The NTP client pools the server every 24 hours, as shown by chris.Now, the above answer got me thinking: Could it be the NTP-client in the router that's causing the network traffic? I will have to test this at home.
Possibly there is a bug in the idle timer function. However are you sure that you are not disturbed by incoming traffic ? I mean, if, for instance, you have not disabled ICMP echo reply, your routeur will answer every scan from the internet and reset its idle timer to 0...If anyone has got any idea how to fix the idle time disconnects (so that they actually work!), then PLEASE, PLEASE let me/us/the world know! PLEASE!
I suggest you to activate the firewall in order to filter all unsollicited incoming traffic : ICMP, UDP and TCP SYN messages. If the router still does not disconnect, it is really a bug. If it does, refine your firewall configuration...
