Now there is no transmission in repository...
Downloading http://ipkg.nslu2-linux.org/feeds/op...3-2_mipsel.ipk
wget: server returned error 404: HTTP/1.1 404 Not Found
Somebody remove it...
Hi all,
the howto is updated for transmission versions newer than 1.3.
I also renumbered the chapters.
Please report bugs.
@Lesiuk
Sorry, i do not get these errors. I even can not help.
Sorry
wengi
there seems to be a build problem.
Wait till tomorow/some days.
wengi
i updated 15 mins ago and run into the same problem.
Have no solution jet.
wengi
I have solution.
http://forum.transmissionbt.com/view...php?f=1&t=6659
Now i have transmission web.
401: Unauthorized
Unauthorized IP Address
1- Stop transmission2- Edit the settings.json file:killall transmission-daemon
*- go to string "rpc-whitelist": "+127.0.0.1",
*- fix the value (+127.0.0.1) to your computer IP (i.e. 192.168.1.*) or just delete this value( i.e. "rpc-whitelist": "",)
3- Launch transmission (or reboot router)
the reason is that my transmission does not create the settings.json any more.
Not on the hdd and not in the users home .config folder.
No idea why. The settings file is not part of the package.Code:[admin@blechbuechse /]$ ps axf PID TTY STAT TIME COMMAND 1 ? S 0:03 /sbin/init 2 ? S 0:00 [keventd] ... 127 ? Ss 0:04 /opt/sbin/cron 270 ? SN 0:36 /opt/bin/transmission-daemon -g /tmp/harddisk/transmission/config -b -w /tmp/harddisk/transmission/download 271 ? SN 0:00 \_ /opt/bin/transmission-daemon -g /tmp/harddisk/transmission/config -b -w /tmp/harddisk/transmission/download 272 ? RN 0:00 \_ /opt/bin/transmission-daemon -g /tmp/harddisk/transmission/config -b -w /tmp/harddisk/transmission/download 273 ? RN 4:34 \_ /opt/bin/transmission-daemon -g /tmp/harddisk/transmission/config -b -w /tmp/harddisk/transmission/download [admin@blechbuechse /]$ find / | grep -i settings.json /proc/7/fd: No such file or directory [admin@blechbuechse /]$
Could you please post the content and location of your settings.json?Code:[admin@blechbuechse .config]$ ipkg files transmission | grep -i set [admin@blechbuechse .config]$
Thanks
wengi
Hi
I have setting.json on harddisk in config folder.
My transmission work about 10 min. and after don`t work properly.
Please I` need help.
In your case, the setting file should be in /tmp/harddisk/transmission/config
Example of file contents HERE
Beta version...it figures. I'm waiting for the final version.
Cheers!
Who is making package's for optware repository?
Do somebody have 1.41b3 ?
Hi all,
i once again updated the HowTo:
Transmission is working with a config file now.
The startup script knows the option restart now.
@Lesiuk
Try this config with the newest version of transmission.
I wish all of you a happy new year!
wengi
