Results 1 to 15 of 29
Thread: [WLAN] Wireless LAN Card PCMCIA/PCCARD
    Jan 2004
    Levanger, Norway
    Wireless LAN Card
    Tested @
    Model:WL-500g
    Firmware: 1.6.5.3
    Device: NOT WORKING!
    Brandname: Nokia
    Brandtype: D211
    Card Type: PC-Card (PCMCIA)
    WLAN Connectivity: 11 Mbps
    Computer OS: Microsoft Windows XP Pro
    Driver Version: 4.33 (English)
    URL To manufacturer: http://www.nokia.com
    URL To product: http://www.nokia.com/nfb/nD211.html
    Jan 2004
    Levanger, Norway
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.5.3
    Device
    Brandname: Cisco
    Brandtype: Aironet 350 Series
    Driver Version: 8.3.10.0
    URL To manufacturer: http://www.cisco.com
    URL To product: http://www.cisco.com/en/US/products/...448/index.html
    Liksys PCMCIA Wireless-G and Linksys PCI WMP54G
    Model:WL-500g
    Firmware: 1.7.5.6
    Device: WORKING!
    Brandname: Linksys
    Brandtype: Wireless-G WPC54G v1.2
    Card Type: PCMCIA
    Tested in HP OmniBook 500
    WLAN Connectivity inside: 36-54 Mbps
    WLAN Connectivity outside: 12-54 Mbps
    Computer OS: Microsoft Windows XP Pro SP1
    Model:WL-500g
    Firmware: 1.7.5.6
    Device: WORKING!
    Brandname: Linksys
    Brandtype: WMP54G
    Card Type: PCI
    Tested in homebox P2, 800
    Aug 2004
    Amsterdam (NL)
    Intel 2100A series
    Model:WL-500g
    Firmware: 1.8.1.9
    Device: WORKING!
    Brandname: Intel
    Brandtype: 2100A Series
    Card Type: MiniPCI
    Encryption Tested: WEP128, WPA-TKIP
    Drivers: Dell Website A15 drv
    WLAN Connectivity inside: 11 Mbps
    Computer OS: Microsoft Windows XP Pro SP2
    Aug 2004
    Amsterdam (NL)
    Asus WL-100g
    Model:WL-500g
    Firmware: 1.8.1.9
    Device: WORKING!
    Brandname: Asus
    Brandtype: WL-100G
    Driver Version: 3.30.15.0
    Card Type: PCMCIA
    WLAN Connectivity inside: 54 Mbps very good reception.
    Tested Encryptions: WEP128, WPA-TKIP, AES
    Computer OS: Microsoft Windows XP Pro US SP2
    Jan 2004
    Levanger, Norway
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.5.3
    Device
    Brandname: Asus
    Brandtype: WL-100g
    WLAN Connectivity: 54 Mbps
    Computer OS: Microsoft Windows 98
    Driver Version: 1.8.2.8 (English)
    URL To manufacturer: http://www.asus.com
    URL To product: http://www.asus.com/products/communi...g/overview.htm
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.5.3
    Device
    Brandname: Kobishi
    Brandtype: Wireless LAN PCMCIA Card
    Driver Version: ??
    Tested: WORKING!
    Model:WL-500g
    Firmware: 1.6.5.3
    Device
    Brandname: Conceptronic
    Brandtype: C54i
    Card Type: PCI Card
    Driver Version: 1.0
    URL To manufacturer: http://www.conceptronic.net
    URL To product: http://www.conceptronic.net/product3.asp?g=9&p=*C54i
    Nokia D211
    Nokia D211 & Asus WL-500g works ok !!!!!!
    (Force WL-500g to 1-11Mbps)
    Wireless LAN Card
    Tested @
    Model:WL-500g
    Firmware: 1.6.5.3
    Device: WORKING!
    Brandname: Nokia
    Brandtype: D211
    Aug 2004
    Amsterdam (NL)
    DigiConnect WLAN/Memory USB Stick
    Model:WL-500g
    Firmware: Tested with all firmwares... all worked fine.
    Device: WORKING!
    Brandname: USB Wifi Memory Stick 802.11b / 32Mb
    Brandtype: DigiConnect
    Card Type: USB stick
    Encryption Tested: WEP128 (11Mbit with dc manager) , WPA-TKIP (2Mbit with xp manager, dc manager only supports wep128)
    Drivers: 3.0.2
    Note: Although connection speed drops to lower rate with higher encryption its very stable. This USB stick has an Intersil chipset and works with netstumbler 4. Nice gadget for on the road or to quickly hook up a visiting computer at your home to the internet.
    Apple Airport Extreme
    Tested @
    Model:WL-500g
    Firmware: 1.6.5.3
    Device: WORKING!
    Brandname: Apple
    Brandtype: Airport Extreme
    Card Type: internal Card
    Computer OS: Mac OS X 10.3.2
    Driver Version: Airport 3.3
    URL To manufacturer: http://www.apple.com
    URL To product: http://www.apple.com/airport/
    Aug 2004
    Amsterdam (NL)
    SiteCom WL-121V2
    Model:WL-500g
    Firmware: 1.8.1.9
    Device: WORKING!
    Brandname: SiteCom
    Brandtype: PCI Card 100G+ (WL-121V2)
    Driver Version: 2.1.22.2 (14-5-2004)
    Card Type: PCI
    Note:
    Compared to the Linksys WMP54G (V2!) its connection is a bit more ~ (waving) than the flatline rock stable Linksys. Sometimes the connection drops a line on the wavebar and than comes back to full range. Never lost connection though and if I tease the card by disabling/enabling or renewing it a few times it always come back properly.
    The drivers gave a nice simple install and the Sitecom client manager ROCKS!!! It supports every encryption possible even AES!!!!
    I would say this is a very good bargain... since its cheaper than the Linksys and shows some nice extra features
    Feb 2004
    Eindhoven
    Tested: Working
    Device: WLAN mini-PCI card
    Brandname: DELL TrueMobile 1300
    Brandtype: -
    URL To manufacturer: http://www.dell.com/
    Tested successfully in all encryption modes (WEP-128, WPA-PSK (TKIP and AES)
    Speed inside 7 meters area: 11-54 MBit/s
    Model: WL-500g
    Firmware: 1.6.5.3
    Tested @
    Model:WL-500g
    Firmware: 1.7.5.6
    Device: WORKING!
    Brandname: Dell
    Brandtype: TrueMobile 1300
    Card Type: Mini-PCI
    Tested in Dell Inspiron 8100 P3m-866 A15 BIOS
    Driver Version: A02
  1. PCI /PCMCIA wifi card with WMM( QoS) support
    By Antwerp in forum Dutch Discussion - Nederlands
    Last Post: 24-08-2005, 11:37
  2. wireless card cannot connect to WL-500G
    By mdn666 in forum WL-500g Q&A
    Last Post: 10-06-2005, 12:00
  3. Looking for PCMCIA CARD
    By britnet in forum WL-500g Q&A
    Last Post: 14-02-2005, 18:31
  4. Which PCcard works best with the WL-500G ?
    By gwl in forum WL-500g Q&A
    Last Post: 21-12-2004, 23:08
  5. [Wireless] Which PCI card works best with WL-500g?
    By Twofish in forum WL-500g Q&A
    Last Post: 03-09-2004, 23:50
