Jan 1 01:00:02 kernel: !unable to setup serial console!
Jan 1 01:00:02 kernel: Calibrating delay loop... 82.94 BogoMIPS
Jan 1 01:00:02 kernel: Memory: 13860k/16384k available (1776k kernel code, 2524k reserved, 248k data, 72k init, 0k highmem)
Jan 1 01:00:02 kernel: Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
Jan 1 01:00:02 kernel: Inode cache hash table entries: 1024 (order: 1, 8192 bytes)
Jan 1 01:00:02 kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 01:00:02 kernel: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:02 kernel: Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:02 kernel: Checking for 'wait' instruction... unavailable.
Jan 1 01:00:02 kernel: POSIX conformance testing by UNIFIX
Jan 1 01:00:02 kernel: PCI: Fixing up bus 0
Jan 1 01:00:02 kernel: PCI: Fixing up bridge
Jan 1 01:00:02 kernel: PCI: Fixing up bus 1
Jan 1 01:00:02 kernel: Linux NET4.0 for Linux 2.4
Jan 1 01:00:02 kernel: Based upon Swansea University Computer Society NET3.039
Jan 1 01:00:02 kernel: Initializing RT netlink socket
Jan 1 01:00:02 kernel: Starting kswapd
Jan 1 01:00:02 kernel: Journalled Block Device driver loaded
Jan 1 01:00:02 kernel: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
Jan 1 01:00:02 kernel: devfs: boot_options: 0x1
Jan 1 01:00:02 kernel: NTFS driver v1.1.22 [Flags: R/O]
Jan 1 01:00:02 kernel: pty: 256 Unix98 ptys configured
Jan 1 01:00:02 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
Jan 1 01:00:02 kernel: HDLC line discipline: version $Revision$, maxframe=4096
Jan 1 01:00:02 kernel: N_HDLC line discipline registered.
Jan 1 01:00:02 kernel: loop: loaded (max 8 devices)
Jan 1 01:00:02 kernel: PPP generic driver version 2.4.2
Jan 1 01:00:02 kernel: PPP Deflate Compression module registered
Jan 1 01:00:02 kernel: PPP BSD Compression module registered
Jan 1 01:00:02 kernel: MPPE/MPPC encryption/compression module registered
Jan 1 01:00:02 kernel: Amd/Fujitsu Extended Query Table v1.1 at 0x0040
Jan 1 01:00:02 kernel: Physically mapped flash: Swapping erase regions for broken CFI table.
Jan 1 01:00:02 kernel: number of CFI chips: 1
Jan 1 01:00:02 kernel: Flash device: 0x400000 at 0x1fc00000
Jan 1 01:00:02 kernel: Physically mapped flash: squashfs filesystem found at block 945
Jan 1 01:00:02 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 01:00:02 kernel: 0x00000000-0x00040000 : "pmon"
Jan 1 01:00:02 kernel: 0x00040000-0x003f0000 : "linux"
Jan 1 01:00:02 kernel: 0x000ec4e4-0x003f0000 : "rootfs"
Jan 1 01:00:02 kernel: 0x003f0000-0x00400000 : "nvram"
Jan 1 01:00:02 kernel: 0x003e0000-0x003f0000 : "flashfs"
Jan 1 01:00:02 kernel: sflash: chipcommon not found
Jan 1 01:00:02 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Jan 1 01:00:02 kernel: IP Protocols: ICMP, UDP, TCP
Jan 1 01:00:02 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 01:00:02 kernel: TCP: Hash tables configured (established 1024 bind 2048)
Jan 1 01:00:02 kernel: ip_conntrack version 2.1 (128 buckets, 1024 max) - 344 bytes per conntrack
Jan 1 01:00:02 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 01:00:02 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 01:00:02 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 01:00:02 kernel: ipt_time loading
Jan 1 01:00:02 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 01:00:02 kernel: IPv6 v0.8 for NET4.0
Jan 1 01:00:02 kernel: IPv6 over IPv4 tunneling driver
Jan 1 01:00:02 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 01:00:02 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
Jan 1 01:00:02 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 01:00:02 kernel: FAT: bogus logical sector size 5376
Jan 1 01:00:02 kernel: NTFS: Unable to set blocksize 512.
Jan 1 01:00:02 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 01:00:02 kernel: Mounted devfs on /dev
Jan 1 01:00:02 kernel: Freeing unused kernel memory: 72k freed
Jan 1 01:00:02 kernel: Warning: unable to open an initial console.
Jan 1 01:00:02 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 01:00:02 kernel: Uniform Multi-Platform E-IDE driver Revision: 6.31
Jan 1 01:00:02 kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Jan 1 01:00:02 kernel: PDC20265: IDE controller on PCI bus 01 dev 08
Jan 1 01:00:02 kernel: PCI: Enabling device 01:01.0 (0004 -> 0007)
Jan 1 01:00:02 kernel: PDC20265: chipset revision 2
Jan 1 01:00:02 kernel: PDC20265: not 100% native mode: will probe irqs later
Jan 1 01:00:02 kernel: PDC20265: ROM enabled at 0x000d0000
Jan 1 01:00:02 kernel: PDC20265: (U)DMA Burst Bit DISABLED Primary PCI Mode Secondary PCI Mode.
Jan 1 01:00:02 kernel: PDC20265: FORCING BURST BIT 0x00 -> 0x01 ACTIVE
Jan 1 01:00:02 kernel: MA at 0x0140-0x0147, BIOS settings: hda
MA, hdb
io
Jan 1 01:00:02 kernel: ide1: BM-DMA at 0x0148-0x014f, BIOS settings: hdc
io, hdd
io
Jan 1 01:00:02 kernel: hda: TOSHIBA MK8026GAX, ATA DISK drive
Jan 1 01:00:02 kernel: ide2: ports already in use, skipping probe
Jan 1 01:00:02 kernel: ide3: ports already in use, skipping probe
Jan 1 01:00:02 kernel: ide4: ports already in use, skipping probe
Jan 1 01:00:02 kernel: ide5: ports already in use, skipping probe
Jan 1 01:00:02 kernel: ide0 at 0x100-0x107,0x10a on irq 6
Jan 1 01:00:02 kernel: blk: queue c00222e8, I/O limit 4095Mb (mask 0xffffffff)
Jan 1 01:00:02 kernel: hda: 156301488 sectors (80026 MB), CHS=155061/16/63, UDMA(33)
Jan 1 01:00:02 kernel: Partition check:
Jan 1 01:00:02 kernel: /dev/ide/host0/bus0/target0/lun0: p1
Jan 1 01:00:02 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.37.0
Jan 1 01:00:02 kernel: eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.37.0
Jan 1 01:00:02 kernel: PCI: Enabling device 01:02.0 (0004 -> 0006)
Jan 1 01:00:02 kernel: eth2: Broadcom BCM4320 802.11 Wireless Controller 3.90.37.0
Jan 1 01:00:02 kernel: device eth2 entered promiscuous mode
Jan 1 01:00:02 kernel: device wds0.49153 entered promiscuous mode
Jan 1 01:00:02 kernel: device eth1 entered promiscuous mode
Jan 1 01:00:02 kernel: br0: port 3(eth1) entering learning state
Jan 1 01:00:02 kernel: br0: port 2(wds0.49153) entering learning state
Jan 1 01:00:02 kernel: br0: port 1(eth2) entering learning state
Jan 1 01:00:03 kernel: br0: port 3(eth1) entering forwarding state
Jan 1 01:00:03 kernel: br0: topology change detected, propagating
Jan 1 01:00:03 kernel: br0: port 2(wds0.49153) entering forwarding state
Jan 1 01:00:03 kernel: br0: port 1(eth2) entering forwarding state
Jan 1 01:00:03 kernel: usb.c: registered new driver usbdevfs
Jan 1 01:00:03 kernel: usb.c: registered new driver hub
Jan 1 01:00:03 kernel: usb-ohci.c: USB OHCI at membase 0xb8004000, IRQ 2
Jan 1 01:00:03 kernel: usb-ohci.c: usb-00:04.0, PCI device 14e4:4715
Jan 1 01:00:03 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 01:00:03 kernel: hub.c: USB hub found
Jan 1 01:00:03 kernel: hub.c: 2 ports detected
Jan 1 01:00:03 kernel: usb.c: registered new driver usblp
Jan 1 01:00:03 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 01:00:04 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 01:00:04 kernel: Initializing USB Mass Storage driver...
Jan 1 01:00:04 kernel: usb.c: registered new driver usb-storage
Jan 1 01:00:04 kernel: USB Mass Storage support registered.
Jan 1 01:00:05 crond[79]: crond 2.3.2 dillon, started, log level 8
Jan 1 01:00:15 kernel: VFS: Can't find ext3 filesystem on dev ide0(3,0).
Jan 1 01:00:15 kernel: MSDOS FS: Using codepage 950
Jan 1 01:00:15 kernel: MSDOS FS: IO charset cp950
Jan 1 01:00:15 kernel: FAT: bogus logical sector size 64543
Jan 1 01:00:15 kernel: VFS: Can't find a valid FAT filesystem on dev 03:00.
Jan 1 01:00:15 kernel: FAT: freeing iocharset=cp950
Jan 1 01:00:15 kernel: kjournald starting. Commit interval 5 seconds
Jan 1 01:00:15 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Jan 1 01:00:15 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,1), internal journal
Jan 1 01:00:15 kernel: EXT3-fs: recovery complete.
Jan 1 01:00:15 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan 1 01:00:15 USB storage: ext3 fs mounted to /tmp/harddisk
Jan 1 01:00:15 FTP server: daemon is started
