does anybody have an idea? at some point I cant mount HDD anymore. I reflashed the router, recreated partition. even changed the HDD to another one. nothing helps. the error is:
system is the following:root@OpenWrt:/# mount -t ext3 /dev/discs/disc0/part1 /mnt
mount: mounting /dev/discs/disc0/part1 on /mnt failed
root@OpenWrt:/# lsmod
Module Size Used by Not tainted
ide-disk 16708 0
ext3 72804 0
jbd 54840 0 [ext3]
aec62xx 6940 1
ide-core 123936 0 [ide-disk aec62xx]
switch-robo 4620 0 (unused)
switch-core 4864 0 [switch-robo]
diag 21920 0 (unused)root@OpenWrt:/# fdisk -l
Disk /dev/ide/host0/bus0/target0/lun0/disc: 6448 MB, 6448619520 bytes
255 heads, 63 sectors/track, 784 cylinders
Device Boot Start End Blocks
Id System
/dev/ide/host0/bus0/target0/lun0/part1 1 100 803218+ 83 Linuxroot@OpenWrt:/# df
none 31464 8 31456 0% /tmp
/dev/mtdblock/4 384 324 60 84% /jffs
/jffs 896 896 0 100% /root@OpenWrt:/# mount
/dev/root on /rom type squashfs (ro)
none on /dev type devfs (rw)
none on /proc type proc (rw)
none on /tmp type tmpfs (rw)
/dev/mtdblock/4 on /jffs type jffs2 (rw)
/jffs on / type mini_fo (rw)
none on /dev/pts type devpts (rw)root@OpenWrt:/# ls -l
drwxr-xr-x 2 root root 483 Jan 23 2007 bin
drwxr-xr-x 1 root root 0 Jan 1 1970 dev
drwxr-xr-x 1 root root 0 Jan 1 00:00 etc
drwxr-xr-x 1 root root 0 Jan 1 00:01 jffs
drwxr-xr-x 5 root root 409 Jan 23 2007 lib
drwxr-xr-x 1 root root 0 Jan 1 00:02 mnt
dr-xr-xr-x 29 root root 0 Jan 1 00:00 proc
drwxr-xr-x 15 root root 136 Jan 23 2007 rom
drwxr-xr-x 2 root root 319 Jan 23 2007 sbin
drwxr-xr-x 2 root root 3 Jan 23 2007 sys
drwxrwxrwt 6 root root 140 Jan 1 00:00 tmp
drwxr-xr-x 6 root root 56 Jan 23 2007 usr
lrwxrwxrwx 1 root root 4 Jan 23 2007 var -> /tmp
drwxr-xr-x 2 root root 3 Jan 23 2007 www
Openwrt or Custom Firmware on asus? - http://wl700ge.hezik.nl/ - Http://wl700g.homelinux.net
My ASUS collection:WL500gp(80GB usb-hdd - Running OpenWrt Kamikaze 7.09) |
WL700gE(250GB - Running OpenWrt Kamikaze 8.09rc1)
It depends on how your router works I guess - mine hands out dhcp addresses, and there is a dhcp client that runs on the WAN port by default with openWRT. If that isnt the case for your router, then you can assign a static IP to eth0.1 in the /etc/config filesystem (around there somewhere I think)
My mount command is
this should definitely work for you looking at your fdisk output (unless the /mnt directory doesn't exist or the filesystem on the drive is corrupted - do an fsck on the drive device if that mount command doesn't work...)Code:mount -t ext3 /dev/ide/host0/bus0/target0/lun0/part1 /mnt
strange situation:
root@OpenWrt:/# mount -t ext3 /dev/ide/host0/bus0/target0/lun0/part1 /mnt
mount: mounting /dev/ide/host0/bus0/target0/lun0/part1 on /mnt failed
root@OpenWrt:/# mkdir /mnt/test
mini_fo: create_sto_dir: ERROR creating sto dir.
mkdir: cannot create directory '/mnt/test': No space left on device
root@OpenWrt:/# df
Hmm, odd - it's booted off jffs and somehow filled up that small partition (ie no room left to create a /mnt directory)
Is there anything you can delete off jffs to create some more room?
trying to go back to the original asus firmare shows:
orpivot_rc starting...
pivot_rc proceeding to boocramfs: wrong magic
t from disk...
ERROR(a):mount_pivot_point failed to mount location : /dev/ide/host2/bus0/target0/lun0/part1...
ERROR(b):mount_pivot_point error : Invalid argument...
pivot_rc boot loop error for location 0...
pivot_rc complete -> calling /sbin/init...
could it be that the flash ir physicallly broken?pivot_rc starting...
pivot_rc pcramfs: wrong magic
roceeding to boot from disk...
0/lun0/part1...
It seems to be very confused about where the hard drive actually is - you said you have tried openWRT on a different hard drive from the original one. Does the original still contain the ASUS formatted reiserfs partition - if so, try plugging that back in and see what the ASUS firmware says...
That doesn't look so good then! - try plugging your had drive into a pc and formatting it to reiserfs (or the openWRT one to ext3) then try to use the appropriate firmware again.
I hope this'll solve it - otherwise it looks like you may have screwed up your flash ROM...
i have tried 3 HDD:
1. original asus
2. Openwrt HDD that was inside the router when everything went wrong
3. another HDD with Openwrt
I have recreated ext3 partition several times. even created fat32 on pc and then back to ext3. nothing helps. so it seems that it is flash, not hdd related problem.
Well, that isn't so good for you then - the only other thing I can think of is to do a few firmware flashes to see if you can clear out the flash memory - you can do openWRT over serial port too I believe(as opposed to just tftp)
On a seperate note, I got the openWRT to work properly as a router - it seems that turning on the firewall just enables this feature - no extra config required!
Any extra configuration you need to do will be for individual ports that need to get to the router I guess...
