@coolerstuff
DOUBLE POST!
Please do not use this thread.
wengi
Have Olegs FW 1.9.2.7-10 on WL-500g Premium
When logged into the router I can ping the local IP of my printer which is 192.168.1.165
when I am on another PC (192.168.1.100) I cannot reach / ping 192.168.1.165
What is wrong in the config???
Any help much appreciated
@coolerstuff
DOUBLE POST!
wengi
What must press key to save and close? (vi / etc / fstab) ??
Sorry do not know very well English.
Chapter 4:
-> ESC, ":wq"You enter the insert mode with i, you leave it with ESC.
After leaving the insert mode you quit and save by typing ':wq'.
wengi
Can I configure (and how) /tmp/harddisk/transmission/config/settings.json that transmission will download each torrent to separate folder.
Tedy
http://trac.transmissionbt.com/wiki/EditConfigFiles
rtfm.
I have no idea if it is possible.
wengi
I have browse this page before, but haven't found solution, so I have posted question here.
Before I have run old transmission, now I have installed new Transmission Web Interface. With old one this was done automatic.
My mistake. There is no problem with folders, I have download torrents that are pointed to one file like *.avi for example, when I download torrent that has multiple files in folders like DVD movie, they are put in seperate folders.
@wengi, i have hundreds and hundreds of messages like this. how can i stop this attacks ?Code:Nov 15 00:00:22 dropbear[851]: login attempt for nonexistent user from 61.138.179.55:57796 Nov 15 00:00:23 dropbear[851]: exit before auth: Disconnect received Nov 15 00:00:27 dropbear[852]: login attempt for nonexistent user from 61.138.179.55:59213 Nov 15 00:00:28 dropbear[852]: exit before auth: error reading: Connection reset by peer Nov 15 00:00:32 dropbear[853]: login attempt for nonexistent user from 61.138.179.55:60606 Nov 15 00:00:33 dropbear[853]: exit before auth: Disconnect received Nov 15 00:00:37 dropbear[854]: login attempt for nonexistent user from 61.138.179.55:33366 Nov 15 00:00:38 dropbear[854]: exit before auth: Disconnect received
Hi
Great tutorial! I m in section 17. (Optimize performance), and I want to delete modules has unnecessary.exemple: printer.write this command "rmmod printer" and after reboot is back printer.I can delete this module forever?
I m sorry for my english
last sentence in this chapter:So try something likeAfter knowing the possible modules you can edit the post-boot and paste the unload commands.to make it permanent.Code:echo "rmmod xxxxxx" >> /usr/local/sbin/post-boot
wengi
After a few weeks of trying I finally decided to post since I am not able to install transmission on my WL-500g.
I have a HDD attached via USB and partitioned like this:
I have installed transmission - 1.75-1. All the files seem to be ok:Code:Filesystem 1k-blocks Used Available Use% Mounted on /dev/root 3008 3008 0 100% / /dev/discs/disc0/part2 988244 93504 844540 10% /opt /dev/discs/disc0/part3 479478544 144144 454978256 0% /tmp/mnt/disc0_3
My S90transmission-daemon looks like this:Code:[admin@router root]$ ls -al /opt/bin/transmission* -rwxr-xr-x 1 admin root 619920 Sep 14 19:57 /opt/bin/transmission-daemon -rwxr-xr-x 1 admin root 651164 Sep 14 19:57 /opt/bin/transmission-remote -rwxr-xr-x 1 admin root 628180 Sep 14 19:57 /opt/bin/transmissioncli
Rights on these files look like this:Code:[admin@router root]$ cat /opt/etc/init.d/S90transmission-daemon #!/bin/sh # # Startup script for transmission export PATH=$PATH:/opt/bin:/opt/sbin HOME=/tmp case $1 in start) # start transmission echo "starting transmission" >> /tmp/syslog.log nice /opt/bin/transmission-daemon /tmp/harddisk/transmission/config ;; stop) if [ -n "`pidof transmission-daemon`" ]; then echo "stopping transmission" kill -9 `pidof transmission-daemon` fi ;; restart|force-reload) $0 stop sleep 1 $0 start ;; *) echo "usage: $0 (start|stop|restart|force-reload)" exit 1 esac
But, when I run it, I get this:Code:[admin@router root]$ ls -al /opt/etc/init.d/ drwxr-xr-x 2 admin root 4096 Jan 18 10:00 . drwxr-xr-x 11 admin root 4096 Jan 18 10:06 .. -rwxr-xr-x 1 admin root 284 Jan 6 07:32 S10cron -rwxr-xr-x 1 admin root 809 Sep 9 2007 S80lighttpd -rwxr-xr-x 1 admin root 610 Jan 18 09:52 S90transmission-daemon -rwxr-xr-x 1 admin root 522 Jun 6 2005 rc.unslung
Even if I try to start directly the transmission-daemon I get the same error, that it does not exist. The file exists, but somehow I get this error and I can't get past this.Code:[admin@router root]$ /opt/etc/init.d/S90transmission-daemon start nice: transmission-daemon: No such file or directory
PLEASE HELP!
is transmission working if you start it manually?
without nice!Code:/opt/bin/transmission-daemon /tmp/harddisk/transmission/config
wengi
Still doesn't work:
Code:[admin@router root]$ /opt/bin/transmission-daemon /tmp/harddisk/transmission/config -sh: /opt/bin/transmission-daemon: not found
