I did not built transmission on the router. I do not have uclibc-opt installed.
such message:
means some library incompatibility. One or more of the libraries on which transmission depends is wrong. You might get a list of it's dependencies using ldd utility (which is a part of buildroot), or just reinstall uclibc-opt as a most likely source of the problemCode:-sh: XXX: not found
Code:[admin@router root]$ ipkg list_installed bash - 3.2.17-1 - A bourne style shell bzip2 - 1.0.4-1 - Very high-quality data compression program cron - 4.1-6 - Standard vixie cron, with cron.d addition e2fsprogs - 1.40.2-1 - Ext2 Filesystem Utilities expat - 2.0.1-1 - XML Parser library fontconfig - 2.3.2-5 - Font configuration library freetype - 2.1.10-4 - Free truetype library gconv-modules - 2.2.5-7 - Provides gconv modules missing from the firmware. These are used by glibc's iconv() implementation. gdbm - 1.8.3-2 - GNU dbm is a set of database routines that use extensible hashing. It works similar to the standard UNIX dbm routines. gnuplot - 4.2.0-5 - Command-line driven interactive data and function plotting utility groff - 1.19.2-2 - front-end for the groff document formatting system hdparm - 6.9-1 - Linux hard drive parameter utility ipkg - 0.99.149-2 - lightweight package management system less - 394-3 - Less file browser libart - 2.3.17-2 - 2-d graphics library. libcurl - 7.17.0-2 - Curl is a command line tool for transferring files with URL syntax, supporting FTP, FTPS, HTTP, HTTPS, GOPHER, TELNET, DICT, FI libdb - 4.2.52-3 - Berkeley DB Libraries libevent - 1.3d-1 - libevent to implement an event loop libgd - 2.0.35-1 - An ANSI C library for the dynamic creation of images libiconv - 1.11-2 - Converts between character encodings. libjpeg - 6b-2 - collection of jpeg tools libmemcache - 1.4.0.rc2-2 - The C API for memcached. libpng - 1.2.21-1 - Portable Network Graphics Libraries libuclibc++ - 0.1.12-4 - C++ standard library designed for use in embedded systems libxml2 - 2.6.30-1 - Libxml2 is the XML C parser and toolkit developed for the Gnome project. libxslt - 1.1.22-1 - An XML Stylesheet processor based on libxml2 lua - 5.1.2-1 - Lua is a powerful light-weight programming language designed for extending applications. man - 1.5p-4 - unix manual page reader man-pages - 2.33-3 - unix manual pages mc - 4.1.35-3 - memcached - 1.2.0-4 - memcached is a high-performance, distributed memory object caching system. nano - 2.0.6-1 - A pico like editor ncurses - 5.6-1 - NCurses libraries openssl - 0.9.7m-3 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari pcre - 7.4-1 - Perl-compatible regular expression library php - 5.2.4-1 - The php scripting language php-thttpd - 2.25b-5.2.4-4 - php-thttpd is thttpd webserver with php support procps - 3.2.3-4 - PROCPS System Utilities readline - 5.2-2 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are rrdtool - 1.2.23-2 - Round-Robin Database tool. Database collator and plotter screen - 4.0.3-2 - A screen manager that supports multiple logins on single terminal sqlite - 3.4.1-1 - SQLite is a small C library that implements a self-contained, embeddable, zero-configuration SQL database engine. tar - 1.16.1-1 - heavyweight version of the Tape ARchiver termcap - 1.3.1-2 - Terminal emulation library transmission - 1.75-1 - unzip - 5.52-1 - A (de)compression library for the ZIP format zlib - 1.2.3-2 - zlib is a library implementing the 'deflate' compression system.
well, I've no idea how the rest might work without uclibc-opt. May be you just try to install it?
how to install it ? ipkg does not find it.
Well, this line:
allows me to suggest that you use wrong 'old' repository for the files. In correct setup it should be read as:Code:ipkg - 0.99.149-2 - lightweight package management system
Please, post your /opt/etc/ipkg.conf file. Read section 6 of this thread. However, after updating of the ipkg.conf you have to reinstall all packages.Code:ipkg-opt ...
this is it:
Code:[admin@router root]$ cat /opt/etc/ipkg.conf src wl500g http://wl500g.dyndns.org/ipkg src unslung http://ipkg.nslu2-linux.org/feeds/unslung/wl500g dest root /
Yes, I'm right. The correct content of this file is:
However, after changing it you have to reinstall all packages. It is default repository since 1.9.2.7-8. May be you have older version of the firmware?Code:src/gz optware http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable dest /opt/ /
Thanks al37919!
That was the main problem. I have started all over from the beginning and now it works!!!
hi ! i\m complete newbee and im trying to follow steps of this tutorial
adn here is what i get at step 4
how can i umount /tmp ?Code:[WL-001Droot]$ df Filesystem 1K-blocks Used Available Use% Mounted on /dev/root 3072 3072 0 100% / tmpfs 15080 148 14932 1% /tmp [admin@WL-001D60E4B744 root]$
here is what i get from ps
wbr madaceCode:root]$ ps PID USER VSZ STAT COMMAND 1 admin 1308 S /sbin/init 2 admin 0 SW [keventd] 3 admin 0 SWN [ksoftirqd_CPU0] 4 admin 0 SW [kswapd] 5 admin 0 SW [bdflush] 6 admin 0 SW [kupdated] 7 admin 0 SW [mtdblockd] 55 admin 1520 S telnetd 60 admin 1100 S httpd vlan1 61 admin 1524 S syslogd -m 0 -O /tmp/syslog.log -S -l 7 -b 2 64 admin 1520 S klogd 66 admin 1072 S nas /tmp/nas.lan.conf /tmp/nas.lan.pid lan 71 nobody 836 S dnsmasq 69 admin 0 SW [khubd] 90 admin 1532 S udhcpc -i vlan1 -p /var/run/udhcpc0.pid -s /tmp/udhcp 93 admin 1264 S pppd file /tmp/ppp/options.wan0 95 admin 892 S infosvr br0 96 admin 1308 S watchdog 114 admin 1048 S upnp -D -L br0 -W ppp0 115 admin 1096 S dropbear 119 admin 1528 S -sh 121 admin 1524 R ps
Hi
First, THANK YOU!! GREAT Tutorial
I'm using a wl500gp v1, with oleg's 1.9.2.7-10, i follow the tutorial and everything is running great (i think so), i use Samba2 and transmission with no problems, my question is, when do the ls -al command i only get this:
[aesir@TSRT01 root]$ ls -al
total 0
drwx------ 1 aesir root 0 Jan 1 2000 .
drwxr-xr-x 1 aesir root 0 Jan 25 2008 ..
I read the forum and i find out that, i should get this instead:
[admin@WL-ASUSAP sbin]$ ls -al
drwxr-xr-x 1 admin root 0 Mar 23 19:24 .
drwxr-xr-x 1 admin root 0 Jan 1 2000 ..
-rwxr-xr-x 1 admin root 575 Mar 23 19:34 post-boot
-rwxr-xr-x 1 admin root 0 Mar 23 19:24 post-firewall
-rwxr-xr-x 1 admin root 0 Mar 23 19:24 post-mount
-rwxr-xr-x 1 admin root 0 Mar 23 19:24 pre-shutdown
is that correct? is something missing in my config?
Thank you all, in advance
@madace:
/tmp does NOT need to be unmounted. Everything is fine and you can simply go on with the tut.
You found a difference between the older and newer firmwares. Thats all.
I updated the Howto.
@genjuro
The listing you receive depends on the location you are.
Try the command "pwd" to see your actual loacation in the file system.
As you can see in your posting you did the ls command in the root folderwhich is the home of root.Code:aesir@TSRT01 root
The other ls is done inwhich is, i guess, /usr/local/sbin/Code:admin@WL-ASUSAP sbin
Try a "ls -ls /usr/local/sbin/" on your router
Btw: This is linux basics and has nothing to do with the router at all.
wengi
Hi
Thank you wengi, you are right .... i was in the wrong directory, now my output is just like the other, and the files are in another color, that should mean that they are executable , and everything is ok...
see ya...
Dear all,
First of all.... i'm such a noob and a newbie, but, i kind of want this to work.
I am good at directions so,.. i will take good directions
I'm stuck at this step:
"mkdir /opt/etc
mkdir /opt/etc/init.d
vi /opt/etc/init.d/rc.unslung"
"Remark: If you get a "mkdir: Cannot create directory `/opt/etc': Read-only file system" your HDD (here the IPKG pertition) is NOT mounted."
I have this error, and i don't know what to do next! please help me!
