Wat is er allemaal verandert in deze firmware? Dat kan ik nergens terugvinden namelijk.
//Edit:
Ik heb het net gevonden... :
New Busybox applets (env, cmp, wc, md5sum sha-1)
IGMP proxy added (multicast routing [IPTV]) (IP Config | Route > Enable multicast routing?)
Added an option to specify 802.11 multicast rate (Wireless | Advanced > Multicast rate)
New kernel features (incl. advanced router, new iptables targets)
Fixed compile problems with newer Linux ditributions
Web interface should no longer show Cable Disconnected status
There is now an option to enable/disable DoS protection (Internet Firewall | Basic Config > Enable DoS protection?)
Built-in ftp server should now work fine in PASV mode
Updated Dropbear to 0.49
Updated WiFi to 3.90.38.00
Added support for the 128MB of onboard RAM
hiddev support
FPU emulator fixes
WL-HDD IDE fixes - SMART should work now
Onboard flash type diagnostic messages
Fixed flashfs to respect comment signs
flash command now has progress indicator
Station/Ethernet Brodge mode should now associate faster to AP after reboot
WL500g Deluxe/Premium/WL550gE now rescpect WAN port settings from the web
WL500g Premium/WL550gE now better handles OFDM transmitter power setting
Added support for /etc/fstab before automount
Fixed problems then upgradinf via WiFi using WPA/WPA-PSK
Disabled "power off" for all units except WL-HDD
Pressing EZ SETUP button for 3 seconds would cause /usr/local/sbin/ez-setup to be executed
