Imagemagick compiles correctly with a simple change in the makefile
imagemagick.mk
change line
IMAGEMAGICK_CPPFLAGS=
to
IMAGEMAGICK_CPPFLAGS=$(STAGING_CPPFLAGS)/freetype2
I am trying to generate some Jepgs with text using ImageMagick. On my Linux System (Suse) it works flawless.
So I installed on my WL-HDD with Olegs latest firmware ( thanks for that graet work) first freetype-2.1.10-4 and than ImageMagick-6.3.4-0-1.
Install went well, basic ImageMagick functions were ok.
When I tried to generate text images, ImageMagick complained about missing fonts for freetype. No matter what fonts I supplied.
So I also installed ghostscript and adjusted ImageMagick paths to these fonts although I had no ghostscript on my Suse system.
No I got a changed errormessage :
The font is exactly there.convert -background blue -fill white -sampling-factor 2x1 -size 3872x2592 -pointsize 8 label:@test.txt test.jpg
AFPL Ghostscript 8.50: ./src/interp.c(295): Fatal error -20 in gs_interp_init!AFPL Ghostscript 8.50: ./src/interp.c(295): Fatal error -20 in gs_interp_init!convert: FreeType library is not available `/opt/share/ghostscript/fonts/n019003l.pfb'
So I started thinking it is an issue with freetype support.
I set up the toolchain according to your wiki.
Days later I made a working freetype and ImageMagick package. And I got the same error.
If I look into the make.log file of Imagemagick I find this lines:
So Imagemagick is compiled without freetype.-------------------------------------------------------------
configure:34786: result: Checking for FreeType 2.0 support
configure:34788: result: -------------------------------------------------------------
configure:34802: checking for freetype-config
configure:34832: result: no
configure:35095: result: no
configure:35111: checking if FreeType package is complete
configure:35116: result: no -- some components failed test
configure:35182: result: -------------------------------------------------------------
Configure looks for a lot of files of the freetype package, which are now at a different location as it suspects.
I can't fix this.
Any help is appreciated.
Martin
imagemagick.mk
change line
to
