If i guess right your WL will act as a normal client on the network and not as router for internet (thats your pc's job). You need to connect the LAN port to the switch!
10.2.109.100 is NOT in the range of your network.
255.255.255.224 means you have a max. of 30 hosts (plus BC).
Your host IP Range is 10.2.109.65 - 10.2.109.94.
Try it yourself: http://www.subnet-calculator.com
