.18.3
    Jan  1 02:00:02 kernel: klogd started: BusyBox v1.18.3 (2011-02-19 10:18:57 MSK)
    Jan  1 02:00:02 kernel: CPU revision is: 00029006
    Jan  1 02:00:02 kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
    Jan  1 02:00:02 kernel: Primary data cache 16kB, 2-way, linesize 16 bytes.
    Jan  1 02:00:02 kernel: Linux version 2.4.37.11 (root@localhost) (gcc version 3.4.6) #18 2011-02-19 19:42:06 MSK
    Jan  1 02:00:02 kernel: Setting the PFC to its default value
    Jan  1 02:00:02 kernel: Determined physical RAM map:
    Jan  1 02:00:02 kernel:  memory: 02000000 @ 00000000 (usable)
    Jan  1 02:00:02 kernel: On node 0 totalpages: 8192
    Jan  1 02:00:02 kernel: zone(0): 8192 pages.
    Jan  1 02:00:02 kernel: NTFS driver v1.1.22 [Flags: R/O]
    Jan  1 02:00:02 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
    Jan  1 02:00:02 kernel: pty: 256 Unix98 ptys configured
    Jan  1 02:00:02 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
    Jan  1 02:00:02 kernel: ttyS00 at 0xb8000300 (irq = 3) is a 16550A
    Jan  1 02:00:02 kernel: ttyS01 at 0xb8000400 (irq = 3) is a 16550A
    Jan  1 02:00:02 kernel: HDLC line discipline: version $Revision: 3.7 $, maxframe=4096
    Jan  1 02:00:02 kernel: N_HDLC line discipline registered.
    Jan  1 02:00:02 kernel: loop: loaded (max 8 devices)
    Jan  1 02:00:02 kernel: PPP generic driver version 2.4.2
    Jan  1 02:00:03 dropbear[68]: Running in background
    Jan  1 02:00:03 kernel: usb.c: registered new driver usbdevfs
    Jan  1 02:00:03 kernel: usb.c: registered new driver hub
    Jan  1 02:00:03 dnsmasq[74]: started, version 2.57 cachesize 512
    Jan  1 02:00:03 dnsmasq[74]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N DHCP no-scripts no-TFTP no-IDN
    Jan  1 02:00:03 dnsmasq-dhcp[74]: DHCP, IP range 192.168.1.10 -- 192.168.1.254, lease time 1d
    Jan  1 02:00:03 dnsmasq[74]: read /etc/hosts - 2 addresses
    Jan  1 02:00:03 kernel: usb-uhci.c: $Revision: 1.275 $ time 10:23:36 Feb 19 2011
    Jan  1 02:00:03 kernel: usb-uhci.c: High bandwidth mode enabled
    Jan  1 02:00:03 kernel: PCI: Enabling device 01:03.0 (0000 -> 0001)
    Jan  1 02:00:03 kernel: UHCI: Enabling VIA 6212 workarounds
    Jan  1 02:00:03 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 12
    Jan  1 02:00:03 kernel: usb-uhci.c: Detected 2 ports
    Jan  1 02:00:03 kernel: usb.c: new USB bus registered, assigned bus number 1
    Jan  1 02:00:03 kernel: hub.c: USB hub found
    Jan  1 02:00:03 kernel: hub.c: 2 ports detected
    Jan  1 02:00:03 kernel: PCI: Enabling device 01:03.1 (0000 -> 0001)
    Jan  1 02:00:03 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 12
    Jan  1 02:00:04 kernel: usb.c: new USB bus registered, assigned bus number 2
    Jan  1 02:00:04 kernel: hub.c: USB hub found
    Jan  1 02:00:04 kernel: hub.c: 2 ports detected
    Jan  1 02:00:04 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
    Jan  1 02:00:04 kernel: PCI: Enabling device 01:03.2 (0000 -> 0002)
    Jan  1 02:00:04 kernel: ehci_hcd 01:03.2: PCI device 1106:3104
    Jan  1 02:00:04 kernel: ehci_hcd 01:03.2: irq 12, pci mem c01f2000
    Jan  1 02:00:04 kernel: usb.c: new USB bus registered, assigned bus number 3
    Jan  1 02:00:04 kernel: EHCI: Enabling VIA 6212 workarounds
    Jan  1 02:00:04 kernel: ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 10 Dec 2004/2.4
    Jan  1 02:00:04 kernel: hub.c: 4 ports detected
    Jan  1 02:00:04 kernel: usb.c: registered new driver usblp
    Jan  1 02:00:04 kernel: printer.c: v0.13: USB Printer Device Class driver
    Jan  1 02:00:04 kernel: Linux video capture interface: v1.00
    Jan  1 02:00:04 kernel: SCSI subsystem driver Revision: 1.00
    Jan  1 02:00:04 kernel: Initializing USB Mass Storage driver...
    Jan  1 02:00:04 kernel: usb.c: registered new driver usb-storage
    Jan  1 02:00:04 kernel: USB Mass Storage support registered.
    Jan  1 02:00:05 kernel: hub.c: new USB device 01:03.2-1, assigned address 2
    Jan  1 02:00:06 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
    Jan  1 02:00:06 kernel:   Vendor: ZTE       Model: MMC Storage       Rev: 2.31
    Jan  1 02:00:06 kernel:   Type:   Direct-Access                      ANSI SCSI revision: 02
    Jan  1 02:00:06 kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
    Jan  1 02:00:06 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:08 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:08 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:08 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:08 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:09 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:09 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:09 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:09 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:09 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:09 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:09 kernel: Partition check:
    Jan  1 02:00:09 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:09 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:09 kernel:  unable to read partition table
    Jan  1 02:00:15 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:15 kernel: usb.c: registered new driver acm
    Jan  1 02:00:15 kernel: acm.c: v0.23:USB Abstract Control Model driver for USB modems and ISDN adapters (patched)
    Jan  1 02:00:16 kernel: usb.c: registered new driver serial
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for Generic
    Jan  1 02:00:16 kernel: usbserial.c: Generic converter detected
    Jan  1 02:00:16 kernel: usbserial.c: Generic converter now attached to ttyUSB0 (or usb/tts/0 for devfs)
    Jan  1 02:00:16 kernel: usbserial.c: Generic converter now attached to ttyUSB1 (or usb/tts/1 for devfs)
    Jan  1 02:00:16 kernel: usbserial.c: Generic converter now attached to ttyUSB2 (or usb/tts/2 for devfs)
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial Driver core v1.4
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for PL-2303
    Jan  1 02:00:16 kernel: pl2303.c: Prolific PL2303 USB to serial adaptor driver
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for FTDI SIO
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for FTDI 8U232AM Compatible
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for FTDI FT232BM Compatible
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for FTDI FT2232C Compatible
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for FTDI FT232R Compatible
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for USB-UIRT Infrared Tranceiver
    Jan  1 02:00:16 kernel: usbserial.c: USB Serial support registered for Home-Electronics TIRA-1 IR Transceiver
  3. #903
    3
    And my 2nd part of my full log is:
    Jan  1 02:00:16 kernel: ftdi_sio.c: v1.3.5r1:USB FTDI Serial Converters Driver
    Jan  1 02:00:18 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:18 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:18 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:18 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:18 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:18 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:18 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:18 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:18 kernel: sda: Write Protect is off
    Jan  1 02:00:18 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:18 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:18 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:18 pppd[159]: pppd 2.4.5 started by admin, uid 0
    Jan  1 02:00:18 pppd[159]: Using interface ppp0
    Jan  1 02:00:18 pppd[159]: local  IP address 10.64.64.64
    Jan  1 02:00:18 pppd[159]: remote IP address 10.112.112.112
    Jan  1 02:00:19 pppd[159]: Starting link
    Jan  1 02:00:21 pppd[159]: Serial connection established.
    Jan  1 02:00:21 pppd[159]: Connect: ppp0 <--> /dev/usb/tts/2
    Jan  1 02:00:21 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:21 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:21 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:21 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:21 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:21 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:21 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:21 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:21 kernel: sda: Write Protect is off
    Jan  1 02:00:21 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:21 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:21 fstab: /dev/discs/disc0/part2 is not attached
    Jan  1 02:00:21 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:22 pppd[159]: CHAP authentication succeeded
    Jan  1 02:00:24 pppd[159]: Local IP address changed to 172.16.241.192
    Jan  1 02:00:24 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:24 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:24 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:24 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:24 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:24 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:24 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:24 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jan  1 02:00:24 kernel: sda: Write Protect is off
    Jan  1 02:00:24 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jan  1 02:00:24 kernel:  I/O error: dev 08:00, sector 0
    Jan  1 02:00:24 fstab: /dev/discs/disc0/part3 is not attached
    Jan  1 02:00:24 kernel: sda: Waiting for disc 0 to settle.
    Jan  1 02:00:25 pppd[159]: Open ICMP 172.16.241.192 -> 8.8.8.8
    Jan  1 02:00:25 dnsmasq[74]: read /etc/hosts - 2 addresses
    Jan  1 02:00:25 dnsmasq[74]: using nameserver 193.231.236.25#53
    Jan  1 02:00:25 dnsmasq[74]: using nameserver 193.231.236.30#53
    Jan  1 02:00:25 3G USB Modem: connected to ISP
    Jan  1 02:00:27 kernel: sda: Unit Not Ready, sense:
    Jan  1 02:00:27 kernel: Info fld=0x0, Current 00:00: sns = f0  2
    Jan  1 02:00:27 kernel: ASC=3a ASCQ= 0
    Jan  1 02:00:27 kernel: Raw sense data:0xf0 0x00 0x02 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x3a 0x00 0x00 0x00 0x00 0x00
    Jan  1 02:00:27 kernel: sda : READ CAPACITY failed.
    Jan  1 02:00:27 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jan  1 02:00:27 kernel: Info fld=0x0, Current sd00:00: sns = f0  2
    Jan  1 02:00:27 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    The last 20 lines are in my first post
  4. #904
    Question Problem with detection of free space on hdd
    Message of insufficient space on hdd.
    Router Asuswl500gp2, Oleg's firmware 1.9.2.7 - 10, hdd Seagate 2Tb with external power. The router settings are according to this tutorial: http://wl500g.info/showthread.php?t=10307
    I created a folder mkdir /tmp/harddisk/share, copied there about 100Gb and got a message for insufficient space on harddrive
    [admin@Wl500gp2 root]$ du s /tmp/harddisk/share
    104844952 /tmp/harddisk/share
    also mounted folder big, the problem is still there
    [admin@Wl500gp2 root]$ mkdir /tmp/mnt/disc0_3/big
    [admin@Wl500gp2 root]$ chmod ugoa+w /tmp/mnt/disc0_3/big
    there is plenty of free space on the drive:
    [admin@Wl500gp2 root]$ df
    /dev/root 3072 3072 0 100% /
    /dev/discs/disc0/part2 985720 65988 869660 7% /opt
    /dev/discs/disc0/part3 1921383312 104976180 1816407132 5% /tmp/mnt/disc0_3
    Filesystem is ext3
    [admin@Wl500gp2 root]$ mount
    none on /dev type devfs (rw)
    proc on /proc type proc (rw)
    ramfs on /tmp type ramfs (rw)
    /dev/discs/disc0/part2 on /opt type ext3 (rw,noatime)
    /dev/discs/disc0/part3 on /tmp/mnt/disc0_3 type ext3 (rw,noatime)
    How can I check if there are restrictions for folder size and what can be reasons for that?
    Why do i get a free space message and how can I fix it?
  5. #905
    Feb 2007
    your message is inconsistent. Your hdd partitions are mounted to /opt and /tmp/mnt/disc0_3, however, you test writing to /tmp/harddisk. Where /tmp/harddisk is located?
  6. #906
    Most likely it is. This is my first experience with Linux, so i don't completely understand what I am doing
    How can i check where is located this folder? /tmp/harddisk
    I also copied information to this folder: /tmp/mnt/disc0_3/big and got the same problem. Thanks for your help.
  7. #907
    Feb 2007
    /tmp/harddisk is likely a symlink. So, look at:
    ls -al /tmp/harddisk
    it would be also interesting to have a look on the output of
    fdisk -l
  8. #908
    [admin@Wl500gp2 root]$ ls -al /tmp/harddisk
    lrwxrwxrwx 1 admin root 16 Apr 9 15:18 /tmp/harddisk -> /tmp/mnt/disc0_3
    [admin@Wl500gp2 root]$ fdisk -l
    Disk /dev/scsi/host0/bus0/target0/lun0/disc: 2000.3 GB, 2000398933504 bytes
    64 heads, 32 sectors/track, 1907729 cylinders
    Units = cylinders of 2048 * 512 = 1048576 bytes
    /dev/scsi/host0/bus0/target0/lun0/part1 1 489 500720 82 Linux swap
    /dev/scsi/host0/bus0/target0/lun0/part2 490 1467 1001472 83 Linux
    /dev/scsi/host0/bus0/target0/lun0/part3 1468 18446744073709362194 18446744073514080256 83 Linux
  9. #909
    Feb 2007
    /tmp/harddisk is really pointing to the biggest partition, however, something is wrong with this record:
    You don't have that much space even if you measure it in bits. I would suggest to recreate this partition
  10. #910
    So I should create and format this partition to ext3 again? Can I do it only with this partition, or i should remake all partitions?
  11. #911
    Feb 2007
    try first to recreate only this partition
  12. #912
    ok. thank you for your help
  13. #913
    Been happily using Olegs firmware for months now (recently upgraded from 1.9.2.7-rtn-r2274 to 1.9.2.7-rtn-r2775), following this tutorial to the letter on my RT-N16. However, it nows seems I've developed an issue I can't solve.
    The transmission-daemon (2.22) process randomly stops. Restarting the transmission-daemon or rebooting within Putty starts the process again, but it will stop some time later (within the hour). Restarting the router also starts the process again but not for long.
    I've completed a full re-install of the oleg firmware which didn't help.
    Re-formatted the /opt partition and completed the configuration steps in this tutorial again which also didn't help. I'm at a loss.
    When the transmission-daemon is working I have the following processes running
    PHP Code:
    [admin@Router root]$ ps axf
      PID TTY      STAT   TIME COMMAND
        2
    ?        S<     0:00 [kthreadd]
    ?        S<     0:00  \[events/0]
    ?        S<     0:00  \[khelper]
    ?        S<     0:00  \[ksoftirqd/0]
    24 ?        S<     0:00  \[kblockd/0]
    51 ?        S      0:00  \[pdflush]
    52 ?        S<     0:00  \[kswapd0]
    53 ?        S<     0:00  \[aio/0]
    50 ?        S      0:00  \[pdflush]
    102 ?        S<     0:01  \[mtdblockd]
    231 ?        S<     0:00  \[khubd]
    296 ?        S<     0:00  \[scsi_eh_0]
    297 ?        S<     0:00  \[usb-storage]
    302 ?        S<     0:00  \[usb-storage]
    301 ?        S<     0:00  \[scsi_eh_1]
    439 ?        S<     0:00  \[kjournald]
    440 ?        S<     0:00  \[kjournald]
    441 ?        S<     0:00  \[kjournald]
    1 ttyS0    Ss+    0:00 /sbin/init
      197
    ?        Ss     0:00 klogd
      199
    ?        S      0:00 eapd
      202
    ?        S      0:00 nas
      207
    ?        Ss     0:00 telnetd
      210
    ?        S      0:00 dropbear -p 8119 -4
      486
    ?        Ss     0:02  \_ dropbear -p 8119 -4
      487 pts
    /0    Ss     0:00      \-sh
      489 pts
    /0    R+     0:00          \_ ps axf
      213
    ?        S      0:00 httpd vlan2
      218
    ?        S      0:00 dnsmasq
      244
    ?        S      0:00 lld2d br0 eth1
      393
    ?        Ss     0:00 /sbin/udhcpc -i vlan2 -/var/run/udhcpc0.pid --O routes -O staticroutes -O msstaticroutes
      395
    ?        S      0:00 pppd file /tmp/ppp/options.wan0
      396
    ?        Ss     0:00 watchdog
      423
    ?        S      0:00 upnp --L br0 -W ppp0
      444
    ?        Ss     0:00 /usr/sbin/vsftpd
      446
    ?        Ss     0:00 /usr/sbin/nmbd -D
      448
    ?        Ss     0:00 /usr/sbin/smbd -D
      464
    ?        Ss     0:00 /sbin/syslogd -m 0 -/opt/var/log/syslog.log --l 7 -s 0
      469
    ?        Ss     0:00 /opt/sbin/cron
      475
    ?        SN     0:00 /opt/bin/transmission-daemon -/tmp/harddisk/transmission/config
      476
    ?        SN     0:00  \/opt/bin/transmission-daemon -/tmp/harddisk/transmission/config
      477
    ?        RN     0:44      \/opt/bin/transmission-daemon -/tmp/harddisk/transmission/config
      478
    ?        RN     0:01      \/opt/bin/transmission-daemon -/tmp/harddisk/transmission/config
      479
      480
    ?        RN     0:42      \/opt/bin/transmission-daemon -/tmp/harddisk/transmission/config
    When the transmission-daemon is not working the following processes are running.
    PHP Code:
        2
    52 ?        S<     0:05  \[kswapd0]
    102 ?        S<     0:02  \[mtdblockd]
      197
    ?        Ss     0:00 klogd
      199
    ?        S      0:00 eapd
      202
    ?        S      0:00 nas
      207
    ?        Ss     0:00 telnetd
      210
      522
      523 pts
    /0    Ss     0:00      \-sh
      524 pts
      213
      218
    ?        S      0:00 dnsmasq
      244
      393
      395
      396
    ?        Ss     0:00 watchdog
      423
      444
      446
      448
      464
      469
    When restarting transmission-daemon within Putty I get the following from the System Log on the router
    PHP Code:
    Apr 28 20:05:55 rc.unslungstop service /opt/etc/init.d/S90transmission-daemon
    Apr 28 20
    :05:55 rc.unslungstop service /opt/etc/init.d/S10cron
    Apr 28 20
    :05:55 rc.unslungstop service /opt/etc/init.d/S05syslogd
    Apr 28 20
    :05:55 syslogd exiting
    Jan  1 11
    :00:04 syslogd startedBusyBox v1.18.3
    It almost gives you the impression that transmission is still running when doing the restart
    When restarting the transmission-daemon within Putty I get the following from the System Log on the router
    PHP Code:
    Apr 28 20:31:30 transmission-daemon[541]: Blocklist "level1.bin" updated with 220131 entries (blocklist.c:421)
    Apr 28 20:31:30 transmission-daemon[541]: Blocklist "level1.bin" contains 220131 entries (blocklist.c:114)
    Apr 28 20:31:30 transmission-daemon[541]: Transmission 2.22 (12099started (session.c:708)
    Apr 28 20:31:30 transmission-daemon[541]: RPC Server Adding address to whitelist127.0.0.1 (rpc-server.c:807)
    Apr 28 20:31:30 transmission-daemon[541]: RPC Server Adding address to whitelist192.168.1.* (rpc-server.c:807)
    Apr 28 20:31:30 transmission-daemon[541]: RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:985)
    Apr 28 20:31:30 transmission-daemon[541]: RPC Server Whitelist enabled (rpc-server.c:989)
    Apr 28 20:31:30 transmission-daemon[541]: Port Forwarding Stopped (port-forwarding.c:183)
    Apr 28 20:31:30 transmission-daemon[541]: DHT Generating new id (tr-dht.c:306)
    Apr 28 20:31:30 transmission-daemon[541]: Using settings from "/tmp/harddisk/transmission/config" (daemon.c:498)
    Apr 28 20:31:30 transmission-daemon[541]: Saved "/tmp/mnt/disca_3/transmission/config/settings.json" (bencode.c:1716)
    I fear my limited knowledge is preventing me from getting to the bottom of this one and therefore request help. If there are other outputs you wish to see let me know and I'll provide. Thanks in advance for any assistance you can provide.
  14. #914
    In addition to my last, I suspect my problem relates to the conflict between transmission and libevent (after some research). Now I need to amend /opt/etc/init.d/S90transmission-daemon to include export EVENT_NOEPOLL=1. Any tips on where I should Include the line of code?
  15. #915
    hi all
    I need some help
    it seems that cron is not starting
    [admin@topex root]$ ps axf
    1 ? S 0:01 /sbin/init
    2 ? S 0:00 [keventd]
    3 ? RN 0:00 [ksoftirqd_CPU0]
    4 ? S 0:00 [kswapd]
    5 ? S 0:00 [bdflush]
    6 ? S 0:00 [kupdated]
    7 ? S 0:00 [mtdblockd]
    58 ? Ss 0:00 syslogd -m 0 -O /tmp/syslog.log -S -D -l 7 -b 1
    62 ? Ss 0:00 klogd
    63 ? Ss 0:00 telnetd
    69 ? Ss 0:00 nas /tmp/nas.lan.conf /tmp/nas.lan.pid lan
    72 ? S 0:00 httpd vlan1
    73 ? S 0:00 dropbear -4
    136 ? Ss 0:00 \_ dropbear -4
    137 pts/0 Ss 0:00 \_ -sh
    138 pts/0 R+ 0:00 \_ ps axf
    75 ? S 0:00 lld2d br0 eth1
    78 ? S 0:00 dnsmasq
    76 ? S 0:00 [khubd]
    94 ? Ss 0:00 pppd file /tmp/ppp/options.wan0
    96 ? Ss 0:00 watchdog
    103 ? S 0:00 [usb-storage-0]
    104 ? S 0:00 [scsi_eh_0]
    118 ? S 0:00 [kjournald]
    119 ? S 0:00 [kjournald]
    121 ? Ss 0:00 /usr/sbin/nmbd -D
    123 ? Ss 0:00 /usr/sbin/smbd -D
    131 ? S 0:00 \_ /usr/sbin/smbd -D
    132 ? S 0:00 \_ /usr/sbin/smbd -D
    if I do /opt/etc/init.d/rc.unslung start
    I get following error
    /opt/etc/init.d/S10cron: line 16: /opt/sbin/cron: Permission denied
    can please someone show what i do wrong
    thank you
  1. [Howto] Install DLNA media servers for Oleg firmware
    By ecaddict in forum WL-500gP Tutorials
    Last Post: 06-06-2017, 07:40
  2. Replies: 24
    Last Post: 05-05-2015, 07:42
  3. Replies: 28
    Last Post: 02-06-2013, 20:58
  4. Replies: 6
    Last Post: 21-09-2012, 17:06
  5. [Howto] Install kernel modules for Oleg firmware
    Last Post: 05-12-2011, 16:18
