adduser - 1.9.0-1 - a multi-call binary for login and user account administration
bzip2 - 1.0.4-2 - Very high-quality data compression program
cron - 4.1-7 - Standard vixie cron, with cron.d addition
cyrus-sasl-libs - 2.1.22-2 - Provides client or server side authentication (see RFC 2222).
e2fsprogs - 1.40.3-1 - Ext2 Filesystem Utilities
expat - 2.0.1-1 - XML Parser library
fontconfig - 2.5.0-0 - Font configuration library
freetype - 2.1.10-4 - Free truetype library
gconv-modules - 2.2.5-7 - Provides gconv modules missing from the firmware. These are used by glibc's iconv() implementation.
gdbm - 1.8.3-2 - GNU dbm is a set of database routines that use extensible hashing. It works similar to the standard UNIX dbm routines.
glib - 2.9.6-1 - The GLib library of C routines.
ipkg-opt - 0.99.163-9 - The Itsy Package Manager
libcurl - 7.17.0-3 - Curl is a command line tool for transferring files with URL syntax, supporting FTP, FTPS, HTTP, HTTPS, GOPHER, TELNET, DICT, FI
libdb - 4.2.52-3 - Berkeley DB Libraries
libgd - 2.0.35-1 - An ANSI C library for the dynamic creation of images
libjpeg - 6b-2 - collection of jpeg tools
libpng - 1.2.23-1 - Portable Network Graphics Libraries
libsigc++ - 2.0.18-1 - libsigc++ implements a typesafe callback system for standard C++.
libtorrent - 0.11.9-1 - libtorrent is a BitTorrent library with a focus on high performance and good code.
libuclibc++ - 0.2.2-4 - C++ standard library designed for use in embedded systems
libxml2 - 2.6.30-2 - Libxml2 is the XML C parser and toolkit developed for the Gnome project.
libxslt - 1.1.22-1 - An XML Stylesheet processor based on libxml2
lighttpd - 1.4.18-1 - A fast webserver with minimal memory footprint.
mc - 4.6.1-3 - Midnight Commander File Manager
microperl - 5.8.8-11 - Microperl.
nano - 2.0.7-1 - A pico like editor
ncurses - 5.6-3 - NCurses libraries
ncursesw - 5.6-1 - NCurses libraries with wide char support.
openldap-libs - 2.3.38-1 - Open Lightweight Directory Access Protocol
openssh - 4.7p1-1 - a FREE version of the SSH protocol suite of network connectivity tools.
openssl - 0.9.7m-3 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari
pcre - 7.4-1 - Perl-compatible regular expression library
php - 5.2.5-1 - The php scripting language
php-fcgi - 5.2.5-1 - The php scripting language, built as an fcgi module
php-gd - 5.2.5-1 - libgd extension for php
readline - 5.2-2 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are
rtorrent - 0.7.9-2 - rtorrent is a BitTorrent client for ncurses, using the libtorrent library.
screen - 4.0.3-2 - A screen manager that supports multiple logins on single terminal
slang - 2.1.2-1 - S-Lang is a multi-platform library designed to allow a developer to create robust multi-platform software.
sqlite - 3.5.4-1 - SQLite is a small C library that implements a self-contained, embeddable, zero-configuration SQL database engine.
termcap - 1.3.1-2 - Terminal emulation library
uclibc-opt - 0.9.28-12 - micro C library for embedded Linux systems
vsftpd - 2.0.5-1 - ftp daemon with an emphasis on speed and security
wget - 1.10.2-4 - A network utility to retrieve files from the Web
xmlrpc-c - 1.11.00-2 - A library providing modular implementation of XML-RPC for C and C++.
zlib - 1.2.3-2 - zlib is a library implementing the 'deflate' compression system.
