Page 43 of 64 FirstFirst ... 33414243444553 ... LastLast
Results 631 to 645 of 958
Thread: [HowTo] Install and configure Oleg's firmware
  1. #631
    Feb 2005
    Germany - Frankfurt
    you could give openvpn a try.
    Search the forum for openvpn.
    wengi
  2. #632
    OVPN
    OVPN has been seted up and it's working ( from local laptop). Later will try from WAN.
  3. #633
    OVPN
    Yes. It's working great
  4. #634
    I want to post a custom message when logging in with putty, how do i do that?
    Please excuse me if this was discussed before and please link me to the topic or posts, but my internet connection is working painfully slow today and when i try to search for this i did not receive results.
    Thank you.
  5. #635
    Feb 2007
  6. #636
    Feb 2005
    Germany - Frankfurt
    Hello,
    this is a general linux question.
    Have alook at:
    http://linux.about.com/library/cmd/blcmdl5_issue.htm
    http://linux.about.com/library/cmd/blcmdl5_motd.htm
    issue is pre-login, motd is post-login.
    wengi
  7. #637
    FTP login
    wtf is this
    Apr 20 14:00:49 vsftpd[1562]: [Administrator] FAIL LOGIN: Client "210.82.111.91"
    Apr 20 14:00:51 vsftpd[1562]: [Administrator] FAIL LOGIN: Client "210.82.111.91"
    Apr 20 14:00:53 vsftpd[1562]: [Administrator] FAIL LOGIN: Client "210.82.111.91"
    Apr 20 14:00:55 vsftpd[1565]: CONNECT: Client "210.82.111.91"
    Apr 20 14:00:56 vsftpd[1564]: [Administrator] FAIL LOGIN: Client "210.82.111.91"
    Apr 20 14:00:58 vsftpd[1564]: [Administrator] FAIL LOGIN: Client "210.82.111.91"
    Apr 20 14:01:00 vsftpd[1564]: [Administrator] FAIL LOGIN: Client "210.82.111.91"
    in web syslog I see, that someone has trayed to connect to my ftp from Apr 20 14:00:20 till Apr 20 14:24:28
    how I can block that f*** IP address?
    P.S. I don't have username "Administrator" for my ftp.
    It would be silly
    P.S.S. this isn't first time, when someone is traying to connect.
  8. #638
    Feb 2005
    Germany - Frankfurt
    Hi all,
    i added a step to correct the time zone settings for middle europe.
    search the howto for "pre-boot" and you will find the additions.
    wengi
  9. #639
    Permission denied when i try to install new package
    Hi all,
    pls I have still problem with permission denied when i try:
    [admin@ASUS_160GB ipkg]$ ipkg update
    Downloading http://ipkg.nslu2-linux.org/feeds/op...le/Packages.gz
    sh: wget: Permission denied
    An error ocurred, return value: 1.
    Collected errors:
    ipkg_download: ERROR: Command failed with return value 127: `wget -q -P /opt/ipkg-4TwonM http://ipkg.nslu2-linux.org/feeds/op...le/Packages.gz'
    [admin@ASUS_160GB ipkg]$ ipkg upgrade
    sh: rm: Permission denied
    Nothing to be done
    Successfully terminated.
    I posted here at this thread before (read page 38, posts 559-569) but still have this problem.
    I am really newbie with linux so Wengi pls can you write me how to use e2fsck on /dev/discs/disc0/part2??? Dont know how to operate with superblocks etc.
    Second dont know if check is necessary because i can create dir on /opt and can copy files in it. So I can write to /opt.
    Any idea how to fix this permission denied problem? After finished this tutorial it forks for half year without problems.
  10. #640
    Neither I cannot do this if I want any change:
    here is post:
    [admin@ASUS_160GB tmp]$ flashfs save && flashfs commit && flashfs enable && reboot
    /sbin/flashfs: /sbin/flashfs: 20: cat: Permission denied
    /sbin/flashfs: /sbin/flashfs: 73: [: Permission denied
    tar: Removing leading '/' from member names
    tar: /tmp/local: Unknown file type
    tar: Error exit delayed from previous errors
    /sbin/flashfs: /sbin/flashfs: 73: ls: Permission denied
  11. #641
    Feb 2007
    Something is wrong in your flashfs.
    Disable it:
    PHP Code:
    nvram set boot_local=""
    nvram commit
    reboot
    Then check again, e.g. with
    PHP Code:
    flashfs status
    If it responds, load it without execution:
    PHP Code:
    flashfs load
    and search for the error in flashfs
    Related Russian thread: http://wl500g.info/showthread.php?t=18949
    P.S. one of the guesses: return LD_LIBRARY_PATH to the default value if it was updated in flashfs
  12. #642
    Ehm but I cant read Russian
    flashfs status gives me all Permission denied
    How can I search for errors in flashfs?
  13. #643
    Feb 2007
    Quote Originally Posted by Etor View Post
    even after disbling it?
    using common sense --- e.g. comment [or remove] everything and then uncomment file-by-file, line-by-line
  14. #644
    Norway
    What if...I use a usb flash drive for the swap area, and the HDD only for share files, and attach them both to the router via a usb hub? I guess the HDD would not spin up by transmission then, since the activity caused by daemon (and transmission) goes to the usb flash drive?
    Quote Originally Posted by wengi View Post
    Start and stop it manually.
    No other way because the daemon hosts the webinterface.
    wengi
  15. #645
    Hi all,
    Collected errors:
    Nothing to be done
    I have the same problem with e2fsck:
    my ASUs says:
    kernel: EXT3-fs warning: mounting fs with errors, running e2fsck is recommended.
    so how to use e2fsck?
    Thank You
  1. [Howto] Install DLNA media servers for Oleg firmware
    By ecaddict in forum WL-500gP Tutorials
    Last Post: 06-06-2017, 08:40
  2. Replies: 24
    Last Post: 05-05-2015, 08:42
  3. Replies: 28
    Last Post: 02-06-2013, 21:58
  4. Replies: 6
    Last Post: 21-09-2012, 18:06
  5. [Howto] Install kernel modules for Oleg firmware
    Last Post: 05-12-2011, 17:18
