Page 40 of 64 FirstFirst ... 30383940414250 ... LastLast
Results 586 to 600 of 958
Thread: [HowTo] Install and configure Oleg's firmware
  1. #586
    i found this solution, is ok???
    Increasing the table size
    The maximum number of connections tracked can be found by:
    cat /proc/sys/net/ipv4/netfilter/ip_conntrack_max
    4096
    Time to double to number of connections that the table can track:
    nano /etc/sysctl.conf
    and add the line
     net.ipv4.netfilter.ip_conntrack_max = 131072
    reload the sysctl.conf
    sysctl -p
    and result:
  2. #587
    Feb 2007
    you can edit this value from the web-interface in the firewall -> basic config
    I'd suggest you to research this topic more seriously, because this conntrack table takes RAM. For such device with pretty limited memory 128K imho is too huge table
  3. #588
    Hello!
    Quote Originally Posted by kaizen View Post
    Where have you found this firmware?
    Last "original" oleg is WL500gp-1.9.2.7-10.trx
    Try this.
    Thank you, Kaizen!
    I have installed this firmware and it seems to be a stable version. It is just enough for what I need. And wireless driver perform very well. Next week I will test it with lot of optware packages. I want to stop services and start'em when I need with xinetd to keep RAM memory free.
    By the way, does anybody knows command line switches to start web interface and pass them to xinetd?
  4. #589
    Oleg Powered Wireless
    I think that's good for OLEG firmware to have an motd login (as OpenWRT and DD-WRT does).
    And motd should be like so. So put file motd (without the extension ".txt") in /etc folder, edit /usr/local/.files and add "/etc/motd", save flash with "flashfs save && flashfs commit && flashfs enable && reboot". When log with dropbear, after login, logo will apear in console window.
    To put the file on the router, I recommend using WinSCP (is freeware and "a must use" )
    So, "OLEG powered WL"
  5. #590
    Feb 2007
    it's impossible, and to kill it either
  6. #591
    Progress but not success
    if you enable samba in the web-interface then /etc/smb.conf is automatically generated based on the settings in it every time you start router. So if you wish to customize smb.conf --- disable samba in web-interface and run from post-boot something like:
    PHP Code:
    /usr/sbin/smbd -d
    /usr/sbin/nmbd -
    I added the 2 lines to post-boot (but it's "smbd -D" and "nmbd -D" as lowercase "-d" is for debug level) and disabled samba in the webinterface. Did the flashfs commit save reboot thing but samba didn't load on reboot - those processes didn't appear in the list from ps axf. But, if I manually run post-boot from the command line, samba is loaded and runs fine.
    It seems post-boot isn't running after the boot - is that possible? Since I can run post-boot from the command line, it seems it's executable. The only difference from straight wengi tut is I have the swap on USB stick on disc1 and USB HDD for shared storage on disc0.
    Any ideas?
  7. #592
    put it in post-mount
    it probably starts from post-boot, but exits directly cause it's missing the harddisk
  8. #593
    Feb 2007
    thanks for the correction
    you can make sure that post-boot is executed by adding to it:
    PHP Code:
    logger -t post-boot "$* started."
    afterwards you can check presence of this line in the syslog.
    I'm not sure if the storage should be mounted to run samba (when post-boot is executed possibly it is not running yet). So, try to put it in the post-mount
    If post mount could be executed multiple times better approach could be:
    PHP Code:
    killall smbd && /usr/sbin/smbd -
    DrChair: you was faster than me
  9. #594
    Quote Originally Posted by DrChair View Post
    This worked, thanks.
    al37919, I didn't add the extra code you suggested, I don't understand what it tries to do - but it seems just having smbd -D and nmbd -D in post-mount does what I need. Is there a reason I need that additional code?
    Also, I stuck the logger code in both post-boot and post-mount. post-mount wrote to the syslog, but post-boot did not!? It seems like I have an issue with post-boot running, right? Any ideas on how to troubleshoot this/fix?
    Thank you for your help and responsiveness!
  10. #595
    transmission stopped responding
    hi! my provider has changed connection from pptp to ppoe and after that transmission stoped transers. it accesable wia web interface but shows 0 transers. what can be the source of the problem?
     PID TTY      STAT   TIME COMMAND
        1 ?        S      0:01 /sbin/init
        2 ?        S      0:00 [keventd]
        3 ?        SN     0:00 [ksoftirqd_CPU0]
        4 ?        S      0:00 [kswapd]
        5 ?        S      0:00 [bdflush]
        6 ?        S      0:00 [kupdated]
        7 ?        S      0:00 [mtdblockd]
       57 ?        S      0:00 telnetd
       62 ?        S      0:01 httpd vlan1
       68 ?        S      0:00 klogd
       71 ?        Ss     0:01 nas /tmp/nas.lan.conf /tmp/nas.lan.pid lan
       73 ?        S      0:00 [dnsmasq]
       75 ?        S      0:00 [khubd]
       84 ?        Ss     0:00 lpd
       86 ?        Ss     0:00 p9100d -f /dev/usb/lp0 0
       89 ?        Ss     0:00 waveservermain
       91 ?        Ss     0:00 rcamdmain
       95 ?        S      0:00 [usb-storage-0]
       96 ?        S      0:00 [scsi_eh_0]
      103 ?        S      0:00 [portmap]
      105 ?        Ss     0:00 /usr/sbin/statd
      107 ?        S      0:00 [nfsd]
      108 ?        S      0:00 [lockd]
      109 ?        S      0:00  \_ [rpciod]
      111 ?        Ss     0:00 /usr/sbin/mountd
      126 ?        S      0:00 udhcpc -i vlan1 -p /var/run/udhcpc0.pid -s /tmp/udhcp
      127 ?        Ss     0:00 pppd file /tmp/ppp/options.wan0
      129 ?        Ss     0:00 infosvr br0
      130 ?        Ss     0:00 watchdog
      133 ?        Ss     0:00  \_ ntp
      147 ?        S      0:00 dropbear
      238 ?        Ss     0:00  \_ dropbear
      239 pts/1    Ss     0:00      \_ -sh
      243 pts/1    R+     0:00          \_ ps axf
      156 ?        S      0:01 upnp -D -L br0 -W ppp0
      172 ?        S      0:00 [kjournald]
      173 ?        S      0:00 [kjournald]
      201 ?        S      0:00 /sbin/syslogd -m 0 -O /opt/var/log/syslog.log -S -l 7
      207 ?        Ss     0:00 /opt/sbin/cron
      232 ?        S      0:08 /opt/bin/transmission-daemon -g /tmp/harddisk/transmi
      233 ?        S      0:00  \_ /opt/bin/transmission-daemon -g /tmp/harddisk/tra
      234 ?        S      0:20      \_ /opt/bin/transmission-daemon -g /tmp/harddisk
      237 ?        R     19:19 vi /opt/etc/init.d/S05syslogd
  11. #596
    Hello Kaizen!
    Try this.
    I installed from your link WL500gpv2-1.9.2.7-d-r160.trx
    That's OK. I see in this firmware lot of good things:
    - kernel update to "Linux version 2.4.37";
    - SSH configuration from webif;
    - firewall configuration for "brute force attacks" from webif (although when I "iptables-save > /opt/tmp/iptables" - I cannot see rules installed )
    Big problem:
    I test swap working with "ipkg remove perl" + "ipkg install perl" and give in another putty window command "watch -n 1 free". So, swap memory does not entered working state (it is showed up, but not used). In time of perl installation free memory decrease till 500kb!
    The same test I do with "WL500gpv2-1.9.2.7-10.7.trx" and in time of installation process swap begins swapping.
    I see in log file some brute force attacks for SSH and FTP servers and trying to limit FTP logon incoming connections:
    iptables -I INPUT 1 -p tcp -m tcp --dport 21 -m state --state NEW -m recent  --set
    iptables -I INPUT 2 -p tcp -m tcp --dport 21 -m state --state NEW -m recent --update --seconds 180 --hitcount 5 -j DROP
    But in both firmware versions it seems that we have no support:
    iptables: No chain/target/match by that name
  12. #597
    I'll answer to myself:
    So, there is iptables module to insert to make these commands available: ipt_recent.o
  13. #598
    Feb 2007
    in 1.9.2.7-d this module should be loaded automatically and rules added to INPUT chain if wan access to ssh or ftp server is enabled in the web-interface and corresponding bruteforce protection option is selected
  14. #599
    Problem with Samba
    First,
    thanks for really great HOW TO, it helped me, because I'm linux beginner.
    Anyway now I stucked on problem with samba. It showes me that my shares are only 20MB big, although my 3rd partition is 450GB big. I really don't know how to solve it. I searched nearly the whole internet
    Help will be greatly appreciated.
    Thanks Jakub
  15. #600
    What is that????
    Reading log file I found that:
    Mar 17 01:38:44 pure-ftpd: (?@115.168.51.137) [INFO] New connection from 115.168.51.137
    Mar 17 01:38:45 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:38:49 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:38:57 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:39:08 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:39:21 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:39:37 pure-ftpd: (?@115.168.51.137) [ERROR] Too many authentication failures
    Mar 17 01:39:41 pure-ftpd: (?@115.168.51.137) [INFO] New connection from 115.168.51.137
    Mar 17 01:39:42 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:39:47 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:39:55 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:40:06 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:40:21 pure-ftpd: (?@115.168.51.137) [WARNING] Authentication failed for user [oracle]
    Mar 17 01:40:38 pure-ftpd: (?@115.168.51.137) [ERROR] Too many authentication failures
    And these tryies are listing for about an hour, every second (they tryied user mysql,apache and test too)!!!
    But I have inserted correct rules in /usr/local/sbin/post-firewall:
    iptables -I INPUT 2 -p tcp -m tcp --dport 21 -m state --state NEW -m recent --update --seconds 160 --hitcount 8 -j DROP
    These rules, I find'em too when do "iptables -nL INPUT". The same rules.
    Chain INPUT (policy ACCEPT)
    target     prot opt source               destination
               tcp  --  0.0.0.0/0            0.0.0.0/0          tcp dpt:21 state NEW recent: SET name: DEFAULT side: source
    DROP       tcp  --  0.0.0.0/0            0.0.0.0/0          tcp dpt:21 state NEW recent: UPDATE seconds: 160 hit_count: 8 name: DEFAULT side: source
    ACCEPT     tcp  --  0.0.0.0/0            192.168.1.1        tcp dpt:22
    ACCEPT     tcp  --  0.0.0.0/0            192.168.1.1        tcp dpt:21
    ACCEPT     tcp  --  0.0.0.0/0            192.168.1.1        tcp dpts:65100:65150
    BUT.....SURPRISE when I do "iptables-save /opt/tmp/iptables" and read the file I found:
    -A INPUT -p tcp -m tcp --dport 21 -m state --state NEW -m recent recent: seconds: 1701970168 hit_count: 1953391971 name:  side: source
    -A INPUT -p tcp -m tcp --dport 21 -m state --state NEW -m recent recent: seconds: 1701970168 hit_count: 1953391971 name:  side: source -j DROP
    And I saved this firewall after powering on the router (so the router had some hours to rest and clear memory)!!!!
    What's that????
  1. [Howto] Install DLNA media servers for Oleg firmware
    By ecaddict in forum WL-500gP Tutorials
    Last Post: 06-06-2017, 08:40
  2. Replies: 24
    Last Post: 05-05-2015, 08:42
  3. Replies: 28
    Last Post: 02-06-2013, 21:58
  4. Replies: 6
    Last Post: 21-09-2012, 18:06
  5. [Howto] Install kernel modules for Oleg firmware
    Last Post: 05-12-2011, 17:18
