Лог
Jan 1 03:00:02 syslogd started: BusyBox v1.17.4
Jan 1 03:00:02 kernel: klogd started: BusyBox v1.17.4 (2010-11-26 21:49:41 MSK)
Jan 1 03:00:02 kernel: CPU revision is: 00029006
Jan 1 03:00:02 kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Jan 1 03:00:02 kernel: Primary data cache 16kB, 2-way, linesize 16 bytes.
Jan 1 03:00:02 kernel: Linux version 2.4.37.10 (root@localhost) (gcc version 3.4.6) #1 2010-11-26 21:53:28 MSK
Jan 1 03:00:02 kernel: Setting the PFC to its default value
Jan 1 03:00:02 kernel: Determined physical RAM map:
Jan 1 03:00:02 kernel: memory: 02000000 @ 00000000 (usable)
Jan 1 03:00:02 kernel: On node 0 totalpages: 8192
Jan 1 03:00:02 kernel: zone(0): 8192 pages.
Jan 1 03:00:02 kernel: zone(1): 0 pages.
Jan 1 03:00:02 kernel: zone(2): 0 pages.
Jan 1 03:00:02 kernel: Kernel command line: root=/dev/mtdblock2 rootfstype=squashfs,ext3 noinitrd init=/linuxrc console=ttyS0,115200
Jan 1 03:00:02 kernel: CPU: BCM4704 rev 9 pkg 0 at 264 MHz
Jan 1 03:00:02 kernel: Using 132.000 MHz high precision timer.
Jan 1 03:00:02 kernel: Calibrating delay loop... 263.78 BogoMIPS
Jan 1 03:00:02 kernel: Memory: 29960k/32768k available (1961k kernel code, 2808k reserved, 140k data, 92k init, 0k highmem)
Jan 1 03:00:02 kernel: Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 03:00:02 kernel: Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Jan 1 03:00:02 kernel: Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 03:00:02 kernel: Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 03:00:02 kernel: Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 03:00:02 kernel: Checking for 'wait' instruction... unavailable.
Jan 1 03:00:02 kernel: POSIX conformance testing by UNIFIX
Jan 1 03:00:02 kernel: PCI: Initializing host
Jan 1 03:00:02 kernel: PCI: Fixing up bus 0
Jan 1 03:00:02 kernel: PCI: Fixing up bridge
Jan 1 03:00:02 kernel: PCI: Fixing up bus 1
Jan 1 03:00:02 kernel: Linux NET4.0 for Linux 2.4
Jan 1 03:00:02 kernel: Based upon Swansea University Computer Society NET3.039
Jan 1 03:00:02 kernel: Initializing RT netlink socket
Jan 1 03:00:02 kernel: Starting kswapd
Jan 1 03:00:02 kernel: Journalled Block Device driver loaded
Jan 1 03:00:02 kernel: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
Jan 1 03:00:02 kernel: devfs: boot_options: 0x1
Jan 1 03:00:02 kernel: NTFS driver v1.1.22 [Flags: R/O]
Jan 1 03:00:02 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Jan 1 03:00:02 kernel: pty: 256 Unix98 ptys configured
Jan 1 03:00:02 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
Jan 1 03:00:02 kernel: ttyS00 at 0xb8000300 (irq = 3) is a 16550A
Jan 1 03:00:02 kernel: ttyS01 at 0xb8000400 (irq = 3) is a 16550A
Jan 1 03:00:02 kernel: HDLC line discipline: version $Revision: 3.7 $, maxframe=4096
Jan 1 03:00:02 kernel: N_HDLC line discipline registered.
Jan 1 03:00:02 kernel: loop: loaded (max 8 devices)
Jan 1 03:00:02 kernel: PPP generic driver version 2.4.2
Jan 1 03:00:02 kernel: PPP Deflate Compression module registered
Jan 1 03:00:02 kernel: PPP BSD Compression module registered
Jan 1 03:00:02 kernel: MPPE/MPPC encryption/compression module registered
Jan 1 03:00:02 kernel: PPPoL2TP kernel driver, V0.15.1
Jan 1 03:00:02 kernel: PPTP driver version 0.8.5
Jan 1 03:00:02 kernel: Amd/Fujitsu Extended Query Table v1.3 at 0x0040
Jan 1 03:00:02 kernel: Flash Id: Vendor: 0x0001 Device: 0x007e
Jan 1 03:00:02 kernel: number of CFI chips: 1
Jan 1 03:00:02 kernel: cfi_cmdset_0002: Disabling fast programming due to code brokenness.
Jan 1 03:00:02 kernel: Flash device: 0x800000 at 0x1c000000
Jan 1 03:00:02 kernel: Physically mapped flash: squashfs filesystem found at block 917
Jan 1 03:00:02 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 03:00:02 kernel: 0x00000000-0x00040000 : "boot"
Jan 1 03:00:02 kernel: 0x00040000-0x007f0000 : "linux"
Jan 1 03:00:02 kernel: 0x000e5480-0x007f0000 : "rootfs"
Jan 1 03:00:02 kernel: 0x007f0000-0x00800000 : "nvram"
Jan 1 03:00:02 kernel: 0x003e0000-0x007f0000 : "flashfs"
Jan 1 03:00:02 kernel: sflash: found no supported devices
Jan 1 03:00:02 kernel: Initializing Cryptographic API
Jan 1 03:00:02 kernel: IPv6 v0.8 for NET4.0
Jan 1 03:00:02 kernel: IPv6 over IPv4 tunneling driver
Jan 1 03:00:02 dropbear[79]: Running in background
Jan 1 03:00:02 kernel: usb.c: registered new driver usbdevfs
Jan 1 03:00:02 kernel: usb.c: registered new driver hub
Jan 1 03:00:03 kernel: PCI: Enabling device 01:03.2 (0000 -> 0002)
Jan 1 03:00:03 kernel: ehci_hcd 01:03.2: PCI device 1106:3104
Jan 1 03:00:03 kernel: ehci_hcd 01:03.2: irq 12, pci mem c01ec000
Jan 1 03:00:03 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 03:00:03 kernel: EHCI: Enabling VIA 6212 workarounds
Jan 1 03:00:03 kernel: ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 10 Dec 2004/2.4
Jan 1 03:00:03 dnsmasq[85]: started, version 2.55 cachesize 512
Jan 1 03:00:03 dnsmasq[85]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N DHCP no-scripts no-TFTP
Jan 1 03:00:03 dnsmasq-dhcp[85]: DHCP, IP range 192.168.1.10 -- 192.168.1.20, lease time 1d
Jan 1 03:00:03 dnsmasq[85]: read /etc/hosts - 4 addresses
Jan 1 03:00:03 dnsmasq-dhcp[85]: read /etc/ethers - 2 addresses
Jan 1 03:00:03 kernel: hub.c: USB hub found
Jan 1 03:00:03 kernel: hub.c: 4 ports detected
Jan 1 03:00:03 kernel: usb.c: registered new driver usblp
Jan 1 03:00:03 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 03:00:03 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 03:00:03 kernel: Initializing USB Mass Storage driver...
Jan 1 03:00:03 kernel: usb.c: registered new driver usb-storage
Jan 1 03:00:03 kernel: USB Mass Storage support registered.
Jan 1 03:00:04 dhcp client: deconfig: lease is lost
Jan 1 03:00:04 dnsmasq[85]: read /etc/hosts - 4 addresses
Jan 1 03:00:04 dnsmasq-dhcp[85]: read /etc/ethers - 2 addresses
Jan 1 03:00:04 dnsmasq[85]: using nameserver 217.27.40.2#53
Jan 1 03:00:04 dnsmasq[85]: using nameserver 10.5.4.1#53
Jan 1 03:00:04 dhcp client: bound IP : 10.5.4.67 from 10.5.7.254
Jan 1 03:00:04 pppd[110]: Plugin rp-pppoe.so loaded.
Jan 1 03:00:04 pppd[110]: RP-PPPoE plugin version 3.10 compiled against pppd 2.4.5
Jan 1 03:00:05 pppd[111]: pppd 2.4.5 started by root, uid 0
Jan 1 03:00:05 pppd[111]: PPP session is 35177 (0x8969)
Jan 1 03:00:05 pppd[111]: Connected to 00:15:17:54:38:1c via interface vlan1
Jan 1 03:00:05 pppd[111]: Using interface ppp0
Jan 1 03:00:05 pppd[111]: Connect: ppp0 <--> vlan1
Jan 1 03:00:05 pppd[111]: CHAP authentication succeeded: Welcome.
Jan 1 03:00:05 pppd[111]: peer from calling number 00:15:17:54:38:1C authorized
Jan 1 03:00:05 pppd[111]: local IP address 81.22.xxx.xxx
Jan 1 03:00:05 pppd[111]: remote IP address 81.22.xxx.xxx
Jan 1 03:00:05 pppd[111]: primary DNS address 217.27.40.2
Jan 1 03:00:05 pppd[111]: secondary DNS address 217.27.41.2
Jan 1 03:00:05 dnsmasq[85]: read /etc/hosts - 4 addresses
Jan 1 03:00:05 dnsmasq-dhcp[85]: read /etc/ethers - 2 addresses
Jan 1 03:00:05 dnsmasq[85]: using nameserver 217.27.41.2#53
Jan 1 03:00:05 dnsmasq[85]: using nameserver 217.27.40.2#53
Jan 1 03:00:05 PPPoE: connected to ISP
Jan 1 03:00:07 login[131]: root login on 'pts/0'
Oct 29 22:06:38 pppd[111]: System time change detected.
Oct 29 22:13:27 login[310]: root login on 'pts/1'
Oct 29 22:13:59 dnsmasq-dhcp[85]: DHCPREQUEST(br0) 192.168.1.10 00:26:b6:14:ce:53
Oct 29 22:13:59 dnsmasq-dhcp[85]: DHCPACK(br0) 192.168.1.10 00:26:b6:14:ce:53 home
Oct 29 22:16:56 dnsmasq-dhcp[85]: DHCPINFORM(br0) 192.168.1.10 00:26:b6:14:ce:53
Oct 29 22:16:56 dnsmasq-dhcp[85]: DHCPACK(br0) 192.168.1.10 00:26:b6:14:ce:53 home
Oct 29 22:20:19 pppd[111]: No response to 6 echo-requests
Oct 29 22:20:19 pppd[111]: Serial link appears to be disconnected.
Oct 29 22:20:19 pppd[111]: Connect time 14.1 minutes.
Oct 29 22:20:19 pppd[111]: Sent 1760007 bytes, received 6536668 bytes.
Oct 29 22:20:24 dnsmasq[85]: read /etc/hosts - 4 addresses
Oct 29 22:20:24 dnsmasq-dhcp[85]: read /etc/ethers - 2 addresses
Oct 29 22:20:24 dnsmasq[85]: using nameserver 217.27.40.2#53
Oct 29 22:20:24 dnsmasq[85]: using nameserver 10.5.4.1#53
Oct 29 22:20:24 PPPoE: Disconnected
Oct 29 22:20:30 pppd[111]: Connection terminated.
Oct 29 22:20:31 pppd[111]: Modem hangup
Oct 29 22:21:01 pppd[111]: PPP session is 35195 (0x897b)
Oct 29 22:21:01 pppd[111]: Connected to 00:15:17:54:38:1c via interface vlan1
Oct 29 22:21:01 pppd[111]: Using interface ppp0
Oct 29 22:21:01 pppd[111]: Connect: ppp0 <--> vlan1
Oct 29 22:21:01 pppd[111]: CHAP authentication succeeded: Welcome.
Oct 29 22:21:01 pppd[111]: peer from calling number 00:15:17:54:38:1C authorized
Oct 29 22:21:01 pppd[111]: local IP address 81.22.198.186
Oct 29 22:21:01 pppd[111]: remote IP address 81.22.198.128
Oct 29 22:21:01 pppd[111]: primary DNS address 217.27.40.2
Oct 29 22:21:01 pppd[111]: secondary DNS address 217.27.41.2
Oct 29 22:21:01 dnsmasq[85]: read /etc/hosts - 4 addresses
Oct 29 22:21:01 dnsmasq-dhcp[85]: read /etc/ethers - 2 addresses
Oct 29 22:21:01 dnsmasq[85]: using nameserver 217.27.41.2#53
Oct 29 22:21:01 dnsmasq[85]: using nameserver 217.27.40.2#53
Oct 29 22:21:01 PPPoE: connected to ISP
Oct 29 22:27:26 dnsmasq-dhcp[85]: DHCPINFORM(br0) 192.168.1.10 00:26:b6:14:ce:53
Oct 29 22:27:26 dnsmasq-dhcp[85]: DHCPACK(br0) 192.168.1.10 00:26:b6:14:ce:53 home
