To get to write for my hard disk the disk it does have to be in FAT32?
Doesn't it work in NTFS?
Thanks,
Punhal
Hi...
yes
Punhal
Thanks,
Punhal
NTFS --- readonly
FAT32 --- works with limitations
ext3fs --- native
Ok!
How is it that I format in ext3fs?
Punhal
I have a printer "hp psc all-in-one" linked to my router asus WL-500W.
The function of the scanner doesn't work. Is there some hypothesis of for the scanner to work for the router?
Thanks,
Punhal
http://wl500g.info/showthread.php?t=5909How is it that I format in ext3fs?
http://wl500g.info/showthread.php?t=10307
I suggest to search on "SANE". It's scanner support for linux. May be you'll have luck with your one...Is there some hypothesis of for the scanner to work for the router?
hi,
Is there some hypothesis of for the scanner to work for the router in WINDOWS XP?
What is SANE?
sorry
Punhal
